Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
1984 Camaro Drag car build
Old 03-13-2011, 12:52 AM
43longtime's Avatar
Here is the start to my build.
Going to be a 1984 Chevy Camaro Drag car.
The Car going to be a team race car.
Here are the pictures of the car being back halfed:
Here is the rear all cut out with the mock up tires setting in there.
That is all I have done for the rear end of there car waiting for my 4 link from Summit racing.
Started building the engine it is a 350 Small block Bord .060 over.
Didn't take pictures of the camshaft install should have but didn't.
Started installing the pistons here are some pictures. They are Keith Black/KB Pistons KB119-060.
Piston #1
43longtime's Avatar
Re: 1984 Camaro Drag car build
Piston # 2
Piston # 3
Piston # 4
Piston # 5
Piston # 6
Piston # 7
Piston # 8
Top Showing the Crankshaft and rods.
Old 03-13-2011, 01:03 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
why a backhalf when a 28x10.5 stiff and just some creative hammering would MORE than hold whatever that motor could throw at it. Curious to see how it turns out, but a torque arm setup is one of the best suspension setups with a few key parts changed out.
Old 03-13-2011, 02:07 PM
43longtime's Avatar
Why not a backhalf? I want to run some 16 inch tires. Can't put that in stock setup even with hammering. I am going to be building a big block soon as well for it. I like the setup of a 4 link and be able to have the ajustablility.
Chris
Old 03-13-2011, 07:32 PM
Andrew91GT's Avatar
Car: 1990 formula
Engine: 433 sbf + turbos
Transmission: powerglide
Axle/Gears: fab9, 3.50
Chris
You can also get hand me down tires from the pro mod guys that will last forever vs a set of 28's that you have to replace every 10 hits.
I also suspect that you might have to cut out some more of the trans tunnel to get a decent rear ride height.
Old 03-14-2011, 04:12 AM
43longtime's Avatar
That wont work for me because I don't know any pro mod guys. Plus there tires are way to small.
Old 03-14-2011, 08:24 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
I dont think you have enough tire. You might spin.
Seriously though, I look forward to seeing your progress and where this build ends up.
Old 03-14-2011, 08:49 AM
Andrew91GT's Avatar
Car: 1990 formula
33x16 is too small for you?
Old 03-14-2011, 12:55 PM
43longtime's Avatar
No, that is not to small that is the size I want.
I was thinking you where talking about getting tires from circle track people, not sure what I was thinking there.
Old 03-14-2011, 01:08 PM
daturbosix's Avatar
Car: '92 Firebird
Engine: Poncho 455
Transmission: TH400
Axle/Gears: 12bolt
Chris
how much adjustablity do you need with a stock block 350?
doesnt seem like that powertrain warrents a backhalf.
28s only last 10 hits?
Old 03-14-2011, 01:20 PM
43longtime's Avatar
I was not sure what he was talking about. Are tires on the other race car are 28 and they last like 2 seasons or more.
I am building the car to handle what ever size engine I want to put in it. I plan to build a big block for it. I want to just get it running.
Old 03-15-2011, 03:22 AM
43longtime's Avatar
Thats what I keep telling the guy that is helping me build the car.
He don't believe me.
Old 03-16-2011, 11:50 AM
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
Keep with the big tires. BBC's don't like 28x10.5's. Don't forget the rear frame should be .250 wall 2x3 for strength. Are you doing the work outside on cinder blocks?
Old 03-16-2011, 12:41 PM
daturbosix's Avatar
Car: '92 Firebird
Engine: Poncho 455
Transmission: TH400
Axle/Gears: 12bolt
bbc's dont like 28x10s? really.... 28x10s have been in the 5s.
Old 03-16-2011, 01:35 PM
43longtime's Avatar
I ordered A frame rail kit from summit racing
It should be here sometime next week I hope only been waiting for it for like 2 months
Old 03-16-2011, 02:31 PM
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
In Camero's?
Old 03-16-2011, 02:54 PM
daturbosix's Avatar
Car: '92 Firebird
Engine: Poncho 455
Transmission: TH400
Axle/Gears: 12bolt
In Camero's?
first off, its spelled C-A-M-A-R-O.
torque arm suspension is one of best platforms for a drag car. if your having problems a 3rd gen to work, you should seek a professional, or take up knitting.
Old 03-16-2011, 09:44 PM
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
H-L and S. Camero seemed appropriate.
Old 03-16-2011, 11:27 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Just because a tire still has rubber on it doesn't mean it's still good. There are some dedicated racers that will replace their slicks a few times a year because the 60' times start to drop off. Wish I had that kind of budget but I'll run mine as long as possible just like everyone else.
The big tire means you have a better chance of getting traction on lessor prepped tracks even with a lower HP vehicle. It's all about consistency. If you can get traction when everyone else is spinning off the line, you'll probably win the race. Yes there are cars that can go very fast on a small tire but track prep usually needs to be exceptional plus those small tires get heavily pounded from high HP. There's a local mustang that competes in XDR class. A set of tires last about 10 passes before the sidewalls are hammered out of them.
