FAQ Board This board is where some of the most informative and helpful Frequently Asked Questions we get here at ThirdGen.Org are put for easier reference. This IS NOT a general question board.
Odd Terms and Definitions
Old 03-26-2009, 04:59 PM
KittDrifter's Avatar
Car: 88 Firebird Formula
We all should know what the term 'f-body' means (any firebird, trans am, or camaro) and if you dont, something is wrong.
I hope this thread can be used to post terms, along with what they mean, or suggesting a term you dont know, or that others may not be familiar with.
Starting off, what are "salad shooters" and what is a 'tranny tunnel'?
And what cars fall under the other GM chassis letters?
Old 03-26-2009, 05:05 PM
JT
Community Administrator
JT's Avatar
Re: Odd Terms and Definitions
This type of thread would probably be better suited in the FAQ forum, as that is the place people should be looking to for Frequently Asked Questions and Information:
https://www.thirdgen.org/forums/faq-board/
We have some information on common technical abbreviations (not just forum abbreviations):
https://www.thirdgen.org/forums/faq-...eviations.html
Old 03-26-2009, 05:30 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
salad shooters are rims. tranny tunnel is the hump in your floor with a transmission in it. and for future reference trans ams are firebirds. trans am was an option on the firebird like z28 camaro.
Old 03-26-2009, 08:15 PM
some others:
Bowling *****: the spherical hubcaps that came on 82-84 trans ams that look like, well, bowling *****
GM Letter-body Platforms:
A-body = malibu, chevelle, le mans
B and D-body = caprice, bonneville, impala
F-body = firebird, camaro
X and K-body = nova, ventura
V-body = GTO
Old 05-04-2009, 01:24 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
AFPR = Adjustable Fuel Pressure Regulator
MAF = Mass Air Flow (sensor)
Old 07-06-2009, 12:13 AM
Lee1's Avatar
Car: 1991 Formula Firebird
N.O.S. New Old Stock- Refers to factory original, unused, never installed parts. Does not apply to replacement parts installed and later removed.
OEM- Original Equipment Manufacturer. Parts made by the same the same suppliers as found on production cars.
Old 07-07-2009, 12:17 AM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
rake - where the front of the car is lower than the back.
Old 08-19-2009, 09:39 PM
Car: 1987 IROC Z
MPFI - Multi Port Fuel Injection - This was the type of manifold and fuel injection scheme used for V6's in the late 80's (87 and up I believe)
TPI - Tuned Port injection - Fuel injection for V8's
Mark_ZZ3
05-24-2018 01:02 PM
hartsmike
10-04-2015 01:00 PM
Stryker412
09-20-2015 06:59 PM
BWilcox
09-20-2015 12:19 PM
Fronzizzle
09-08-2015 12:10 PM
Quick Reply: Odd Terms and Definitions
