[IL] LS SWAP 383 TRANSAM FIREBIRD
Car: 1985 TRANSAM
$15000 OBO CALL OR TEXT 847-366-7559
550 HP!
TWO OWNER!
43K MILES ON THE BODY!
less than 500 MILES ON THE MOTOR!
FRESH BUILT 383 STROKER LS6!
461 RWHP, 438 RWTQ (W/ DYNO GRAPH)
T-TOPS!
BLACK EXTERIOR – GRAY CLOTH INTERIOR
Up for sale is the ultimate 1985 Trans am! Done well enough to be the ultimate sleeper, docile enough to be street driven
and fast enough to win at the track. This Trans am only has 42,800 miles on the chassis and it shows in the quality of this
car. It has a beautiful interior and exterior that anyone would be proud to own. This Trans Am has a 383 stroker LS6 the
makes 461 RWHP through a 4000 yank stall convertor. Don't miss your opportunity to own a truly unique ‘85 Trans am.
Mod list
383 LS6 block
Forged eagle crank and rods
Wiseco pistions -3cc
11 to 1 compression
243 LS6 heads ported by Total Engine Air Flow (2.04 and 1.59 valves)
92 mm fast intake
92 mm billet throttle body
Holley valve covers
Custom headers going into custom y pipe with new 02 sensors
Z06 85 mm mass airflow
160 degree t stat
36lb Bosch injectors
Racetronix 255lph fuel pump with hot wire kit
Custom cam spec'd by Brian Tooley Racing ( 2.39 .250 623.595 lift 114+4* )
Tuned by Speed Inc
Yank 4000 stall
Rebuilt 4L60e Transmission
Sphon subframe connectors
Eibach Spring kit
Spohn lsx conversion motor mounts with poly bushings.
Poly trans mounts
Drive shaft safety loop
Spohn adjustable torque arm with poly ends
Spohn f-body adjustable panhard bar with poly bushings
Spohn tubular lower control arms with poly bushings
Professionally wiring harness rework for 3rd gen with abbot speedo box- performed by spear-tech inc.
17"x8" ZR1 style SLP wheels specifically designed for third gen f-bodies with new radials
Adjustable Borla exhaust
All factory gauges work with the conversion
No a/c and heater box is removed( have existing)
550 HP!
TWO OWNER!
T-TOPS!
Mod list
383 LS6 block
11 to 1 compression
92 mm fast intake
Holley valve covers
160 degree t stat
Tuned by Speed Inc
Yank 4000 stall
Eibach Spring kit
Poly trans mounts
toronto formula
11-10-2015 06:17 AM
