[PA] 1989 Pontiac Firebird Formula
1989 Pontiac Firebird Formula WS6
The car has served me well over the past eight years and had been a great daily driver. A month after I purchased the car I entered it in the Carlisle GM Nationals where it won first place in 78-02 Pontiac Firebirds. Shortly after that it won an award for best wheels at the NJFBOA nationals. The car was a 305TPI/700R4/2.73 Posi car that I had professionally converted to a manual transmission (WC T-5). The car currently has 98XXX miles on it. If you have been to the Carlisle GM nationals the last eight years you have seen this car. It also was entered in many shows local to Philadelphia PA.
Modifications:
Complete stainless steel exhaust including:
SLP Headers 1 ¾” stainless steel and ceramic coated
Catco 3” hiflo cat
Magnaflow Stainless Cat-back (4th gen)
Intake
MSD 6AL
MSD coil
MSD Cap and rotor
Taylor wires
NGK Spark plugs
Accel TPI coil trim plate
Ford SVO 19lb/hr fuel injectors
Manual Trans conversion
World Class T-5
Zoom Clutch
New GM L69 Flywheel (factory 19lb)
Pro 5.0 shifter
LS1 aluminum driveshaft
Poly transmission and torque arm mount
Spohn Lower control arms
Spohn Panhard Rod
TDS Wonderbar
HP Motorsports 3 point rigid strut tower brace
Poly Endlinks and sway bar bushings
Koni Yellow 3rd gen fronts/4th gen rears
Global West Del-a-lum control arm bushings
Hot part strut mounts
Howe Extended ball joints
4th Gen fuel tank conversion
Plastic tank
Grand Prix sender to work with stock fuel gauge
LS1 Fuel Pump
4th gen filler neck
Charcoal canister mounted in gas tank (cleans up engine bay)
Clear sidemarker lenses
Trans-Am taillight conversion (black honeycomb)
Kenwood KDC-BT900
Pioneer 4x6 Plate speakers
Pioneer 6x9 speakers
Alarm with keyless entry
4th Gen Ebony leather seats
Leather shift boot to match seats
Replacement parts:
Headlight motors rebuilt (TDS Kit)
ECU
MAF
All relays
R134 conversion for A/C
Ignition module
TPS
Coolant Temp Sensor
Knock Sensor
Alternator
Power master starter
All the steering linkage replaced (idler/center-link/tie rods + billet sleeves)
TTop weather striping
Windshield
Painted GM Flame Red
BFG Gforce sport tires last year
Factory Options:
Power Windows
Power Door Locks
WS6
305TPI
TH-700R4
2.73 Posi rear
Tilt wheel
$8,000 obo
Modifications:
Catco 3” hiflo cat
Intake
MSD 6AL
MSD coil
MSD Cap and rotor
Taylor wires
NGK Spark plugs
World Class T-5
Zoom Clutch
Pro 5.0 shifter
Spohn Panhard Rod
TDS Wonderbar
Plastic tank
LS1 Fuel Pump
4th gen filler neck
Kenwood KDC-BT900
Replacement parts:
ECU
MAF
All relays
Ignition module
TPS
Coolant Temp Sensor
Knock Sensor
Alternator
Windshield
Factory Options:
Power Windows
Power Door Locks
WS6
305TPI
TH-700R4
2.73 Posi rear
Tilt wheel
$8,000 obo
Re: 1989 Pontiac Firebird Formula
Bump!
Added last year:
Black GTA door panels
3.70 9bolt with new posi cones/bearings/seals
PBR disc brakes
Goodridge braided brake lines all around
Stainless hard lines on the rear
Added last year:
PBR disc brakes
colton_carlson
03-08-2019 12:21 PM
1Aauto
Sponsored Vendors
04-09-2018 03:00 PM
1Aauto
Sponsored Vendors
08-24-2015 03:40 PM
