anyone make an adjustable torque arm?
1 Post
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
Ive been thinking of fabing my own and I was wondering if anyone has any experience making one.
Re: anyone make an adjustable torque arm?
I have seen some people fab there own up. If you do a search i'm sure you can find the threads. For like $120 you can just buy one and not go threw the hassle.
Car: 1984 ta slightly modified
Transmission: auto 350 w/reverse valve body
Axle/Gears: 410 ratio
I bought the one from spohn with the adjustable pinion and the front torque arm mount on the trans cross member......... BEST THING I DID FOR TRACTION AND LAUNCH. Kind of pricey but worth it. Jegs and summit sell some that arre mounted to the trans.
Car: Currently have 3 cars and 1 truck.
Engine: 1970&92 Cams,both BBC's
Transmission: LS1 T-56 & PG w/vendor's
Axle/Gears: Built 10 bolt& 9inch w/spool
Yeah, Spohn.com,its worth the money. Plus they give you choices.
Car: 87 GTA
UMI (a TGO sponsor) makes them too..... UMIPerformance.com
I looked at Spohn.net's site.....And you cannot get one for $120, like 84Z28 said. Your looking at $280 & up, from ANY place that makes them.
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
i made my own. i was a good learning experience but a PITA. it works best if you have SFCs and run a crossmember to connect the shackle to.
spohn was around 600 for mine, figured only buying once so go for the one i want
Car: 88 Iroc
Engine: 94 lt1 modded
Transmission: t 56
I plan on building one in the next month or two. Anyone have any suggestions on where to buy the heim joints?
Thanks,
kory
Thanks,
kory
1 Post
Car: 1987 Iroc-z Convertible
here is another rod end to consider.
http://www.summitracing.com/parts/SUM-MAX12/
Car: '88 Camaro (Gone...)
Here's one that customblackbird made:
https://www.thirdgen.org/forums/susp...ml#post4504132
Lots of good info in there, even has links to where he got everything. You're gonna have to fab up your own forward mounting point too though, he reused his jegster tunnel mount piece. There's more than one way of designing that mount though
ambainb
04-25-2016 09:21 PM
