questions regarding exported cars
Old 07-30-2009, 11:26 AM
72vega's Avatar
Car: 2008 Silverado, 73 LeMans, 1987 GTA
Engine: 4.8, 350 Pontiac, 350 LT1
Transmission: 4L65E, TH350, T56
Axle/Gears: 3.42, 2.73, 3.42
im stationed in germany and i was searching on the ebay.de site and found this
http://cgi.ebay.de/Pontiac-Trans-AM-...d=p3286.c0.m14
if a goto translate.google.com you can put in the link and translate it. it says it has 22900 km and the photo of the gauges show it has a kmh speedo with a small mph scale, so i wonder if it is still miles or kilometers on the odom. ( cause then it would have only 14k miles...). also would it have metric gauges like Celsius temp and kPa oil press.? how many were exported and is info of this available anywhere? what i am really getting at is would this be worth the 6900 euro (or 10K) for it? it has such low miles and is so very clean... also would it (besides the gauges) be the exact same as a US version and be able to be brought back to the US when i get sent back with no problems for importation? thank you for any and all input.
Old 07-30-2009, 06:33 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: questions regarding exported cars
im not positive, but the odometer most likely reads KM, not miles. I dont know about the other guages.
Old 07-30-2009, 06:40 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
i think some of the exported cars had different emissions systems due to differing laws. dont know what the differences are or if they will pass emissions testing in the states. canada dont have emissions testing so i have no idea how it all works, just that it exists.
Old 07-30-2009, 07:49 PM
IROCZ28KevinZ's Avatar
Car: 1991 Z28 vert, 1988 GTA
Engine: 305 TPI, 305 Carb-finally runs!
Transmission: TH-700R4/BW WC T-5
Axle/Gears: 3.73 posi 4th gen 10-bolt/BW 9 bolt
Dude,
It has been retarded quiet tonight at work, been running the pinouts on an 85 wiring harness to see if it'll work in my car LOL. But I took a break and did some digging. Take a look at the last post here:
https://www.thirdgen.org/forums/tpi/...i-engines.html
This post seems to deal mostly with Canada, but check it out anyway, might have some customs info for ya:
https://www.thirdgen.org/forums/thir...ck-across.html
Here is a Army guy that lives in Germany now, maybe he can help you out?
https://www.thirdgen.org/forums/memb...c-germany.html
And I found THIS little gem, just by doing a quick look-see, I think it may be a huge help:
http://www.hqusareur.army.mil/opm/cars.htm
From what I gander, the best thing to do is check the car for EGR, 02 sensor, and AIR pump/Cat. Like we discussed earlier, I can't see the rest of the car being too different; they were all built on the same lines. It'd actually be funny if that 91 TA was built right before or after my vert LOL.
Old 07-30-2009, 08:13 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
buy it but give them a counter offer but dont let it go.
Old 07-30-2009, 08:42 PM
okfoz's Avatar
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I think due to the age it should not be a problem importing the car. You may be able to import it into the US, but depending on where you go IE California you may have to have the car emissions tested and it may not meet emissions in some areas. I do seem to remember that Porsche wanted to import the 959 in the 80's but could not because they did not want to total some to see if they would meet requirements. So Bill Gates had to wait several years before he could actually get his car....
I would definitely check into it, and not take my word for it, but I would not see why there would be many problems as the car should be basically the same car as the one that was intended for the US. you might have to install a catalytic converter or something along those lines to make it legal...
MustangBeater20
10-29-2022 09:20 PM
Exxon Limited
Camaros Wanted
22
12-21-2015 10:36 PM
jharrison5
08-19-2015 05:53 PM
Exxon Limited
08-09-2015 08:13 PM
Quick Reply: questions regarding exported cars
