Restoring 1986 T/A
Old 06-16-2004, 12:12 PM
RedTitan24's Avatar
Restoring 1986 T/A
I am trying to restore a 1986 T/A Firebird. Where can I find information containing the original interior colors and exterior?
Old 06-16-2004, 03:58 PM
TestyAmoeba's Avatar
Car: 1989 Firebird Formula
Engine: TPI 350 Vette motor
Transmission: 4spd Auto
Correct me if I'm wrong, but isn't that info in the VIN#?
Nate -
Old 06-16-2004, 04:00 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No it's not in the VIN.
However, it is on the trim tag on the radiator core support. Right there in plain sight, in raised sheet metal letters and numbers.
Old 06-16-2004, 04:02 PM
I knew it was with some numbers somewhere....
Old 06-16-2004, 04:04 PM
RedTitan24's Avatar
Well how do I then decode the numbers and letters? I dont think those are there because the individual who had this car before me redid alot of work in the engine. He put in a 350 and took out the 305. If that plate is not on there, where else could I find it?
Old 06-16-2004, 07:40 PM
85silverz28's Avatar
Car: 1988 iroc z
Engine: 5.7 liter
Axle/Gears: 2.77
If u still have ur rpo codes in the center council ( if i remember right) that should tell u also. I decoded mine and i think it was there. But not 100% sure.
Old 06-16-2004, 10:00 PM
Mr. TurboTA's Avatar
One good item to get for your car, besides the Pontiac Service Manual, is the Pontiac Product Book for the year of your car.
It comes with most of the option codes, what's standard, what are options. In the front of these book, it even gives samples of the seat material, in the various colors.
In the section on your car, it will even give you body molding info, as well as decal colors for the color of your car!
Trying to help,
George
Old 06-17-2004, 09:32 AM
RedTitan24's Avatar
Thanks for all the info. I was hoping that there might be a easier way. I looked last night around the radiator and couldnt find any kind of metal stamp. And the middle console lid is missing.
Old 06-17-2004, 06:47 PM
Guest
Guest
Posts: n/a
There's no trim tag on the car, you need to consult the RPO list in the console.
The colors in there now might be the original ones. Should be able to look those up in a book.
Old 06-18-2004, 12:13 AM
Car: 1988 iroc z
Engine: 5.7 liter
Axle/Gears: 2.77
If its the tag i think there talking about is on the core support more twards the pass. side of the car. Next to were the fan shroud bolts to. Should have six #s on it. But it could be missing. Its rivited on, so very easy to remove.
Old 06-18-2004, 09:51 AM
RedTitan24's Avatar
If I find those codes, where would I decode them at?
Old 06-18-2004, 11:15 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
paint store
Old 06-18-2004, 06:07 PM
82RECAROTA's Avatar
Re: Restoring 1986 T/A
Interior Trim Colors for '86:
Black - color code 19
Light Saddle - " " 62
Russett - " " 68
Dark Carmine - " " 72
Dark Gray - " " 82
What exterior color is your T/A?
As I think madmax was trying to say, NO trim tag on '86's. '85 was the last year.
Old 06-18-2004, 06:15 PM
RedTitan24's Avatar
The exterior is Red. There is also a silver color on the ground effect or whatever you call them.
Old 06-18-2004, 07:08 PM
82RECAROTA's Avatar
SRKLEGIN
10-29-2015 06:38 PM
2012sergen11
10-13-2015 07:38 PM
Thornburg
Aftermarket Product Review
10-06-2015 12:04 PM
Aaronv808
Members Firebirds
09-30-2015 12:55 PM
Gordonr1973
09-29-2015 11:59 AM
Quick Reply: Restoring 1986 T/A
