HIDDEN - Over flow and washer tanks - Built on the cheap!
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Iv been procrastinating on fabricating a set tanks... so i decided to try and make some out of PVC...
Materials
Test fitting tubes
Brackets
Materials
Test fitting tubes
Brackets
Re: HIDDEN Over flow and washer fluid tanks - Built on the cheap!
Drilled and tapped and fittings installed tubes got painted.
These tanks can hold over a quart of fluid.
Installed, I used some single side foam adhesive strips where the tubes might come in contact with surrounding metal. zip tied in place they don't move at all.
Needless to say these are now my new tanks...
As far as the the top plastic cover goes i already got that figured all post about that later on
Re: HIDDEN - Over flow and washer tanks - Built on the cheap!
Thanks. Stock pump.
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
not in love with the zip ties, but other than that, it actually looks pretty good.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I always like seeing someone fabricate something useful out of commonly available items. I assume the screw top lid is how you fill it. How hard is it going to be to access when it needs to be filled?
A couple of hose clamps would be a better job of securing it than plastic ties.
Me either but they will do for now. I was planing on getting some hose clamps but no one had large clamps.
Yea there both screw top lids. As far as filling go's its going to be super easy and simple and all post later on about the plastic cover.
Hose camps would be cleaner and stronger but seems the ties work just fine all probably add clamps later on.
I hear everyone on the clamps, That was my original idea. Thanks
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
Been a while since i have seen that filler pannel in a car. Always amazed me these cars don't over heat with that pannel right in front of the rad.
Mine has been gone for so long now. Interesting. Might need to copy you on the coolant side. Great idea.
At first all white, I hated it. All black, love it.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Looks good. Alot of folks think there needs to be something special, or a certain size for overflow, which is not the case. I've seen plenty of folks use their fav 16oz beer can as an overflow with simply running the tube into the top - as long as the tube stays at the bottom, the suction that occurs with cooling fluid will still occur.
I swapped to carb, and thus removed my evap canister. Thus I grabbed a brand new Ford Explorer overflow/washer fluid tank for $30 and installed. It's almost exact dimensions of the battery, and serves both needs in one reactangular unit that is symmetrical with battery on the other side. I just spliced my washer pump wires into the ford washer pump pigtails, and rerouted my overflow hose under the plastic cover to the pass side. You can see part of it here:
Thanks for the complements so far guys.
yes.
This happened to cross my mind when i was painting these out back. Just wait till some noisy *** neighbor sees these...
Car: 1989 Trans am GTA
i have been trying to track down a non cracked overflow tank for months...
the search ends. thanks for sharing this!
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Where/How did you hook up a windshield washer squirter motor? Looking through the thread, I saw no pics or mention of it.
Mine is mounted on the bottom edge, kinda "plugged into" the washer tank, so I don't see a way it could be used on a PVC pipe.
1 Post
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
IIRC, lots of thirdgens (maybe just the older ones?) have the squirter pump on the wiper motor.
Not worried about it.
Car: GTA
How it that simple? The stock pump piece is black plastic & your circling a brass 90 degree fitting.
I've always thought this would be a good container for that sticky traction stuff at the track. Run the outlet hose to a T-fitting & aim each hose output towards each rear tire. Or just water/bleach for burn outs!
Car: GTA
I noticed in my pics (look in the lower right) last night, that my daughters 89 RS has the same style pump. So it couldn't be "older ones" as an issue, since hers is newer than mine is.
As far as sticky traction and other chemicals go i have no clue if the pump will work or last but there cheap so its worth a shot to test, which reminds me i have heard about some 60s cars that had bleach bottles and a push button on the dash to spray the rear tires for better smoke during burn outs im not sure if that was aftermarket, factory or a deal option i never cared to research it.
GM has put to many different style whipper motors / washer systems in these cars
I think it is the older ones that have the pump on the wiper motor
According to my camaro part and Illustration book 84 - 87 have the washer pump attached to the whipper motor.
Car: 1991 Camaro Z28
Engine: 5.0 LB9 TPI
Axle/Gears: 2.73 posi drum
Just to ask, are they mounted to that black cover over the rad?
Yea, i showed how they are mounted on the last pic on the first post
Engine: 5.0 LB9 TPI
So if we dont have a plastic cover where would we mount it?
Engine: 5.0 LB9 TPI
Im not understanding, i thought its a black cover and behind it is the rad. Am i wrong?
Good idea and execution. Later.
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: 700-R4
wondering about using PVC for overflow tank on a daily driver... i doubt the PVC would withstand the heat for a decent amount of time. correct me if i'm wrong.
You'll be fine!
Car: 1992 RS
Engine: ZZ4
Great job man, love the clean engine bay look. Been trying to find new factory overflow and washer tanks, after this maybe ill just do away with them and do something custom.
#42
Thanks!
#44
you'll never see the brackets anyway.
#45
Car: 91 Camaro RS
Engine: TBI
Those look real good and on the cheap even better
I built a rectangular one for a friends 91 stang with a big block, the aluminum was free compliments of works scrap bins but after all the an fittings and filler neck and what not he was into it almost 90 bucks
#46
Car: 1991 Chevy Camaro RS w/t-tops
Engine: BBC 396 .090 over (414)
Transmission: LS1 T-56
Axle/Gears: Shortened Ford 9, 3.25, discs, posi
Just curious, what size are those pipes? Do you remeber the approximate total cost?
#47
They are 4". I can't recall but around 20 or 30 bucks.
#48
For the top cover i am thinking of adding push clips but just for aesthetics they wont do anything since they will be cut on the back side and plastic welded on, then im thinking of using velcro to keep it planted easy to take off if i need to access or add fluid...
#49
Car: 1988 iroc-z
Engine: building a 360 now almost done
Transmission: 700r4 w ratchet shifter
its funny, cuz i got bored and tryed this out. failed. got mad and toss the idea away. good work its a great idea tho if you dont got a head full of peanuts( like me).
#50
What didn't work out for you?
