[AZ] FS: 1991 Firebird Formula WS6 L98 All original 30K miles
Hey guys, considering making room in the garage, and selling my 1991 Firebird Formula 5.7 WS6. All Options, Very low mileage, just 31,000 miles, all Original. Red Exterior with Grey interior, no T-Tops (Hardtop).
Haven't uncovered it in the garage to take pics yet, but pristine Red exterior, with just the normal wear and tear of 30,000 miles. Interior looks as new.
Car was originally ordered by Executive in GM, and delivered through internal GM ordering system to Central Foundry GMC Plant in Indiana before selling to it's first private owner in 2009 with 25,000 miles on it. No accident history whatsoever.
Since then, in past 6 years has had just about 1,000 miles a year put on the car. Car drives as new off the showroom floor, truly a dream.
I'm not super decided on selling it, but I'd consider offers of about $10,000 if interested in finding a very low mileage unmolested clean 3rd gen.
Can email specific pic requests as necessary.
Thanks,
Dave
Happened to find one pic on my computer that I've attached.
Thanks,
Dave
Re: FS: 1991 Firebird Formula WS6 L98 All original 30K miles
Had some requests for the RPO codes here you go:
Report for..
1G2FS2383ML221764
Vehicle:
FIREBIRD 2 DR
Year:
1991
Build Date:
1990-06-29
Found 47,612 vehicles matching that year and model in our database.
RPO Description Matches
UB3 CLUSTER,INSTRUMENT(OIL,COOLANT TEMPERATURE,VOLTMETER,TACHOMETER,TRIP ODOMETER)(USED WITH DELUXE SPORT PKG W32) GA(UB3) 47,612
UQ1 RADIO,PROVISIONS FOR STEREO STEREO RDO PR0VISIONS(UQ1) 47,612
U1A RADIO,AM&FM STEREO,SEEK/SCAN,C.D. PLAYER,EQUILIZER,INCLUDES CLOCK CD PLAYER/EQLZR(U1A) 1,402
U62 SPEAKER SYSTEM,4,DUAL COAX FRONT,DUAL COAX PACKAGE SHELF 4 SPKR SYS(U62) 47,612
VAN PLANT CODE VAN NUYS, CA, CPC VAN NUYS,CA PLANT CODE(VAN) 47,612
VK3 LICENSE PLATE,FRONT MOUNTING PACKAGE FRT LIC PLT MTG PKG(VK3) 37,477
V73 VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73) 44,388
WS6 PERFORMANCE PACKAGE,SPECIAL(MERCHANDISING OPTION) SPECIAL PERFORMANCE PKG(WS6) 10,360
W66 FORMULA OPTION(MERCHANDISING OPTION) FORMULA(W66) 5,464
1SC PACKAGE-OPTION 03 (1SC) 24,569
15P WHEEL COLOR,MEDIUM SLATE GRAY (15P) 5,382
6ZW SPRING COMPTR SELECT FRT LH SUSP(6ZW) 7,587
7ZW SPRING COMPTR SELECT FRT RH SUSP(7ZW) 7,587
8NL SPRING-COMPTR SELECT RR LH SUSP(8NL) 11,102
81Q MOLDING COLOR - BRIGHT RED (81Q) 12,546
81U EXTERIOR COLOR,PRIMARY,BRIGHT RED (81U) 12,730
82C TRIM COMBINATION,CLOTH,MEDIUM DARK GRAY (82C) 31,438
82I INTERIOR TRIM,MEDIUM DARK GRAY (82I) 31,861
829 SEAT BELT COLOR - MED DK GRAY (829) 31,861
9NL SPRING-COMPTR SELECT RR RH SUSP(9NL) 11,102
AAA Unknown 46,052
AH3 ADJUSTER,SEAT,4-WAY MANUAL,DRIVER 4-WAY MAN D/SEAT ADJR(AH3) 13,751
AJ3 RESTRAINT SYSTEM,FRONT SEAT INFLATABLE DRIVER SI INFL RST SYS(AJ3) 47,612
AR9 SEAT,FRONT BUCKET,DRIVER,PASSENGER,MANUAL RECLINING(EUROPEAN STYLE) MAN RECL FRT BKT ST,DELUXE(AR9) 44,743
