headlight air induction idea
Car: 1987 Camaro Z28
Engine: Carbed 355
Transmission: Borg Warner T56
Axle/Gears: 4th gen 10 bolt 3:73 Richmond gears
im toying with the idea of doing a ram air induction through my high beam light spots. i found an HID kit that replaces the low beams, and switch from high to low from just those, so i dont need the high beam halogens anymore. i found a car that someone did this to, i was thinking of doing something similar, here is a pic:
and this guy put a filter behind the screen:
and then i photoshopped what i want:
before:
after:
oh and here is the link to the HID kit:
http://www.ebay.com/itm/4X6-PROJECTOR-BLACK-LENS-HEADLIGHT-4300K-H4-HID-HIGH-LOW-BEAM-SLIM-BALLAST-KITS-/400550763859?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3ACamaro&hash=item5d42af9d53&vxp=mtr
before:
after:
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: headlight air induction idea
I've been toying with the same idea ('91 F'bird). It looks neat. However, you're not going to get any significant ram effect until you're going really fast. Good cold air though.
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Good idea, bad (imho) choice of kit.
I highly doubt that those are projector lights. Those appear to merely be HIDs in a housing with a round lens to look like projectors.
I'd like at http://www.ddmtuning.com or from http://www.theretrofitsource.com
Several threads here on TGO about retrofits. Read those before you buy anything & waste your $.
Engine: Carbed 355
what about these
https://www.thirdgen.org/forums/exte...card-full.html
Ghettobird52
12-29-2023 08:23 AM
1992 Trans Am
05-10-2023 07:19 PM
86IROC112
09-07-2015 01:37 PM
db057
08-11-2015 10:11 PM
