Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Want your inputs on a new old idea...
Old 03-14-2009, 03:59 AM
littlej2700's Avatar
Car: 1987 firebird formula
Transmission: 5-speed
sooooo... i think this would be real neat for all ya'll smokers out there like me. any ideas on how to pull this off or how they did back when it came out would be awesome. anyway heres the idea.... so i was watching that mecum's auto auction on TV and i think it was a '56 or '57 impala came up on the block and it had and ashtray with vacuum to it so it sucked up the ash and the smoke... it might be really hard or even impossible to do but i was hoping to design a system like that for my 87 bird.... any ideas on how or if anyone has attempted something similar??
Old 03-14-2009, 01:35 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
Re: Want your inputs on a new old idea...
one way: and this is totally MacGyvering it
Go to walmart or wherever. Buy a small handheld vacuum cleaner.
hide the base of the machine in the dash somewhere or trunk if you have a long enough hose.
re-wire the switch with long long long wires from the machine and install it into the center console.
install the end of the hose under the ashtray cutting a hole with a circular saw from home depot or sears hardware
use epoxy glue underneath to make sure the hose stays put
machine would be self powered but might have to either recharged or figure out a way to wire it to the car but you will need to find out alot of power specs on the machine
run the hose under the trim/carpet and under the center console.
i think you get the idea
i'm sure theres a more clever way but good luck
Old 03-14-2009, 02:17 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Use one of those battery-operated "PC" vacuums. I have one I bought at Circuit City (last year) that runs on 4 AA's. Wire it into the car's electrical with some resistors to knock the voltage down from 12V to 6V. Then you'll have to do some cutting and epoxying as mentioned in the last post.
My first instinct would be to use engine vacuum, but I don't see how you could do that without the engine seeing it as a vacuum leak.
Old 03-14-2009, 03:02 PM
83z28camaro's Avatar
Car: '01 GMC Sierra
Engine: 5.3L
Transmission: 4L60e
Axle/Gears: 3.73 eaton locker
look for one in caddilac from around '87. I think it was the deville and it was located in the front passanger kick panel.
Old 03-14-2009, 09:03 PM
Macguyver hahahaha I love it man. I like those ideas a lot and I'll draw up somethin but any ideas on harnessing natural engine vacuum? Just a thought.... Appreciate the help though I didn't know the caddies had it
Old 03-14-2009, 09:35 PM
Car: '01 GMC Sierra
Engine: 5.3L
Transmission: 4L60e
we have a couple caddies at work if I get a chance I will look and see if they have it.
Old 03-15-2009, 08:15 PM
that would be awesome much appreciated
Old 03-22-2009, 01:00 AM
boldguy's Avatar
Car: 1992 Z28
Transmission: World Class T-5 5speed manual Trans
Axle/Gears: STOCK G92 performance 3.42
speaking of macguyver....
macgruber!!!
http://www.youtube.com/watch?v=PUxxI28zhNc
this is an interesting thought. How do motors like nocitine? lol
Old 03-22-2009, 05:50 PM
jccaclimber's Avatar
Car: 1991 RS Camaro
Engine: 350 0.060" over
If you used engine vacuum you would either need a filter that you cleaned out, or you would be sucking whatever went into the hole into your engine vacuum source....the intake manifold.
Old 03-23-2009, 09:16 AM
iroc a 86 berli's Avatar
Car: 86 berlinetta 92rs gfx
Engine: 4 bolt 384 stroker
Transmission: th350 4000 stall manual/T brake
Axle/Gears: 87 iroc 9 bolt
hook it into the exhaust and make it scavenge it. get the angle right and it will pull a vacum effect.
http://www.edelbrock.com/automotive_.../6000/6560.pdf
Old 03-25-2009, 01:03 PM
83TransAmRECARO's Avatar
Car: 83 Pontiac Trans Am Recaro
Engine: Crossfire 350
Axle/Gears: 4.10 posi
I thought about doing a mod like this on a chevy beretta I had in the late 90's... only problem I ran into was the intake of hot materials... I used a 12volt vacuum from wal-mart and placed the vacuum motor in the center console... it worked great for a couple days... to make the story short the vacuum bag caught on fire...
just tossing in my couple cents worth of knowledge...
find a way to have the contents removed from the ashtray placed into a non-flamable container.
Old 03-26-2009, 01:42 AM
all great inputs i still dont know where to go with it but more of that exhaust idea has REALLY caught my attention. so any more help with that would be awesome. i mean could you just run a male vacuum end at some point near the collector on my headers and just run a vacuum line to the ashtray and make that work... but yeah that whole angle thing is a mystery to me
Old 03-26-2009, 09:39 AM
lol, thats acually for the crankcase evac on race engines. but it might work for your app. id use some pc tower fans and some dryer vent hose in reality. that way you dont have to mess with exhaust seeping into your ride if you screw up the angle.
cheesehomer
12-31-2015 08:48 AM
Linson
10-01-2015 09:50 PM
83ho87gn
09-26-2015 08:49 PM
83ho87gn
09-24-2015 08:58 AM
83 Crossfire TA
09-18-2015 12:01 PM
Quick Reply: Want your inputs on a new old idea...
