[Sold] 1987 GTA Trans Am Fairly Modded
1 Post
Car: 1987 GTA Trans Am
Axle/Gears: Borg Warner 9-Bolt 3.27
Deciding to sell my 87 GTA Trans Am. Have owned this car for almost 4 years and has been a reliable daily. Blast to drive. Like a guided rocket. I am the second owner. I'll try to keep this short and sweet.
Body has 165k, and will go up as it's a daily driver. Going on 30 years, the body has seen better days. Some bodywork and paint job it'll be a neck breaker, now it's just a head turner. Small dent in passenger fender. A-pillar has rust spots. Left rear quarter panel has some damage. Roof is starting to form some pea sized rust bubbles as well. Overall nothing extreme.
Driveline:
350 Vortec w/Holley Stealth Ram intake (untouched low mile bottom end, freshly rebuilt heads)
Lt1 camshaft
30lb injectors
Tuned (could use a better one however)
Racetronix 255 fuel pump with upgraded wiring harness
Rail mounted fuel pressure gauge
Braided stainless steel fuel lines (only in the engine bay, stock hardline back to the fuel tank)
Dual LS1 fans
160 Thermostat
All new sensors
New distributor
new ign coil
New MAF
New AC compressor (blows nice and cold)
New radiator
New waterpump
5-spd manual with Pro 5.0 Shifter. Nice firm shifts. No griding, popping out of gear, etc
02 Camaro SS 10- bolt 3.42 Torsen Posi rear end
3" Aluminum Inland Empire driveshaft
Koni Yellow adjustable shocks on all 4 corners
Upgraded front dual piston brakes from same 02 Camaro SS
Drilled/slotted front rotors
Eibach Sportline lowering springs
Founders Caster Plates
Upgraded solid steering shaft (Elmiates rag joint)
Jegs subframe connectors
Edelbrock rear boxed control arms and tubular panhard bar
BMR rear lower control arm relocation brackets
Corvette C6 wheels 18 front 19 rear
New rubber and hard brake lines
New front ball joints
All black interior
4th gen front seats. Previously gray but dyed black, fading a little. No rips or tears
All digital dash
No back seats
Driver side carpet has a tear
Headliner has been redone, looks great
Newer windshield
4th gen Trans Am center console
Working power antenna
Working rear power hatch release
Door locks work
Recently tinted windows. 4% rear, 16% sides
There is quite a bit I'm forgetting but it's an overall solid daily. Routine 3k mile oil change.
I have tons of paper work and receipts for everything, factory books, service manual, etc. Tons more pictures and videos. Know this car inside and out.
Asking price is $4000. I'm open to any serious, reasonable offers. Clean FL title in hand.
Also have the original 87 gold crosslace wheels with decent tires.
Driveline:
Lt1 camshaft
30lb injectors
Dual LS1 fans
160 Thermostat
All new sensors
New distributor
new ign coil
New MAF
New radiator
New waterpump
All black interior
All digital dash
No back seats
Newer windshield
Door locks work
beths91camaro
10-02-2016 05:57 PM
1989GTATransAm
Southern California Area
02-04-2016 11:26 AM
madsv1000
01-29-2016 10:35 PM
seanof30306
Wheels and Tires
01-23-2016 03:32 PM