As for the back half, I've seen 13 second cars with a back half. It's a big project to do but once it's done, you can upgrade the rest of the powertrain as your budget allows later on down the road and never have to worry about the rear. Many people seem to start with a high HP engine then wait for the 7.5" time bomb diff to fail before changing to something different. Going right to a 4-link with a better diff allows more options down the road plus you get the better adjustability of the 4-link system.
Old 03-17-2011, 12:03 AM
Andrew91GT's Avatar
Car: 1990 formula
I have been 5.5s on that tire, but that really isn't anything. Fastest ive heard of is Sam vincent sbf nitrous, NMRA sso, he has been high 4.6 low 4.7. He probably gets 5 passes out of a set of slicks.
Old 03-17-2011, 12:10 AM
43longtime's Avatar
That is my thought. Start with the important stuff like the rear end and upgrade as you go along and have the money. I don't know why everyone is against the 4 link system? All that really matters is consistence like you said and the track that I have locally is no where near pro on prepping the dam track. I am modeling you setup after yours, really like what you did plus If im going to do it im going to do it right the first time.
Old 03-20-2011, 02:47 PM
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
most people are afraid of a project like this, and having the back half is good for doing the brackets
however my bracket tires will probably be 29.5x10.5's on my camaro, or maybe a 315 radial, but i don't go to many bad tracks either. and it'll be slow (mid 6's on the spray)
Old 04-24-2011, 04:03 PM
43longtime's Avatar
Update
I worked on installing my 4 link Frame rails yesterday, Let me tell you it was a pain. Trying to figure out where to square everything off was a nightmare.
I started by fabricating some sub frame connectors that went down both sides of the rocker panel from the front of the wheel well to the front of the car and tied into the frame in the front. I looked all over and tryed buying pre-maid sub-frame connectors and the only ones I could find where the ones that went down the middle of the car on both sides of the transmission tunnel. I bought them but have not installed them yet all I have done is the frame tacked in place. It was my first time welding and I would have to say that it is not as easy as you would think. I am going to have my neighbor weld up the whole car once I get everything tacked in place.
Let me know what you think.
Old 04-24-2011, 05:55 PM
dannyboyemt's Avatar
Car: 89 RS,02 WS6 M6,08 GMC Sierra SLE
Engine: ZZ4HCI, LS1, LY5
Transmission: T5/T56/4L60E
Axle/Gears: 323,342,373
Beautiful.
Old 04-25-2011, 08:26 AM
43longtime's Avatar
Originally Posted by dannyboyemt
Beautiful.
Thank you.
Old 04-26-2011, 01:26 PM
daverr's Avatar
43longtime very nice build. I myself was on the fence on whether to back half or mini tub. In the end I went with mini tubs kinda wish i would of backhalf they look so awesome. Build the car first than the powertrain is the correct way of building the car ,like your doing.
Old 04-28-2011, 08:31 PM
43longtime's Avatar
yeah I figure start with the best you can finish with the rest!
Old 05-07-2011, 07:46 AM
Bunnydoom's Avatar
Car: 84 Chevy Camaro (Frankenmaro)
Transmission: TH700R4
Nice build been looking at those frame rails from summit also. Its funny in your pictures how stuff is just randomly in the car, pretty hilarious if a beer can gets left in the frame lol.
Old 05-07-2011, 08:49 AM
43longtime's Avatar
Yeah I get excited and leave it in there like the front seat, I wanted to what is looked like and I don't have any room in my shed to work so I left it in there
Old 09-24-2011, 12:17 PM
lunati397's Avatar
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
any updates on this
Old 09-25-2011, 10:15 PM
43longtime's Avatar
Sorry no updates, I have been so busy working and I just got married and moved to another house. I am planing on working on it over the winter and I will be sure to keep everyone updates.
Old 09-26-2011, 04:43 AM
lunati397's Avatar
I might look to doing something simular because the motor Im putting in now will have alot of tq around 1000 now and 1500 within a few years
Old 09-28-2011, 05:56 PM
z28scott's Avatar
i have already done this,used the comp eng rear kit with ladders,motor is a 14 to one bbc,big heads big cam,dyno @710,9 inch out of a 65 galaxy,getting ready to install tubs,sheetmetal,I can tell you this,it's ALOT of work(and cash)MEASURE EVERYTHING,WRITE IT DOWN,DO NOT BURN ANY WELDS TILL YOU ARE 110%SURE
Terrell351
06-13-2021 01:13 PM
colton_carlson
03-08-2019 12:21 PM
84z96L31vortec
08-20-2017 12:16 AM
Exxon Limited
Camaros Wanted
22
12-21-2015 10:36 PM
84z96L31vortec
08-10-2015 08:27 PM
Quick Reply: 1984 Camaro Drag car build
