Custom cold air intake idea. need opinions please
Car: Black 1991 Pontiac Trans Am GTA
Engine: 350 5.7L V8
Transmission: Monster Trans 700r4
So I have a 91 GTA and I'm debating on removing the front fog lights and blinkers from the bottom of the bumper. After that I would use some sort of tubing and send the air from both sides through their own air filters and then straight to the throttle body. Is this a decent idea and what, if there are any, problems could this cause, I don't want to do this without opinions incase I'm overlooking any future problems. Im thankful for any feedback
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: Custom cold air intake idea. need opinions please
Where/how would you relocate the lights? I've been thinking of that but not for a street car.
Engine: 350 5.7L V8
Im more worried about getting my blinkers back, im not too worried about my fog lights. I don't want to do anything crazy but maybe get blikers to install into my mirrors and I haven't driven it in a while so I don't remember but if they don't already, id get my fog lights wired as blinkers too. I know its not the best solution but theres no place id want to try to stick any lights. If it became a problem there may be a way to even mount them at the bottom of the bumper while trying not to make it look too bad
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
There's no point in going through all of that for a cold air intake. You'll only get a 2% increase in power.
Engine: 350 5.7L V8
Engine: 350 5.7L V8
I'm sure the only increase he saw was throttle response. That's not a cold air, and being that close to the radiator isn't going to make it any colder either. All you really get with a ram or cold air intake is more throttle response, so it feels like more power, but in all reality it's about 3 more hp.
Engine: 350 5.7L V8
Car: 89 Formula
It would be a lot more efective if you mounted a 1" or 2" high by 10" wide scoop just under the front bumper on each side or a wider on one side and directed the air flow up to the airboxes.
I did this a while back (in '97) on my 87 TA. I used some hvac ducting from Home Deeps, some 7" flexible tubing and cut a hole in the side of the air box and mounted hvac ducting to it. Keeps fog lights in position and water intrusion is not a problem because of oil on K&Ns.
Or do what lb9 did and use metal ducting and custom make an air box using the camaro flat filters instead of a round or cone.
Where there's a will there's a way.
The stock piping is restrictive. Using bigger pipes allows the engine to actually get to the air it needs. Whether that air is warm or cold doesn't really matter, just as long as you aren't getting your air from a 200* source.
Engine: 4++,350 & 305 CIs
SLP used to make CAI kits for your car. They used the stock plastic tube to a nice OEM looking plastic box that bolts to the PASS side of the engine compartment and contained a K&N filter.
They also offered a dual cold air kit that was used on the 92 Hawks. It has 2 plastic air boxes and required the batt 2 b moved to the rear.
Here is my old beater 89 with the SLP cold air box and custom 4" aluminum tubing I'm building.
Engine: 350 5.7L V8
They come up for sale used from time to time. I'll keep my eyes open for ya.
Car: 86 Camaro
Engine: 350 LT1
Id try to fab one up yourself Anthony. Its hard to see in that picture but all it looks like is a simple box.
Posted from Thirdgen.org App for Android
Car: 1985 firebird
Engine: 360"sbc NA pump gas
Transmission: Th350 manual valve body
Axle/Gears: Moser 12 bolt 4.11:1
If you cut a hole big enough for the intake tube to pass through the battery tray and put a filter on the other side/bottom of the tray, you wouldn't need any box. And I can guarantee you that box setup will still absorb some heat from the engine bay.
The SLP box is a OEM type plastic/vinyl/abs or whatever.
My under hood temps are very low compared to a stockish 3rdgen, 160 t-stat, aluminum heads, no A/C, and Jet hot coated headers..
The very 1st SLP box setups were aluminum.
The only problem I see with the filter on the bottom side of the battery tray, is when it rains. It could have a better chance of sucking water up.
And outer filter covers but since I'm old,
I don't like:
laying under my car for basic filter maintenance
and drilling huge holes in my car.
I do like:
a semi OEM could have built it look,
filter in a easy spot to get to,
I'll stick w the SLP setups.
I don't like:
I do like:
Car: 1988 Trans Am GTA
Engine: 350ci 5.7L TPI
I made this a couple years ago for a Firebird I had
make a aluminum tube that runs over to the driver or pasenger side, cut a hole in the tray where the stock filter canister use to be and run it under the car in the wheel well... that cold air also. i did one like that for mine..
Car: 1986 Trans Am
Engine: 305 TPI 5.0L
Transmission: Automatic with shift kit
For the open air intakes does it really make much of a difference? Its just sucking in the hot air from the engine bay isn't it? I'm trying to find a way to make a air filter for my 86 trans am and I'm trying to get the best result from it as I can. I do like the setup of the two air filters going right into the throttle body. It looks pretty sweet but how effective is it?
If both flow the same amount there is a 2% gain with colder, more dense air. That's all.
Car: 1986 Trans Am
How'd you make the T shape filter?
Car: 1985 firebird
2% of 350hp.....that's 7hp. If I'm going through the trouble of fabbing a cai I'd get that too.
Plus if your spraying or running boost that cooler air will be worth a lot more before detonation.
That's nice that you have 350hp. The OP doesn't. I doubt the OP is spraying or boosting either. That 2% is mostly torque, not hp.
Car: 1985 firebird
Lol, I run 6's in the 1/8, 10's in the 1/4....I passed the 350hp threshold in high school.
You gotta build hp somewhere so why not get all you can since you are going though all the trouble of fabbing it up yourself. My pervious post was not just directed to the op but all who are contemplating building their own. That kind of "oh well it's just 2%" is the main reason the fox body mustangs are "generally faster" than third gens.
Don't get me going on a rant here!!!
LOL,He HAS a good point there! 2% here, 2% there, and pretty soon you are talking about some pretty big numbers!
2% of nothing is still nothing though. Yes, you have to start from somewhere, so do stuff that will actually make more power.
Car: 1985 firebird
I guess man, just how much more would you expect?
Here's my cowl cold air scoop.
Cowls are a different story. Cowls actually do make a difference.
Cowls make more than 2%.
Car: 1985 firebird
It better be more than 2% or its going in the trash!! Lol
Car: 1987 camaro sc
Engine: lg4 305
with tpi caai really wont make a difference since you have to route the tubing next to the radiator. simple as that you mainly feel the less restrictive air filter
a cowl wont do much for a TPI, in theory, cold air injection (if its actually cold out) would theoretically expand inside the motor to increase the power....i did a "cool air intake" which is like LB9GTA's.
i would never do a cold air intake, the power is just theoretical for it. I'd rather keep my fog lights and do a cam than cold air. IMO
I could make mine into a cold air intake but the practicality goes down the toilet with it.
Once that extra pipe is added closer to the ground(also closer to more dirt, stones and water) the bigger the chance to suck up something.
Car: 89 Formula
The rocks/debris issue is resolved with hot gluing or bolting a screen from an old window or some tight mesh "chicken wire" to ducting from a household HVAC (central air) system. Or hit the bone yards for an ABS piece from another car that might work. I did a bunch for friends of mine back in the dya on F cars, a couple fox bodies, and a Supra.
1992 Trans Am
05-10-2023 07:19 PM
Brinkkl2000
08-04-2018 08:29 AM
