Gforce do it yourself crossmember
Car: 1984 z28 H.O.
Engine: 305 H.O.
Axle/Gears: 10 bolt
I was nosing around and ran across this. Seems it might be useful for a t-5 with long tubes situation. Which I have and suck with the stock member. Drag on everything.
http://www.transmissioncenter.net/gf...mbers_.htm#DIY
Anyways thought I'd see what people thought of it.
Car: 92 Firebird
Engine: Supercharged 6.0
Axle/Gears: 8.8 3.73
Re: Gforce do it yourself crossmember
They charge the price of a prefabed powder coated piece and you get a pile of raw steel
Spend $20 and go to a steel supplier
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Just by looking at the pictures I dont think you'd even be able to make a nice crossmember for our cars out of that. The side flanges dont look big enough to hit our bolt holes. And there is so little room between the subframe and trans, you would be cutting most of that up and throwing it away.
Get yourself a piece of 3/16-1/4" angle iron, cut it in half for side pieces, then get some 1x3 rectangular tubing. Cut the bottom piece for the trans mount, then fill in the gaps to suit your needs. Pretty easy if you take your time.
And you'll spend way less in the long run.
J.
J.
Car: 86 Iroc-Z28 Camaro/84 BMW M Power
Engine: 350TPI/ S50
Transmission: t-5 five speed/ 5 speed
Axle/Gears: 3.42 posi/ 3.73LSD
like said before can be done with a few pieces of square box tubing. Not worth the $149.
TinnMann2
Canadian Region
16
06-18-2017 05:10 PM
kammi10
11-09-2015 08:28 PM
tmork454
09-29-2015 06:33 PM
TOMcat GTA
09-15-2015 09:31 AM
body, cross, crossmember, crossmembers, diy, fab, fbody, force, fox, gforce, member, tranny, trans, transmission, worth
