Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Fender Flares on a third gen
Old 06-13-2013, 08:00 PM
  #51
Twin_Turbo's Avatar
Re: Fender Flares on a third gen
86blackiroc (11-21-2022)
Old 06-15-2013, 07:28 PM
  #52
mac86's Avatar
Car: 1987 Camaro Z28
Engine: Carbed 355
Transmission: Borg Warner T56
Axle/Gears: 4th gen 10 bolt 3:73 Richmond gears
this honestly looks awesome.
Dirtydrifter420 (09-26-2019)
Old 06-15-2013, 10:10 PM
  #53
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
I'd drive it.
Old 06-16-2013, 07:32 AM
  #54
freaky's Avatar
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
i like it
Old 06-16-2013, 10:11 AM
  #55
RockJay81's Avatar
Car: 84 Z28......99 TA
Engine: Lq9 6.0... Ls1
Transmission: 4L60E X's 2
Axle/Gears: 3.73 on both
I'd drive it off a cLiff
Old 06-16-2013, 03:14 PM
  #56
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Me too. Every fenderflare in this topic is hideous.
Old 06-16-2013, 05:36 PM
  #57
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
the stock fender flares are hideous? Why are you even on this website?
Old 06-16-2013, 11:03 PM
  #58
T/Aperformance's Avatar
Car: 1987 Trans Am
Engine: 355 tpi
Transmission: 5 speed
Nice opinion you have there. And thank you for the insult.
Do you even understand what it take to make customs fender flares, I don't think you do. You can't just order these and stick them on. I've got over 100 hours in mine so far and many more to go,
Old 06-16-2013, 11:19 PM
  #59
86_irocz-28's Avatar
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Yours is awesome love the spoiler and pop up deletes
Old 06-17-2013, 05:02 AM
  #60
Twin_Turbo's Avatar
Just ignore the narrow minded, no vision..no taste.
Old 06-17-2013, 06:28 PM
  #61
Car: 1987 Trans Am
Engine: 355 tpi
Thank you, Its a lot of work and a long way until it's done. I won't do a build thread until I'm finished or close to it, But I keep everything documented and lots of pics.
Twin_Turbo, I'm not to worried about what that person thinks, They have there right to there own opinion, And you know what they say about them. It was how they stated it making them look like an opinion.
Old 06-17-2013, 06:38 PM
  #62
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
When do you think itll be done would love to see more pics
Old 06-17-2013, 06:47 PM
  #63
Street Lethal's Avatar
I'm actually liking the rear flares off of that Camaro a few posts up, insomuch that I photo-shopped it on my GTA, then I brought the TT2 rim out to meet it. I'm freaking liking it a lot...
Old 06-17-2013, 09:19 PM
  #64
BlackTopKing's Avatar
Car: 1987 Trans Am GTA
Axle/Gears: Posi 3:42
If it help at all, im doing a widebody build thread with flares, 4"over on rear and 2"over on fronts. Check last past for last weeks update, should be in primer week or so.
Just a thought for the builtnotbought crowd.
Old 06-18-2013, 12:44 AM
  #65
Car: 1987 Trans Am
Engine: 355 tpi
I'm unsure when I'll be finished with this project, I just have so many other projects like 2 motor homes both big block chevys getting fuel injection and turbos, I have a sail boat and a ski boat to work on, just finished putting a motor in the ski boat, and all those are for one customer, well one motor home is mine, and what I am using to design everything for my customer, since they are the same exact vintage RV, So my Trans Am is last on the list of things to get done, but I did just buy a new roll of fiberglass so I'll be doing some more work on the TA, I'm not happy with how my hood turned out last time so I'll be making a new one, A little thicker this time and hopefully the ZL1 cowl will be right this time,
Old 06-18-2013, 12:47 AM
  #66
Car: 1987 Trans Am
Engine: 355 tpi
That looks great on your car and you can fit some really wide tires under there, And with what you're doing with your car I'm sure you could use them.
