Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Glass Hood?
Old 08-17-2015, 07:59 PM
dbrochard's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: WC T5
Axle/Gears: Torsen 3.73
Glass Hood?
Hi guys, has anyone attempted to build a glass cut out in the hood like on the new Callaway Camaro? I though it would be cool to do after I do my LT1 swap, I will post a picture for reference.
Old 08-17-2015, 08:00 PM
dbrochard's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: WC T5
Re: Glass Hood?
Old 08-18-2015, 01:42 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Re: Glass Hood?
Would be very easy. Just need to find the scoop with the clear cutout and then cut a hole in the hood and mount it.
Old 08-18-2015, 01:47 PM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Re: Glass Hood?
Fun concept but all it does is provide a magnifying glass for the sun's heat right on top of your engine.
Old 08-18-2015, 02:29 PM
dbrochard's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: WC T5
Re: Glass Hood?
Good point.
I'm thinking of either doing this to my base model hood, or cutting the shape of the iroc louvers into it and getting glass plates in that shape. This will probably not happen for another month, but I do plan to do one of these two ideas
Old 08-18-2015, 03:52 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Re: Glass Hood?
This might be of interest...
https://www.thirdgen.org/forums/ltx-...ild-storm.html
Old 08-18-2015, 10:01 PM
Car: 87 TA clone
Re: Glass Hood?
Last time I checked the motors run at 180-225*F… thats way hotter than the sun rays lol. not going to affect it lol.
Old 08-18-2015, 11:08 PM
Slash's Avatar
Car: 1988 Camaro IrocZ
Engine: Holley Stealth Ram 385 Stroker
Transmission: Redline Performance 700r4 Trans
Axle/Gears: Bulletproof 4thGen Ls1 SS Rear 3.73
Re: Glass Hood?
thats why you can burst an Ant into flames with minimal effort and a magnifying glass right? lol. The glass in the hood would magnify the heat and trap it inside the engine bay like a greenhouse effect.
Old 08-18-2015, 11:51 PM
mjdavis68's Avatar
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
Re: Glass Hood?
Reminds me of a Hot wheel. Looks cheap to me
Old 08-19-2015, 06:53 AM
Car: 1983 Z28
Re: Glass Hood?
Bingo. lol.
Old 08-19-2015, 06:54 AM
Car: 1983 Z28
Re: Glass Hood?
Originally Posted by dbrochard
Good point.
Somebody on here made some functional iroc louvers out of stainless, I think it was stainless, looked pretty wicked.
Old 08-19-2015, 10:04 AM
dbrochard's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: WC T5
Re: Glass Hood?
I think if Callaway is making such a high performance car, their engineers figured it wasn't a problem.
When you try to set those ants on fire, you have to move the magnifying glass a certain distance from them to find the focal point as possible. The focal point is when the little spot of sunlight going through the lens is at its smallest, so the sunlight/ heat is more concentrated therefore being hot enough to burn the ant.
Applying that logic to putting it on the hood, the glass isn't at enough of a distance and isn't curved enough to have its focal point directly on the surface of the engine.
Will it concentrate the sunlight?
-Yes, however the sunlight won't be nearly concentrated enough to do any sort of damage.
I'm no scientist i'm just spitting out what I learned in science class, but because of how close the engine is to where the glass will be, the space the "Concentrated sunlight" will take up is still so large that I doubt it will increase the temperature be more than 5 degrees.
Old 08-19-2015, 11:34 AM
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
Re: Glass Hood?
Thats like saying your sky-light in your bathroom will burn you if you walk under it. Or melt the floor....
Or the windows in your car/house. "Look out, dont let the light that shines through the window touch you, It will burn you"
Silly ppl... hehe..
Lets think about things before posting.....
Old 08-19-2015, 03:47 PM
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
Re: Glass Hood?
Only way it would do it is if you used a big magnifying glass as the piece of glass for the hood, AND had it at the right distance to focus the beam of light. No ifs ands or butts.
Old 08-19-2015, 03:57 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Glass Hood?
It would have to be concave or convex with the engine at the proper focal point. Wont happen with a flat piece of glass.
Old 08-19-2015, 06:21 PM
Scorpner's Avatar
Engine: V6, V8
Re: Glass Hood?
Yes, it has. In fact it has been attempted many times before, ...and very long ago.
http://www.bigalslist.com/featuredca...3/feat1303.htm
Scorpner's Avatar
Engine: V6, V8
Re: Glass Hood?
Here is an example of a Thirdgen that one of the sponsors here built:
91TTOPZ
Exterior Parts for Sale
09-20-2016 12:42 PM
Bubbajones_ya
10-25-2015 08:01 PM
Quick Reply: Glass Hood?
