Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Viper Powered 85 Z28
Old 01-12-2012, 02:14 PM
  #51
mac86's Avatar
Car: 1987 Camaro Z28
Engine: Carbed 355
Transmission: Borg Warner T56
Axle/Gears: 4th gen 10 bolt 3:73 Richmond gears
Re: Viper Powered 85 Z28
that pic is the one on this thread
Old 01-12-2012, 02:18 PM
  #52
Sick92's Avatar
Car: 92 Camaro RS
Engine: 350 LT1
Axle/Gears: 4.10
Holy ****.
AT least the viper is a respectable car. If you said a nissan gtr, now I might've been hatin. LoL
Old 01-12-2012, 05:24 PM
  #53
Slayerx666's Avatar
I'm in, sounds like an awesome build. Idk I'd I'm alone on this, but I HATE the way most v10s sound. Hopefully yours will sound good.
Old 01-12-2012, 08:16 PM
  #54
Cray z28's Avatar
Car: 1985 Z28
Engine: 8.3 ltre viper
Transmission: Tremec T6060
I did some research on the sound. I too didn't like. I found one post on a viper forum that stated it was because there is no x-pipe. I plan on trying a bunch of options until I get the growl I'm looking for. I want people to look and say hey that sounds different but, I just can't place it. I wanted the Gen4 v-10 but, now I am thinking of the Gen2 because I can get the motor and trans with 500hp for 6k. The gen four is a badder 600hp but the combo is 14-16k. 10k difference gives a lot more mod money.
Old 01-12-2012, 08:28 PM
  #55
Slayerx666's Avatar
That's true, usually just side pipes or whatever. I used to work next to a viper performance shop. They had a 1500hp viper, that almost sounded good. But I'm assuming those cars are just side pipes with no type of crossover.
Old 01-12-2012, 09:39 PM
  #56
Cray z28's Avatar
Car: 1985 Z28
When the time comes I am going to call Borla and see what they suggest for a more throaty growl. Found a mock-up viper block for $450.00. That is going to give me the time to fab everything and save for the final purchase. Also n a sick note.... I found a Rod shop that is currently putting a Viper v-10 in a Volkswagen Karmann Ghia.
Old 01-13-2012, 12:31 AM
  #57
Seven_MPG's Avatar
Car: 1985 Z28
Engine: '69 350 4 Bolt Main .30 Over
Transmission: 700r4/B&M Shift Kit and Flywheel
Axle/Gears: GM 10 Bolt 3.23 Gears
Subscribed..I want to see this complete.
Old 01-13-2012, 01:37 AM
  #58
Carlos773's Avatar
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
I support this more than the Ecotec swap thread.
Old 01-13-2012, 01:38 AM
  #59
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Do you already have the motor. And I would think one would have to be half way wealthy to pull ofvthia swap.
Old 01-13-2012, 09:12 AM
  #60
Cray z28's Avatar
Car: 1985 Z28
I do not have the motor yet. I am going to do the build in the beginning with a mock block from http://www.payr.com/index.htm. Well I am going to dedicate $500/week to the build. Thats the plan anyway.
Old 01-13-2012, 10:02 AM
  #61
Andrew91GT's Avatar
Car: 1990 formula
Engine: 433 sbf + turbos
Transmission: powerglide
Axle/Gears: fab9, 3.50
$2000/month is about what I spent when I built my outlaw car... a year or two and you'll be there. Good luck!
Old 01-13-2012, 02:37 PM
  #62
gscz28's Avatar
Car: 89 iroc
Engine: 355 TPI FINALLY
Transmission: 700r4/ SHIFT KIT
gotta see this through.....this will be great...good luck
Old 01-18-2012, 01:53 PM
  #63
KhaosTactic's Avatar
Car: 1985 Black z28 T-top, 09 eclipse
Engine: Carb'd 305 soon to be a 400 sc
Transmission: 700r4 to T5 swap
I'm on board, good luck!
Old 01-19-2012, 11:05 AM
  #64
Cray z28's Avatar
Car: 1985 Z28
I did some more tear down this week. I also ordered the mock-up block. Hopefully it will be here next week so I can start the front suspension.
