sticking neck out/poor man's tub & narrow
Car: 91' Camaro RS
Engine: 305 TBI V8
Transmission: 700/R4
Axle/Gears: Stock
Re: sticking neck out/poor man's tub & narrow
Looks pretty good! Next time add some plug welds where you welded the diff. They add a lot of extra strength for very little work.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I'm not going to say yes or no about anything. The welds look great from an inexpensive TIG. I love seeing someone having a plan and jumping right in and doing it. Too many "How do I do this", "How can this be done" etc posts from people who really shouldn't be attempting the things they're asking.
My only concern about your project is straightness of the tubes. I don't see a diff jig anywhere in the pictures nor do I see an alignment bar going through the tubes. All that welding, as straight as you try, will always cause the tubes to warp slightly. An alignment bar is a solid bar usually 1-1/4" or 1-1/2" thick and some aluminum pucks which replace the bearings and bolt the bar in place. Some locks at both ends of the bar holds everything tight.
When I narrowed my 9", it was a lot simpler. I cut the ends off the tubes, cut the tubes to the length I wanted then welded the ends back on. I made a rough alignment tube to go through the diff after welding everything back up and found the tubes weren't straight. I had also welded on a back brace, coil over shock mounts and 4-link brackets. I used a 50 ton press at work to tweak the tubes as straight as I could get them. Haven't had a failed bearing yet and the axles slide nicely into the splines of the spool.
After I narrowed my diff, I ordered the axles I wanted to the length required. As nice as those S10 axles may be, they're still very weak. Not all S10 axles are the same length. I hope you remember what year truck those came from. You can probably order aftermarket replacement axles which will be much stronger than OEM ones and if you change the posi to 28 spline, upgrade to 28 spline axles as well.
i appreciate the honest input. i looked into one of those bars and it was $500! i took a million measurements and strategically tacked and welded in a certain order. i was surprised how close it came out.
they were 84 s-10 axles. i had done a lil research first and moser does offer some replacement axles. all-in-all, this was an experiment and my first time narrowing a rear.
still much work to do, but i'm happy so far.
should be a fun experiment , later when you want to run it im sure they will want the c-clip eliminators installed.
Ive had axles walk on on these 10bolts in 100% stock form with a drum rear. that's another spot the stock 9 bolt was better.
Car: 87 IROC L98
Rear disk brakes will act as good axle retention devices. If the end of the axle snaps off and a c-clip is lost, the caliper over the rotor will keep the axle from falling out.
I'm guessing that's not the first time you ever tig welded if that's how your welds came out.
I can't tell you how many times around here I've started answering something and went to "you really shouldn't be attempting this if you're asking this question..."
Yea, if there's enough heat in those welds to have good penetration then those tubes bent. I honestly don't know how you would check them (even sighting down the tube isn't going to really tell you) without some sort of jig.
A big press is one way to straighten it, an easier way is to use a torch with a rosebud tip on it, you can heat the "long" side and then let it cool and it will shrink some.
The problem with this is that you still have a 7.5" ten bolt when you're done. a hard launch on those slicks will still break something eventually. If this was a show car this would make sense, but trying to make this thing live will turn it into a money pit.
Been there, done that at over 100mph... that tire locked up and I was in for a hairy ride... I guess it was much better than the tire leaving the car and going for a similar ride...
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
good job, but wouldn't it have been easier to just get wheels with more backspacing?
Car: 87 IROC L98
Looking at the large tires he's using and the rims they're mounted on, I'd say they already have a lot of backspacing. Adding more would have the center of the rim pushed outward even more. It would start to look something like a corvette rim.
My tubbed out car has 15" wide rims. With my narrowed diff, a backspace of 5.5" works well but I still have enough room between the tire and the frame rails to use 6.5" if I really had to. The deep dish has a much nicer look with slicks. Another advantage is the shorter axles. Although not impossible, it's easier to twist a long axle than it is a shorter axles of the same diameter.
Question about the TIG inverter. Did you do all those welds with 110v or 220v? Looking at the heat penetration on the tubes, I'm going to guess 220v.
yes, i'm using 220 on a double throw 30 amp breaker with 100' of hard wire so i can reach pretty far away. i've been a welder for 25 years. just thought this was a nice machine for $200. its scratch start but can stick weld too obviously.
running deeper dish rims would still have needed suspension and tub work. these rims are 5.5" backspacing. and i was wondering if shorter axles might be stronger?
yea, i shoulda started out with a 28-spline disk brake rear. but, this is what i had laying around to work with. luckily there is basically no tech at the 1/8 mile i've been to. my car is kinda slow too, only ran a best of 8.3 at 83mph so far.
started throughing this together earlier for the control arm mounts.
