1991 Trans Am GTA $3800
Car: 1991 Trans AM GTA
Transmission: 700r4 (for now)
Hey guys, it saddens me but I am coming to a point where I need to let my 1991 Trans Am GTA go. I am coming close to the end of my college career I need to start thinking about getting my massive amounts in loans paid off and can't afford to keep up with this awesome car. It has just over 107,000 mi on it and it runs and drives great. It has a 5.0L TPI motor, 700r4 automatic transmission, and a posi rear end. I have put a good amount of work into it and I have all of the receipts for everything that has been done since I have owned it. The body is very straight and the interior is in pretty good condition. Plus, the t-tops only leak if you go through an automatic car wash. I never have had them leak any other time.
Things I have done:
New tires
New water pump and lower radiator hose
New tensioner and belt
Replaced all the old vacuum lines
Magnaflow high flow catalytic converter & catback exhaust
Spark plugs & wires
New distributor, cap & rotor, ignition control module
Ignition coil
Bosch III injectors (recently ran on flow bench and cleaned)
Replaced fuel rail & fuel pressure regulator
New EGR valve
New EGR solenoid
New AIR tubing
New throttle position sensor
New idle air control valve
K&N air filter
New fuel sending unit, pump, screen, & filter
Frequent oil changes
New headlight motors
Valve cover gaskets
Valve adjustment
Intake & throttle body gaskets
Transmission mount
Rear sway bar bushings & end links
Panhard bar bushings
Coolant temp sensor
Intake air temp sensor
Things it needs:
Front sway bar end links & bushings
AC recharge (still R12 system as far as I can tell so may need to be converted)
Cosmetics (will need new paint eventually, has clear coat peel on spoiler and driver's mirror)
Windshield Replacement (has crack on driver's side)
To pass emissions*
*It runs extremely well but for some reason will not pass emissions. I have changed almost every part and sensor that could affect the system and it still just barely fails.
I am asking $3800 and I would really like this car to go to someone who can take care of it. I am continuously working on it and trying to get it to pass emissions so the price may increase accordingly. I live in Queen Creek, Arizona and will gladly set up a time to show it. Thanks for looking!
P.S. - Confederate plate does not come with the car and the Magnaflow pipes have been replaced with more stock looking pipes.
Things I have done:
New tires
Spark plugs & wires
Ignition coil
New EGR valve
New EGR solenoid
New AIR tubing
K&N air filter
Valve cover gaskets
Valve adjustment
Transmission mount
Coolant temp sensor
Things it needs:
To pass emissions*
Car: 1985 firebird
Engine: 360"sbc NA pump gas
Transmission: Th350 manual valve body
Axle/Gears: Moser 12 bolt 4.11:1
Re: 1991 Trans Am GTA $3800
Things I have done:
New tires
Spark plugs & wires
Ignition coil
New EGR valve
New EGR solenoid
New AIR tubing
K&N air filter
Valve cover gaskets
Valve adjustment
Transmission mount
Coolant temp sensor
Things it needs:
To pass emissions*
I am asking $3800 and I would really like this car to go to someone who can take care of it. I am continuously working on it and trying to get it to pass emissions so the price may increase accordingly. Thanks for looking!
Things I have done:
New tires
Spark plugs & wires
Ignition coil
New EGR valve
New EGR solenoid
New AIR tubing
K&N air filter
Valve cover gaskets
Valve adjustment
Transmission mount
Coolant temp sensor
Things it needs:
To pass emissions*
Car: 92 Trans Am Conv
Engine: LB9
Axle/Gears: 3.08
What did you end up selling for if you don't mind? I was going to buy this car but you sold two weeks too early! I was the guy with the R6 I was selling/trading.
I let it go for $3700.. I really needed the cash and that was the best offer I received. Sorry about that
Engine: LB9
Axle/Gears: 3.08
No worries. I'm bummed my bike didn't sell fast enough. Thanks for the info. It will help if I ever find another for sale.
Glowsock
09-05-2015 07:48 PM