Old 01-19-2012, 11:55 AM
  #65
h1-vltg's Avatar
Car: 91 Camaro Z28
Engine: LS3
Transmission: 6 Speed
Axle/Gears: 3.71
Subscribed....sounds awesome!!! Cant wait to see progress pics!
Old 01-19-2012, 12:28 PM
  #66
GreenCamaro13's Avatar
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
Axle/Gears: 5 Speed Manual
Subscribed And Wanna See this!! YEA!!!!!
Old 01-19-2012, 04:42 PM
  #67
james94's Avatar
Car: 1990 IROC
Engine: Tree Fiddy
V10s can sound pretty good. Im looking at dropping one in a 70 challenger and have been looking for sound clips online. I havent found a good sounding viper, but the srt10 rams with the same viper v10s can sound nasty. http://www.youtube.com/watch?v=gwK4txj3xks
Old 01-19-2012, 06:02 PM
  #68
Cray z28's Avatar
Car: 1985 Z28
There is a viper powered 70 ish Challenger on you tube that goes against a Ferrari Enzo.
It's a beast!
Old 01-20-2012, 04:26 PM
  #69
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
20 to 1 this project is never completed
Old 01-20-2012, 04:55 PM
  #70
tjl IROC's Avatar
Car: too many
Engine: SBC
Transmission: AUTOs and a 5 speed :D
Axle/Gears: you name it
"20 to 1 this project is never completed"
we can hope (it is like believing in Santa)
Old 01-20-2012, 05:10 PM
  #71
89_RS's Avatar
Car: 2003 F-150
Engine: 4.6L Modular V8
Transmission: 4R70W
Axle/Gears: Ford 8.8"/3.55 LSD
Originally Posted by SDTransAM
Almost like this more than a LSx swap. But that viper engine is REALLY long. You sure it will even fit? It's tight with an LS engine.
I don't think length will be an issue. Someone swapped an Aston Martin Vanquish V12 into a Mustang and it fit:
http://www.autoguide.com/auto-news/2...-for-sale.html
Old 01-21-2012, 07:24 AM
  #72
james94's Avatar
Car: 1990 IROC
Engine: Tree Fiddy
It all should fit in, but the shifter for the tranny may be a little to far back to shift comfortably, so you may have to have an extended and angled shift ****, not too sure though. And if you do need it, its not really a big deal.
Old 01-21-2012, 12:55 PM
  #73
L695speed's Avatar
Car: '88 Trans Am GTA; '84 Trans Am
Engine: L98 350TPI; 5.3 LSx built
Transmission: N/A; T56
Axle/Gears: 3.70 9 bolt; 3.73 10 bolt
That didn't stop Shelby, he just had the shifter reversed in his cobras. Do the same for this. Have the shifter bent forward from a point further back, and there you go.
Old 01-21-2012, 04:11 PM
  #74
hdis2002's Avatar
Car: 87 IROC Z
Engine: 5.7
Subscribed. Looking forward to this one.
Old 01-21-2012, 04:21 PM
  #75
james94's Avatar
Car: 1990 IROC
Engine: Tree Fiddy
Thats what I was thinking about.
Old 01-21-2012, 06:15 PM
  #76
Cray z28's Avatar
Car: 1985 Z28
I'll Take your 20-1 odds. I will complete this. It wont be in a couple of months but it will be completed!
Old 01-21-2012, 10:50 PM
  #77
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
dude, your NUTS!!
its probably going to be a tight fit, good luck
if/when you get it done, you should get a few of the old Pentastars and put on the car, 1 in the traditional Mopar location, and then 1 next to each of the factory Z28 emblems.
Old 01-21-2012, 11:00 PM
  #78
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Originally Posted by DENN_SHAH
...next to each of the factory Z28 emblems.
Zpentastar28 emblem? Except that the Viper is a Dodge, "not" a Chrysler, like the Camaro is a Chevrolet, not a GM
Dodge has the double stripes, the 1st gen Z28 was Z/28. Make some Z//28 emblems.
Old 01-21-2012, 11:49 PM
  #79
DENN_SHAH's Avatar
all Mopars used to display the Pentastar on the lower back part of the right front fender.
but i think displaying it just on the lower right fender would be too subtle, so i feel something like 1 of these this would work.
