AC / Heater Box Delete Filler Panel
Car: Used to drive a camaro
Wasn't there a vendor who was selling 82-92 AC / heater box delete filler panels? I plan on taking off my heater box and putting it away. I'd rather not fab one up but if I have to I will I guess.
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: AC / Heater Box Delete Filler Panel
havent seen anybody recently offer one.
they are simple to make, just trace the heater box you have onto a piece of aluminum, cut and drill holes.
86TA, yep, I think its that simple too. I just thought I remembered seeing something that wasn't that bad priced. But, looks like I'll get a hefty guage aluminum, metal blade for the ol' jig saw and drill some holes. LOL, maybe I should start selling them.
Car: 89 Iroc Z Convert, 89 RS Convert
Engine: 305 TPI, 305 TBI
Transmission: 5 Speed,
I have one for sale for $50 plus shipping a little rusty but could be sanded and painted. came out of a 86 Camaro Call 239-303-9943 tmruff@yahoo.com
Click on link for picts
http://fortmyers.craigslist.org/lee/pts/1361674419.html
Car: '82 Z28
He doesn't need a heater box, he needs a block-off plate.
some one sells them but i cant seem to find it.
BMR makes one for the 4th gen
http://www.bmrfabrication.com/misc/FP003.jpg
I saw that BMR piece and am 99.9999% sure it won't work. The last .00001% woudl come from trying it, LOL. I'm just going to make one. I have wire EDM machines at my disposal or if I'm feeling nutty can just get one waterjet cut for the profile and then machine in the mount holes. I was just trying to save me from DIY, BUT hey, if they turn out good I should sell em' for $50 bux.
1 Post
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
keepin my tired mouth shut.
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
here you go buddy http://acdelete.com/pages/82-92_F-body. next time do a search please.
yeah, read the post next time please
Car: sold
1 Post
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
IIRC there is a flange anound one of the large holes on the firewall that would keep a block-off plate from sitting flat against the firewall. It would need to be flattened out or cut off.
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Or you use RTV to seal around the plate and that will help fill in that raised edge. Same way the delete boxes or the stock boxes were installed.
1 Post
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
The stock heater box sits flat against the firewall even without the seal, because the heater box is raised up about 4" where this flange is.
This hole looks like it is about 4.5" in diameter with a 1/4" flange.
this link doesnt even work lol
i would jus flatten that lip off or grind it off. and throw a aluminum plate over it. wat would be nice is someone to make one for our cars and maybe have a laser etch on it, with the camaro symbol or the firebird symbol on it
Car: 89' IROC-Z
Engine: LO3
Some one on here must have access to a CNC Machine. Trace the stock box, trace where the holes are and scan it into the computer put a nice slab in there and start making these.
1 Post
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
I would assume that anyone that removes the A/C/ heater box will also remove the heater core, so I think it should be made to cover those holes too.
My plan is 1/4" stock (not sure what guage that is), machine out the pocket needed to clear the flange. I'm not a big fan of modifying something that is "permanent". I have access to a CNC but it's not really needed. I may do a CNC wire EDM to cut the profile but the holes and flange pocket I'll just do on a bridgeport.
Car: 86 berlinetta 92rs gfx
Engine: 4 bolt 384 stroker
Transmission: th350 4000 stall manual/T brake
Axle/Gears: 87 iroc 9 bolt
i just made a cardboard template, traced it on to 16ga sheet metal, i havent had the heater box for years, and i deystroyed it while removing it, i got a little mad.
as for the lip for the blower, i just beat it flush with a small hammer.
i used a plasma cutter for this one, but i made one for my old camaro using 20ga tin and tin snips.
i tacked it into place with a mig, sheet metal screws work just as good, but are difficult to install at the bottom of the plate, cause the wheel well.
I did. I just finished milling one up at work and have yet to mount it. Its aluminum 3/16 plate and I wanted to get it powdercoated and not painted so I'm waiting until I get it done to take pics and post finished pieces up for sale. FWIW, I had a circle or "pad" milled out to cover the area of the flange that's sticking out on the firewall. SO, it should mount flush but I'd recommend putting a 1/4" bead of slicone around the parameter of this plate to keep the dirt,water,air out.
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
Here's what I did. I know it's a little more extreme. But, I just got tired of how terrible the cowl and firewall look on these cars.
1986BANDIT (03-15-2021)
Car: 2003 F-150
Engine: 4.6L Modular V8
Transmission: 4R70W
Axle/Gears: Ford 8.8"/3.55 LSD
Its a hell of alot cheaper and easier to go to ACE, buy some sheet, and make it yourself.
Mines, DIY and looks fine. I did everything via a saber saw, bench drill press. The only thing I had to use a Bridgeport on was the milled pocket to cover the 4" hole in the firewall.
Car: '82 Z28
That is alot more work than its worth. Unless you have access to the really expensive self loading, self changing CNC mills, its pointless to do it on a CNC. Also, the sheet is too thin. The mill would punch through the sheet instead of drilling it.
Car: 2003 F-150
Transmission: 4R70W
And yes, I do know what I'm talking about. I work in a machine shop and see too many people come in and want something done on a CNC that can be done much faster with just hand tools.
I just made a template from poster board paper and took it to my sheetmetal guys on base. Covers everything up just fine and I painted it to match the color of the car. Sure makes it easy to work on back there!!
Car: '82 Z28
I work in one too and have seen the same thing. Spend all day setting something up for 10 minutes of actual cutting time to make a part.
FWIW, I work in a tool & die shop and could have used the CNC wire machines, the Agie+Charmille HSM centers BUT, DIY in my garage with a 15dollar B&D saber saw, my drill press and a bridgeport from work was easier and more rewarding.
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
i dont know... i think it'd be fun to do it on a CNC (i have access to one)
then again, im in a class where im learning the programming and stuff to this is all still very novel...
its not like ive done it a thousand times before. you know.
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
1BADRZ28 how did you get all that seam sealer out of the corners
Hey, just checking the status of your custom ac/heater box delete panel. Are you still gonna make others for sale. Because I'd really like to see pics and get one really soon if you are. I'm just looking for a timeframe if you are gonna make others, bc if its gonna be a while then I'm gonna have to go another route. I already pulled my ac/heater box and need to get it covered now. I've been banking on you making some, but if thats changed please let me know. thanks.
Sorry to not have replied recently. I've been busy between personal and professional lives. I don't plan on making any more at this point and in fact, I've actually decided to sell my car after 9 years. Its in the for sale section for those seriously interested.
I'm sorry to hear that. both for you not making any extra panels, and for your troubles and selling your car. well goodluck with the sale anyways.
well i'd love to see it, but i dont know what a dxf is, nor do i have access to all the tools you had when making yours. I wouldnt be able to mill out the circle for the blower wheel flange/lip.
BlackphantomZ28
08-21-2015 07:12 PM