Old 06-18-2013, 12:48 AM
  #67
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
looked good from the pics
Old 06-18-2013, 01:03 AM
  #68
Car: 1987 Trans Am
Engine: 355 tpi
Ye but the pics don't really show the front of the cowl at its widest point and how as you look up the cowl towards the windshield it goes in an 8th of an inch on each side, This was caused by the hood being curved as firebirds hoods are, So I'm going to modify this one for a plug, then make a new mold. and then a new hood.
It has to be right for what I plan on doing for the paint and simple grafixs.
Old 06-18-2013, 01:08 AM
  #69
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Should turn out pretty nice!
Old 06-18-2013, 09:29 AM
  #70
COTM Editor
BADNBLK's Avatar
I have emailed that used car place about 3 times trying to get info about this car and if there is wiggle room on the price.
I like what you guys are doing in here. Keep the ideas bouncing and trial and error until you get it right. Haters keep hating. Its just motivation for an even better end result.
Old 06-18-2013, 10:28 AM
  #71
Coprice 9C1's Avatar
So, nobody has brought up wheel sizes yet. If a guy wanted to run a 15" wheel.... Rears 10-12" wide? 4-5" BS? Fronts 10" wide with a standard 4" BS? Probably have to do some sort of spacer to get it perfect once the flare was built.
I'm only guessing. It's been several years since I researched widths, BS and tire sizes to stuff some tires under my Caprice.
Old 06-18-2013, 12:15 PM
  #72
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
The 15x8s rears should have around a 4.5" backspacing stock.
15x10 on rears will fit with 5.5" back spacing. Yes, they come close to the fender but do not touch with the correct tire.
15x10 with 6.5" backspacing will fit also if you shave the bump stop, trim some metal, and tap the front edge of the fender well with a hammer.
Depending on the rear fender flares you might get away with a 15x12 with 5.5" or 6.5" back spacing. At that point your backspacing wouldn't change you'd just be increasing the rim width to bring it as close as you could to the outside.
I think there would be a point that looking cool would become looking like a car with messed up backspacing trying to use flares to be legal.
Old 06-18-2013, 01:05 PM
  #73
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Honestly, if you are going to flare the fenders, don't even waste an ounce of time on the 15" wheels - they are extremely limited in both tire patterns and also brake clearance.
If you are serious, step right into the 18" wheel club - a stock 3rd gen can run 295-35-18 tires on 10.5" wide wheels without any problems. Add 2" of flare allows a 12.5" wheel and a 335 width tire. 335 on all 4 corners with the right suspension is a world beater...
Old 06-18-2013, 02:02 PM
  #74
mac86's Avatar
Engine: Carbed 355
im doing 18x12 rims on all four corners. Weld RTS High Pad Rims.
Old 06-18-2013, 02:06 PM
  #75
mac86's Avatar
Engine: Carbed 355
im toying with the idea of no bolt on, just bond the fiberglass to the metal. i dont know yet.
Old 06-18-2013, 02:07 PM
  #76
paul_huryk's Avatar
Now that sounds like a great plan!
Old 06-19-2013, 12:06 AM
  #77
Car: 1987 Trans Am
Engine: 355 tpi
I don't know about 15" wheels But I'm running !7"x11' with 7.5 inch back spacing, Corvette wheels , Front spacer are 2" tires are 285 40s, Rears I'm using 2.5 spacers tires are 335s My flares are only an inch and a half wider in front than stock and an inch and three quarters wider than stock, Not much I know but they are designed to fit my wheels and tire combo and not be to big, They are also deigned to make the wheel well look smaller and fit closer to the tire.
Old 06-19-2013, 12:11 AM
  #78
Car: 1987 Trans Am
Engine: 355 tpi
I made mine to be a bolt on and bonded on to the fenders, For them to last a long time with out cracking you really need to do both.