Attached Thumbnails Viper Powered 85 Z28-dodge_red_pentastar1.jpeg   Viper Powered 85 Z28-z28pent.jpeg
Old 01-21-2012, 11:56 PM
  #80
Car: GTA
Old 01-22-2012, 12:05 AM
  #81
DENN_SHAH's Avatar
yeah, that would work
edit, i just thought of something, "they" may say using the Pentastar like that on a GM is copyright infringement
Old 01-22-2012, 09:24 AM
  #82
james94's Avatar
Car: 1990 IROC
Engine: Tree Fiddy
Put a viper head instead of the pentastar, that would be badass
Old 01-22-2012, 04:26 PM
  #83
Cray z28's Avatar
Car: 1985 Z28
I drew up viper logo with the z/28 between it's teeth. I am going to have it machined by a friends machine shop.
Old 01-22-2012, 05:50 PM
  #84
james94's Avatar
Car: 1990 IROC
Engine: Tree Fiddy
Cant wait to see it!
Old 01-23-2012, 06:58 PM
  #85
Cray z28's Avatar
Car: 1985 Z28
Here is the rough logo before CAD.
Old 01-23-2012, 07:44 PM
  #86
86_irocz-28's Avatar
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
That is awesome!!!
  #87
Slayerx666's Avatar
I like that logo.
Old 01-23-2012, 07:52 PM
  #88
mh82camaro's Avatar
Car: 82 camaro berlinetta (z28clone)
Engine: gmpp 350,edelbrock,msd,k&n
Transmission: stage 2 maddog 700r4
Axle/Gears: motive gear 4.10/ eaton posi
i like it also....looks venomous!!!
Old 01-24-2012, 12:10 AM
  #89
DENN_SHAH's Avatar
that does look good
Old 01-24-2012, 01:42 AM
  #90
C-Titan's Avatar
Car: 91 Z-28
Engine: 360TPI
Transmission: PA Racing 700r4
Axle/Gears: 3:73
Someone did a successful swap into a mustang svt cobra a few years ago, side exhaust and all... came out completely ****, executed perfectly - cleanest stang on the planet and the only one I don't think is complete garbage...
Old 01-24-2012, 05:23 PM
  #91
Cray z28's Avatar
Car: 1985 Z28
Well if any of you guys are looking for some original 85 equipment, I have all of it. I am only keeping the T-Tops, Hatch, and Body. Everything else is for sale.
Old 01-26-2012, 03:58 PM
  #92
Cray z28's Avatar
Car: 1985 Z28
Off to get the rear frame damage pulled out. He is backed up so probably 2 weeks. SO I will start ordering parts.
Old 01-27-2012, 05:24 AM
  #93
shone190's Avatar
Great project, I can't wait to see, also because I have one "similar" project with my GTA too
Engine is already here
Old 01-27-2012, 07:52 AM
  #94
Cray z28's Avatar
Car: 1985 Z28
That is awesome. Do you have any picks of your viper project?
Old 01-27-2012, 08:12 AM
  #95
shone190's Avatar
No I don't, I accidentally bought this engine a few days ago for 1000€ , so first I need to see how to purchase transmission, engine harness and ECU.
Old 01-27-2012, 08:36 AM
  #96
dlambunion's Avatar
Car: 1990 firebird formula 5.0
Engine: 305 tbi
Axle/Gears: 2:73
subscribed... cant wait to see it start coming together!!
Old 01-27-2012, 08:53 AM
  #97
patricklav's Avatar
Car: 92 Camaro Z
Transmission: Built TH350 with 3200 stall
Axle/Gears: 4th gen, 4.10
Great idea! Good luck with this.
Old 01-27-2012, 08:54 AM
  #98
james94's Avatar
Car: 1990 IROC
Engine: Tree Fiddy
Shone, is that a gen1 or gen2 8.0?
Old 01-27-2012, 08:58 AM
  #99
shone190's Avatar
First gen, 8.0
Old 01-27-2012, 09:29 AM
  #100
james94's Avatar
Car: 1990 IROC
Engine: Tree Fiddy
Make sure you have a build thread on your project too!
Quick Reply: Viper Powered 85 Z28
