Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
2014 Hood heat extractor onto third gen? Is it possible?
Old 09-11-2014, 11:54 PM
Nelz's Avatar
I've been looking at GM's solution for extracting heat out of the hood of the new 2014 Z28.
They do list 2 part numbers for the hood heat extractors and a rain deflector plate.
1- GM 2014 Heat extractor (GM Part # 22828242)
Optional- GM- Water Deflector (GM Part # 23180572)
I know many people have tried to build their own heat extractors or cut the louvers on the stock hood but rain usually kills the distributor If you look at the new z28, the LS motor is covered by engine covers and the heat extractor has a water deflector that deflects water to the front of the Z28 where the water is.
I don't think this will fit where the louvers are on a V8 car with louvers, but I've seen the stock V6 third gens have flat hoods with no louvers that might be a candidate for testing this mod. Or, maybe the water deflector is big enough to go under the stock V8 Louvers if you are cutting them to the right dimensions and add in a mesh screen to keep leaves out???? (I can't believe how many pine needles get embedded in my louvers in my parking lot without any holes in the louvers.)
Thoughts?
Ever since I modded my motor, the heat under the hood has increased quite a bit! Cold air=more power but what's the point if the exhaust heat just gets trapped under the hood?
Old 09-12-2014, 02:01 AM
RaverRacerX's Avatar
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
Re: 2014 Hood heat extractor onto third gen? Is it possible?
Old 09-12-2014, 02:25 AM
Nelz's Avatar
Wow Very Nice! Did you just get a fiberglass hood and install that heat extractor? Are you going to put the rain deflector on it too?
Very nice!
Old 09-12-2014, 04:55 AM
Veaceonee's Avatar
Car: 88 GTA Notchback
Axle/Gears: don't know
That looks awesome. But, what about the rain??
Old 09-12-2014, 07:20 AM
G-Performance's Avatar
Car: 1992 Z28 25th Anniversary
Transmission: Automatic
Axle/Gears: Stock
You can buy a similar hood on ebay with the extractor in it.
http://www.ebay.com/itm/82-92-Chevy-Camaro-ZL1-Look-Duraflex-Body-Kit-Hood-/151293700002?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A1992%7CModel%3ACamaro&hash=item2339cea7a2&vxp=mtr. But I do like the way yours came out. Get the GM rain gutter that they are putting on the 2014 Camaros unless you don't plan to drive in the rain
Old 09-29-2014, 10:22 AM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
Originally Posted by RaverRacerX
dam looks sweet I wanted to do this to my hood but didn't have the ***** to cut up a $400 hood. how much them vents cost.
Old 10-29-2014, 12:46 AM
92rsvortec350's Avatar
Car: 92 rs z28 clone
Engine: forged 350
Transmission: 700r4 fully built
Axle/Gears: moser axles eaton posi 3.73 gears
Nice what's the measurements of it length and width?
Old 10-30-2014, 09:21 PM
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
the vent plus drip pan is something like 150 or so all together.
Old 12-31-2014, 08:36 PM
PAFORM350's Avatar
Car: 1992 Formula 350
Engine: 5.7 L98
any pics of hood on car
Old 01-02-2015, 07:43 PM
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
not my car:
http://www.pro-touring.com/threads/8...987-Camaro-Z28
Old 01-12-2015, 08:46 PM
ls2 dude's Avatar
Car: 1989 iroc z
Engine: 98 ls1, prcs, btr cam
Transmission: rkt56 6 speed
Axle/Gears: midwest chassis 9 inch 4.30wavetrac
I don't have a dedicated heat extractor hood. However. I removed the center of this hood all the way down to the front and it does a very good job of moving air from under the car. In conjunction with the radiator position.
Attached Thumbnails 2014 Hood heat extractor onto third gen?  Is it possible?-img_20141117_000922.jpg
Old 01-04-2016, 12:18 PM
BadCarma's Avatar
Hey Guys,
Just found this thread with the pics of my hood on it. Here are some additional pics.
Old 01-06-2016, 03:04 PM
92BLKL98's Avatar
Car: 1992 Black Z28 Hardtop
Axle/Gears: 2002 10 bolt w/3:23
Who makes the hood? Looks very nice.
Old 01-08-2016, 09:15 PM
BadCarma's Avatar
The hood started out as a Harwood 3 inch Cowl induction hood. It took six months of night and weekends to cut it and fit the vent.
Greg
Old 01-23-2016, 03:20 AM
edz88irocz28's Avatar
Car: 1988 Iroc-Z28
Engine: TBI 305 Bored 30 over mild Mods
Axle/Gears: Stock
Very Nice work !
Old 01-23-2016, 05:11 AM
peterc005's Avatar
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
I got a set of these functional IROC hood louvers. They are great and I can't see how rain would get to the distributor, which sits under a cover at the back of the engine.
Old 07-16-2016, 02:09 PM
BOTTLEDZ28's Avatar
Transmission: A4
Greg
I take it the insert wont work on a stock hood huh? how tall is the insert?
Old 07-17-2016, 11:12 PM
ThirdGen1984's Avatar
Car: 1984 F41 Camaro
Engine: LC1 V6 2.8L
Transmission: 4 Speed Auto
Looks really good, like the carbon fiber too.
Frozer!!!
01-19-2024 04:55 PM
Black89TA
Exterior Parts for Sale
07-23-2016 10:42 AM
TheExaminer
08-26-2015 04:59 PM
ElPaleterro85
08-13-2015 03:49 PM
bryan623
08-10-2015 11:33 AM
Quick Reply: 2014 Hood heat extractor onto third gen? Is it possible?
