[PA] 1987 Trans Am $6000 OBO
Car: 1987 Trans AM
Engine: 355 4-bolt, L98 heads, Holley 650DP
Axle/Gears: 3.70 9-bolt
Thinking it may be time to sell the bird. I've owned it for 5 years and it sat for 4 of them. In the last year i've done a new motor, transmission, rear, interior, gears, wing, etc. Here's a list of everything I've done to the car.
I have a ton of money invested in this thing. The body has 150,000 on it. the new motor and rear has less then 2000 on it. I'm looking for around $6000 OBO.
Motor:
ATK 355 Short block
Melling high volume oil pump
L98 Corvette heads with hardened springs
Comp Cam Camshaft, Hydraulic Roller Tappet, Advertised Duration 288/294, Lift .520/.540
Carb spacer
New timing set
New oil pan
New pick up
Victor Jr. intake manifold
Holley 650dp carb
Scorpion 1.5 ratio roller rockers
Cast aluminum valve covers
Transmission:
Built by dynamic transmission
3000 10 inch non lock up stall converter
Stage 2transgo shift kit
Dana tru cool trans cooler
Have all paper work on trans way to much to list here trust me it will hold up to over 700hp oh and its a 700r4
Suspension:
Eibach lowering springs
Founders LCA's
Founders adjustable panhard bar
KYB AGX rear shocks
KYB front struts
Alston frame connectors
Exhaust:
SLP headers with AIR pipes cut off and welded closed
Cat delete and 3" pipe
Edelbrock 3" exhaust
Body:
Gold crosslace wheels
New tires on front
New fiberglass wrap around wing
New door frame and door weatherstripping
New window sweeps
Interior:
99 Camaro seats
Newer dash pad
B&M ratchet shifter
New rear carpet
Floor pans dynamated
Rear:
Borg Warner 9 bolt
3.70 gears
Ratech solid pinion spacer
TA specialties diff cover
Replaced the posi with a low mileage one
Fully rebuilt less than 1500 miles ago
Brand new PBR rear disc upgrade with correct proportioning valve.
Misc:
New front rotors, wheel bearings, calipers, and pads.
GM AC delete box
New heater core
140 speedometer with correct gears at transmission for the 3.70 gears
Electronic fuel pump has been removed and a manual one has been installed in the tank. The proper way, NO TRAP DOOR
New 3" cowl fiberglass Harwood hood.
Comes with extra set of American racing wheels and tires
Extra Electric fan
Extra custom made dual exhaust
Extra Hedman Headers
The Bad:
Reverse lights are not hooked up to shifter
Horn does not work through Grant steering wheel
Motor:
ATK 355 Short block
Carb spacer
New timing set
New oil pan
New pick up
Holley 650dp carb
Transmission:
Suspension:
Founders LCA's
KYB AGX rear shocks
KYB front struts
Exhaust:
Body:
New tires on front
New window sweeps
Interior:
99 Camaro seats
Newer dash pad
B&M ratchet shifter
New rear carpet
Rear:
Borg Warner 9 bolt
3.70 gears
Misc:
GM AC delete box
New heater core
Extra Electric fan
The Bad:
Car: 1988 Iroc Z28
Re: 1987 Trans Am
This is a nice care guys i have seen it in person hate to see you sale it dave I'd think about it but you know my shops full and another on the way . That and i aint sure that bird wpuld get along with all the camaros. Any way bud good luck . If any one wants to look at the underside let me know you can run it up and put it on the lift
Car: '86 IROC-Z
Engine: LG4 305-4BBL
Car: 1987 Trans AM
Re: 1987 Trans Am $6000 OBO
Everything has been done in the past two years. I'm located in southeast PA about 40 miles north of Philadelphia.
dpmalibu
04-29-2016 12:04 PM
dpmalibu
04-29-2016 12:04 PM
Thirdgen89GTA
Wheels and Tires
04-19-2016 05:52 PM