Car: 87 IROC L98
Axle retention isn't mandatory until you run 10.99 in the 1/4 or 6.99 in the 1/8. Since you're only running 8.3, you have a long way to go until it's necessary to have it but having something you don't need never hurts.
You could put a full cage in your car but don't really need it.
I'm going to follow this thread very eagerly. I will convert to a 8.8 in a way that's pretty similar to how you did your narrow job. Cut tubes and weld in other tubes. I was planning on cutting them myself and finding a good place in phoenix to do the weld and straightening or just the straightening. I had read a couple threads across the internet where it was done without jigs and the results after useage were either not posted or excessive bearing wear. Very interested in you results over the next year!
i did put a homemade cage in it already. on 4 spots, i drilled holes through the floor so i could weld directly to the SFC's, then welded a plate over them. i doubt its up to any "tech". just doing kind of a pro street type build.
Car: 87 IROC L98
It that doesn't have a halo bar and A-pillar tubes, it's only a fancy roll bar and not a full cage. Those door bars won't allow you to run quicker than 11.49 in the 1/4 anyway. They don't pass between the shoulder and elbow so it's not even a legal roll bar.
i agree 100% with you. i may add on to it at a later date? i forget why i put the bars low? i think i was trying to keep the stock door pulls or something? anyway, just showing where its at. i'll try to get back on topic next post.
thanks! it's 3"x3" square tube. theyre 6" long each. i sliced them down the middle and at 1/2", then flipped the drop over and welded it in. when i tack them in the car it will be more apparant to why the notch.
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
First off, great job on the fabrication.
My only question is, why do you need to tub and narrow the car? How fast are you going?
We've got guys on the forum in the low 9s, high 8s in the1/4 and are not tubbed.
-- Joe
-- Joe
thats a good question. i eventually would like to put more power into the car. never could get good traction, til i tried these tires. i just dont like them sticking out. also i do like the "old school" pro street look.
Plus good practice before doing it to a 9"
Car: 2013 RAM, 1991 GTA
Engine: 5.0
Axle/Gears: Factory?
Great progress and fun to watch!
Can you not use a 3/32nd stick and arc it?
I have been doing some work on mine and don't have a MIG but find the stick is working well. I used to be a boilermaker/welder and still have a feel for it even not welding for 10+ years.
#43
i do have a stick and flux core mig. i think i'm going to have to go one of those routes, especially in some of the hard the reach spots.
i've been busy with work and havent had any time to mess with it lately.
found another pic from the other day.
if you look above the weld in this pic, you can see where i used a hole saw to cut about a 1 3/8" hole so that i can tighten the control arm nut/bolt.
#44
Car: 91 Firebird
Engine: 6.0
with all of your welding skills, have you starting doing any welding on the side for members?
I might have a torque arm mount that needs to be welded to an 8.8 ford center section....
#45
sure, no problem Jason. that's all i do is odd welding and mechanic work for myself. i'm kinda far from you though. i'm north of st. pete area. i used to live in north ft. meyers. shoot me a PM and i'll give you my number.
#46
after days of rain and work, i finally got back on the project today. started looking at where the shocks need to be re-located, marked it out and got most of it cut out before it rained again, uhhggg. i plan on slicing a piece of pipe in 1/2 to fill the gap in the frame, etc., and of course beefing up the area.
hope to get more done this weekend if the weather cooperates.
#47
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Would it be possible to move the shock mount on the axle? You should have plenty of room to use the stock body side mount with that size wheel/tire
#48
#49
do you have a link or a few pics? when i had my wheels/tires on, i could barely fit a finger between the control arm and tire. i'm always open to new ideas or ways of doing things.
#50
one thing i'm really trying to do is keep the factory gas tank. (super low budget build). so far it looks like its probably going to fit.
took some measurements and painted the ground where the shock should be, and used a piece of 3" pipe to simulate the angle.
made a template earlier for a plate that i plan on welding to the top of a piece of 4" pipe sliced in half. but heres the mess im at right now, lol.
pic from the inside.