Old 07-03-2013, 02:42 PM
  #79
mac86's Avatar
Engine: Carbed 355
okay, i have decided i am most likely going to drop the custom fabbed fender flares. tires would cost a fortune, and so do the rims. i am going to get some custom fiberglass fender skins that extend the wheel wells out 1.5 inches. since i can already fit 9.5 inch rims all around without any modification,,,or so i have heard, i am going to get 4 deep dish corvette zr1 wheels. hyper silver. 17x11. i just dont know what spacers to run though. is there a way i can measure what spacer size i need?
Old 07-03-2013, 10:14 PM
  #80
Car: 1987 Trans Am
Engine: 355 tpi
Well most of the corvette ZR1 wheels like the ones I have on my rear in my pics only need a 2.00 to 2.50 inch spacers, I'm unsure which Wheels your thinking of, The wheels like mine even with the deep dish are only a 2 inch lip but the back spacing is the same,
I'm sure you have checked the wheel and tire section but there are plenty of post about this size wheels and back spacing.
Old 07-03-2013, 11:07 PM
  #81
RockJay81's Avatar
My brains hurts with this thread.
Old 09-10-2013, 08:26 PM
  #82
r c
r c's Avatar
came across this picture online a while ago ....
Attached Thumbnails Fender Flares on a third gen-544782_10201666721818911_1597461138_n.jpg
Old 09-10-2013, 08:54 PM
  #83
Size:  83.3 KB[/URLName:  60FDBD0B-orig_zps20fc298a.jpg
Size:  106.9 KBURL=http://s1223.photobucket.com/user/BLackTopInk/media/IMG_61240774574827_zps28e682ed.jpeg.html]Name:  IMG_61240774574827_zps28e682ed.jpeg
Well I had to share, think I posted couple months ago I was in mist of doing something like the fender flair/wide body. I have a pretty detail thread for those who are interested, but I have 2" up front, nose is about 2" total but not much to mention. Rear is 4" over total, 2" in quaters withba 2"flair at too apex, 3.5" on aprons making a 2" total at taillights and rear bumper.
Last two pics are after 4tg gean rear swap (should be noted) as the others are prior.
After swap I don't have much to kill, and am looking for rims now, key is offset, corvette rims seemed like best bet at first, but after really looking and tryn a few on, there are maybe one or two stock sets I even consider. Two reasons, one...there are flat face rims and actually kills the wide look plus your not really getting out of the stock lip area, just wider tread under car.
Two....cost, might as well grab a set of MMT (I think there called,) aftermarket corvette rims and still, not out of the well...by much, the rear helps big time but still not enough for what your adding (if you rearlly add width to car and not reshape the fender/quarters to look flaired)
But old school welds or craigs, now....have offset, which get out from under car and the lip....ampifies the appearance of depth.....it'll look deep n wider, plus you can still get in 10" width which kills the rear, skinny jean look....
Unless you wanna spend the money for CCW rims....ahhhhhhhh....sexy....but they are worth more then my whole car and if I had that budget, I'd....probably do it...,
So, trick is wider =; offset....
Old 09-10-2013, 09:16 PM
  #84
rarebmx's Avatar
Car: 89 IROC/89 Vert/87 Vert/89 GTA Vert
Engine: 5.7/5.0/5.0/5.7
Axle/Gears: 9" 2.77/9" 3:23/9" 3:42
More research on IMSA style flares
Old 09-10-2013, 09:31 PM
  #85
rarebmx's Avatar
I'm going to research this a little more in person.
Old 09-30-2013, 08:47 PM
  #86
jaybdaboat's Avatar
Car: 1987 Sports coupe/z28
Engine: 2.8/ swapping 5.3
Axle/Gears: Open 3.42
If the op isn't done yet, maybe try vents in the fenders like the new c7's. Make it a little more aerodynamic.
Old 10-07-2013, 03:47 PM
  #87
scarbucket's Avatar
Car: 1987 Firebird Formula
Engine: 305 Tpi
Transmission: Borg Warner 5 spd
Axle/Gears: 3:73
might have to roll wheel wells and make those myself hmm thanks for the idea!