AU3 LOCK,SIDE DOOR,ELECTRIC ELEC S/D LK(AU3) 41,671
A31 WINDOW,ELECTRIC OPERATED,SIDE ELEC SI WDO(A31) 41,671
A90 LOCK,REAR COMPARTMENT LID,REMOTE CONTROL,ELECTRIC RELEASE ELEC REL LID LK(A90) 28,389
BC8 ORNAMENTATION,INTERIOR,FRONT DOOR MAP POCKET RH AND LH DR MAP PKT(BC8) 41,671
B2L ENGINE PACKAGE-V8 5.7L, PFI ENG PKG(B2L) 3,489
B84 ORNAMENTATION,EXTERIOR,BODY SIDE MOLDING(USED WITH APPEARANCE PACKAGE Z12) BODY SI MLDG(B84) 46,790
C49 DEFOGGER,REAR WINDOW,ELECTRIC ELEC RR WDO DEFG(C49) 33,076
C60 AIR CONDITIONER,FRONT,MANUAL CONTROLS A/C MAN CONT(C60) 46,946
DC4 MIRROR,INSIDE,REARVIEW TILT,DUAL READING LAMP I/S DUAL READING LP RR VIEW MIR(DC4) 46,761
DG7 MIRROR,OUTSIDE,RH AND LH REMOTE CONTROL,ELECTRIC(PAINTED)(USED WITH SE Z7M,STE Z7N,LE Z7K) O/S ELEC R/CON PAINTED MIR(DG7) 27,108
D5X GEAR-SPEEDO DRIVEN (D5X) 3,489
D8I SENSOR-VEH SPD (10456089) (D8I) 2,268
D81 SPOILER,REAR,AERO WING RR AERO WING SPLR(D81) 13,733
E5Z ADAPTER - SPEEDO - DELETE 47,612
E9Z KEY - SPEEDO - DELETE 47,612
FE2 SUSPENSION SYSTEM,RIDE AND HANDLING(USED WITH PERFORMANCE PACKAGE WS6) RIDE & HANDLING SUSP(FE2) 10,360
GU5 AXLE,REAR,3.23 RATIO 3.23R(GU5) 26,461
G80 AXLE,REAR,POSITRACTION,LIMITED SLIP POSITRACTION L/SLIP R/AXL(G80) 9,171
IPC TRIM,INTERIOR DESIGN (IPC) 44,743
J65 BRAKE SYSTEM,POWER,FRONT AND REAR DISC 4-WHL DISC BRK(J65) 3,474
KC4 COOLING SYSTEM,ENGINE OIL(EXPORT-IRAQ) KC4(EXPORT IRAQ) 4,569
K34 CRUISE CONTROL,AUTOMATIC,ELECTRONIC CRCONT(K34) 30,237
K68 GENERATOR,105 AMPERE 105 AMP(K68) 8,835
L98 ENGINE, 5.7L, (5.7-8) 350 CID, V8, TPI 5.7-8(L98) 3,489
MD8 TRANSMISSION,AUTOMATIC 4-SPEED(THM700R4/4L60) 4-SPD A/TRANS(MD8) 43,399
MX0 TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION)(MD8) A/TRANS PROVISIONS(MX0) 43,399
NA5 EMISSION SYSTEM,FEDERAL REQUIREMENTS FEDERAL EMIS(NA5) 43,196
N10 EXHAUST SYSTEM,DUAL(USED WITH TOURING YP6) D/EXH(N10) 4,569
N36 STEERING WHEEL,SPORT-4 SPOKES SPORT STRG WHL(N36) 41,430
N64 WHEEL AND TIRE,SPACE SAVER SPARE(ALUMINUM) STOWAWAY SPARE(ALUM)(N64) 7,327
PE0 WHEEL,16X8,ALUMINUM,LIGHT WEIGHT STYLED LGT WT AL WHL(PE0) 5,382
QLC TIRE,ALL P245/50ZR16/N BL R/PE ST TL HWY TIRE(QLC) 10,360
R6P CONTROL - SALES ITEM NO. 15 3,005
Report for..
1G2FS2383ML221764
Vehicle:
FIREBIRD 2 DR
Year:
1991
Build Date:
1990-06-29
AAA Unknown 46,052
Ok, new car looks to be coming my way. Very Motivated to sell. Accepting serious offers, for a quick sale.
Will be putting up on eBay and Autotrader by the weekend if no serious inquires by then.
Thanks,
Dave
Thanks,
Dave
Car is now on Ebay, LOW RESERVE! Purchased a new car, and gotta make some room.
http://www.ebay.com/itm/151479033601?forcerRptr=true&item=151479033601&viewitem=
Car: 1985 firebird
Engine: 360"sbc NA pump gas
Transmission: Th350 manual valve body
Axle/Gears: Moser 12 bolt 4.11:1
Congrats!!
Engine: 4++,350 & 305 CIs
How in the beeeep did I miss this ???
colton_carlson
03-08-2019 12:21 PM
Zachattack0925
08-12-2015 09:54 PM
Zachattack0925
08-12-2015 09:52 PM
