SC- Charleston 87 Trans Am GTA
Car: 1987 Trans Am GTA
Axle/Gears: Posi 3:42
Considering Selling my project Trans Am
87 Firebird Trans Am GTA FS/FT - Summerville SC (29483)
87 Trans Am GTA
Digital Dash (works)
Speedo will need Digital Dakota SG-1 Adapter for the T56 to read correct MPH
DriveTrain
5.7 w/LT1 Hot Cam
Headman Long Tube Headers
T56 Tremec Trans (6spd w/new 3500miles) *NEW*
02 Camaro Rear Swap (3:42)
Custom Tune / chip w/9th injector, egr delete, air delete. vats delete (computer 89)
Custom Wide Body to include;
Custom Front Bumper (+1".5),
Custom Fenders(2"over stock),
Custom Side Skirts (1.5" lower w/ 2-3" grade)
Custom Lambo Door Hinges w/1000lb struts
Custom Rear Quarters (3.5 over stock),
Custom Rear Bumper (+1.5)
Custom Wide Spoiler
Custom Smoke TailLights w/ sequential turn signals
Custom Paint and Airbrush Mural
Body needs: door sweeps. hood shocks and replacement glass for side mirrors or original mirrors
Recent Replacement
BMR Pan hard Bar, Sway Bar End Links, Breaks, Battery +Terminals, IAC and TPS, Distributor, ICM,Coil, Plugs, Wires and Cap/Rotor, Computer, Prom (Have 2).
Needs:
Interior is original and untouched and does need somethings but pretty clean and everything there. Do have door panels although will need upper trim.
E-Break cable installed (have modified set)
Tires (old)
Actual Exhaust (currently a set of flow master as dumps, not my doing but should be replaced)
Door Weather Stripping
Steering Column (Tilt Knuckle is loose)
Battery (have one, just not new)
Not Included:
No Radio
AC unit/Heater, does have good heater core if heat was to be re installed
Extra Interior parts included along with a box of goodies
Overall: Currently car starts, runs and drives, but does need attention.
I would highly suggest a TUNE or Custom "CHIP" ( i have a custom chip now which the car will run great on, but will not start and factory 87/89 chips that the car will start on but runs well...i believe its the egr in the original chips as the car doesnt have egr). Other then that, #3 exhaust valve seal does let oil into the header (not intake). May have fixed by time car sells.
The transmission is gem! Currently with new 2nd stage Clutch-have oem replacement as well (new)
VSS is not hooked up nor park safety switch, exceptional to drive threw 6 gears.
Nice project to finish, def a unique TA.
Body 9 of 10
Interior 5 of 10
Drive 8 of 10
you can view my build thread from signature to see all the details. or photobucket link:
http://s1223.photobucket.com/user/BL...?sort=3&page=1
87 Trans Am GTA
DriveTrain
5.7 w/LT1 Hot Cam
Custom Wide Spoiler
Recent Replacement
Needs:
Tires (old)
Not Included:
No Radio
Body 9 of 10
Interior 5 of 10
Drive 8 of 10
Re: SC- Charleston 87 Trans Am GTA
Been asked if I would do package deal in both 87 & 88.
And I would, pm for details.
The_Phoenix
02-04-2016 07:10 AM
