Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Sub frames (final design and build)
Old 12-23-2012, 12:36 AM
  #201
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Re: Sub frames (final design and build)
Originally Posted by Twin_Turbo
Very nice but why not weld them in?
My original idea was to weld them in but i decided to drill holes, weld in tubes and bolt them in. I also incorporated other areas of the car that i would consider structural that i couldn't do with welds, i mean i still could weld them in if i wanted but i don't think its going to matter at this point. I would say bolting them in the 30+ locations was actually stronger with my sub frame design, since there is a constant clamping force every (roughly) foot from each bolt/nut location along the entire sub-frames... I noticed when i only had bolted into the original locations i was going to weld in with no other places bolted in along the sub-frames there was some flex not much but some which was probably due to the thickness of tubing i chose to use, however once fully bolted in with the the correct bolt toque speculations for the bolts i used there was no flex. I am extremely impressed with the structural rigidity of the car, i was able to get 3 wheels off the ground when i jacked one of the rear corners of the car. The doors moved less then 3/32 away from the rear quarter panel, this was with out the t-tops on and i opened and closed the doors with out any problems while the car was up in the air with 3 wheels off the ground, no creeks, no cracks the about the only thing i heard while i was jacking the car up was the tire on the opposite side drag across the garage floor before losing contact from the floor
Old 12-31-2012, 02:59 PM
  #202
neilb's Avatar
Car: 1986 sports coupe, 1984 F41
Engine: 3.8L Turbo SFI, stock 305
Transmission: 700 R4, 700 R4
Axle/Gears: 3.42:1, 3.08:1
Originally Posted by FueledSoul
Some underside shots and an idea on the clearance... they sit about the same height as the UMI transmission cross member... actually the lower relocation brackets and rear of the torque arm hang lower then my subframes...
Beautiful frame connectors! I may be building my own in the near future, I will be sure to use your's as a reference. Also I believe (I may be wrong), the grease boots on your idler arm and pitman arm are on upside down. Not a big deal, just thought I'd mention it.
What tools were required? I'm assuming a chopsaw, grinder, welder, cutoff wheel, drill... anything I'm missing?
Again, great job on the connectors!
Old 01-03-2013, 10:44 AM
  #203
FueledSoul's Avatar
All of the grease boots should be in the right spot however nothing is really bolted in on the front half yet...as you can see in the top pic you quoted...
Everything you mentioned tool wise plus a tape measure, levels and angle finders... I used some air tools air die-grinders too im sure, but you covered the basics of what you will need.
Old 08-05-2013, 12:29 AM
  #204
firebird_6645's Avatar
Car: 1989 GTA WS6
Engine: 5.7L TPI
Axle/Gears: Borg 3.27
Will you be building any more and if so how much?:-)
Old 08-12-2013, 10:00 PM
  #205
GMZombie's Avatar
Car: 89 Camaro RS Convertible
Engine: 355 chevy power
Transmission: 5 speed manual
Axle/Gears: standard
i concur those are sick bro..so want a set of those.
Old 09-08-2013, 10:33 AM
  #206
BlackTopKing's Avatar
Car: 1987 Trans Am GTA
Axle/Gears: Posi 3:42
Fantastic time detail and so well thought out and executed. So many wouldn't of changed design to impove to save time and cost!
Great job, def impressive
Old 09-08-2013, 11:50 AM
  #207
Formula 305's Avatar
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
Those came out great! They have to make the car super rigid. They seem a little over engineered tho, do you know how much they weigh??
Old 09-08-2013, 12:41 PM
  #208
lmidden's Avatar
Car: 1987 camaro sc
Engine: lg4 305
how strong are these subframe connectors?
Old 10-20-2013, 09:54 AM
  #209
nickdiesel's Avatar
Car: 1988 Camaro Convertible
Nice work I might try to make something similar for my vert since the outside rails our already there.
Old 10-20-2013, 10:07 AM
  #210
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Thanks for the wonderful pictures.
Old 11-05-2013, 01:32 PM
  #211
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Stronger than the entire FRAME of the car I bet. Those things tie into every major stress point on the floor pan front to rear. If you cut the roof off that car I bet it would still be stiffer than a stock Thirdgen without SFCs.
About the only thing stiffer would be a full cage I bet.
Old 01-18-2014, 02:15 PM
  #212
FueledSoul's Avatar
There are pics on here showing what a 8 point cage tied into my sub frame design would look like on this thread.
Old 03-31-2014, 08:16 PM
  #213
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
Great build. Love all the pics
Old 04-20-2014, 10:08 AM
  #214
berlinettajames's Avatar
Car: 85 berlinetta
Engine: 5.0
Transmission: at
I am looking for front frame rails for my 85 berlinetta. I was under the car and noticed there isnt much left holding up the tranny. Where can i get new ones, or do i need to make my own??
Old 04-23-2014, 06:21 AM
  #215
Engine: LS3
Think you have to make your own.
Old 04-23-2014, 10:27 PM
  #216
Car: 85 berlinetta
Engine: 5.0
Transmission: at
I have an 85 and the frame rails where the tranny mounts are getting really bad. THANKS Ontairo, for putting salt on the roads. I am looking to fix her up, I am wondering if anyone knows of what i can do to, other then making up something. I am good with a welder and I know my way around tools thank god. I have been looking at new floor pans its just that no one has the frame rails on them. PLEASE help me.
Old 04-24-2014, 07:27 AM
  #217
FueledSoul's Avatar
post some pics if you can of what's going on.
Old 04-24-2014, 07:28 AM
  #218
Norm Peterson's Avatar
Car: '08 Mustang GT
Engine: 4.6L
Transmission: º º 0 . . . |-|-|
Axle/Gears: 8.8", 3.55
Sounds like you're in for fabbing your own frame rails, and a sheetmetal bending brake capable of bending whatever thickness necessary and some way of making long cuts in metal sheets would be on my wish list. If you aren't concerned with originality, you might be able to use square or rectangular tubing instead.
Norm
Old 09-02-2016, 10:44 AM
  #219
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Thanks for posting this whole thread FueledSoul. After reading through it I was able to mimic what you did with your inner set. Mine probably didn't turn out as nice but they still look great and should work fine, in addition to saving me ~$300!
Old 10-01-2016, 01:29 PM
  #220
FueledSoul's Avatar
Nice job!
Old 11-07-2016, 08:20 PM
  #221
Ghettobird52's Avatar
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
Wow you guys are ****ing amazing!! Thats some serious work there!
customblackbird
08-15-2021 10:16 PM
dennisbernal91z
Fabrication
29
03-02-2017 12:04 PM
aaron7
08-17-2016 06:02 PM
Polo Z03
09-10-2015 06:43 PM
89-S-dime
Southern California Area
09-04-2015 10:34 AM
Quick Reply: Sub frames (final design and build)