Old 10-07-2013, 06:39 PM
  #88
What OP?!
Old 10-07-2013, 11:28 PM
  #89
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Originally Posted by Twin_Turbo
You guys do know that GM offered flares on firebirds shipped to japan right? I have never seen the camaro type. The firebird ones are a little like Corvette Grand Sport flares and IMO pretty hideous but would make a nice starting pont
I would LOVE to get my hands on a set of these. The biggest downside to these is availability. As in, I've never seen a set for sale. You've found lots of weird stuff, have you seen them for sale?
Old 12-23-2013, 03:14 PM
  #90
surajchem's Avatar
Car: 1989 Firebird
Engine: 5.0L V8
Axle/Gears: Posi-Trac, 3.08 gear ratio
i found something similar but may work and is cheap!
http://www.ebay.com/itm/CARBON-FENDER-FLARES-WHEEL-LIP-BODY-KITS-FOR-UNIVERSAL-CAR-TRUCK-550x60mm-/121173413958?pt=Motors_Car_Truck_Parts_Accessories&hash=item1c367f9046
Old 12-23-2013, 03:32 PM
  #91
92g92's Avatar
Car: 1992 Camaro Z28
If it takes me 100+ hours to take a ****, that doesn't make it pretty. Fender flares and side pipes are the two things on the list of "Cool Car Aesthetics that Don't Belong on a Thirdgen". They are just ugly. Don't want to flame anyone, it's your car do with it what you wish, but if someone posted up "How to make 22's fit on a thirdgen", you know darn well we'd have 90% of this site telling them how disgusting and stupid it would be on a thirdgen, not to mention tasteless. Same thing here.
Old 12-23-2013, 04:54 PM
  #92
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
Iansane I wouldn't do anything to your car it looks great just the way it is
Old 12-23-2013, 05:05 PM
  #93
Joe Tag's Avatar
Old 12-23-2013, 09:26 PM
  #94
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
1986BANDIT (09-10-2019)
Old 12-24-2013, 04:15 AM
  #95
scarbucket's Avatar
Engine: 305 Tpi
Axle/Gears: 3:73
I really like to stick in the ones you found I might have to order myself a set and uses a base for my fiberglass when I do my fender flares thanks guys
Old 12-24-2013, 06:29 AM
  #96
Dakota W.'s Avatar
Originally Posted by InfernalVortex
Fiberglass fenders?
Old 12-25-2013, 08:04 AM
  #97
scarbucket's Avatar
Engine: 305 Tpi
Axle/Gears: 3:73
No fiber glass fender flares like the wide body kits they do on some of the dub cars not fiberglass fenders
Old 12-26-2013, 05:14 PM
  #98
Car: 1992 Camaro RS
Originally Posted by Dakota W.
Fiberglass fenders?
I have no idea, something that got posted up on facebook a while back. Someone found it on craigslist.
If you want a little more info, you might find some useful stuff here.
http://www.lateral-g.net/forums/showthread.php4?t=23997
This particular post is pretty useful:
http://www.lateral-g.net/forums/show...&postcount=273
And here are some pictures of his flares...
Old 12-26-2013, 09:38 PM
  #99
scarbucket's Avatar
Engine: 305 Tpi
Axle/Gears: 3:73
Exactly how I'm doing my flairs is there
Old 12-29-2013, 10:23 PM
  #100
Car: 1987 Trans Am
Engine: 355 tpi
WOW a newbe comes on here and and is bad mouthing other peoples car. Who are you to say what belongs on third gen or not. There are people that like the look and even think its cool. If no one did than this thread wouldn't keep coming back to life, And people would quit sending me private messages asking me advice about mine and if I still have my molds to make them some. Now the people that like them are here to learn and talk about them.
Now it's OK if you don't like fender flares but that is all you would need to say if anything, So are you here just to bash peoples ideas and cars or are you going to contribute in a positive, helpful and creative way?
Quick Reply: Fender Flares on a third gen
