Subframe problems
Old 03-16-2010, 11:38 AM
nemisis02's Avatar
Car: 1986 Trans Am and 1995 Sierra 1500
Engine: 350 small block in both vehicles
Subframe problems
I have found that the sub frame on my Trans Am has rusted quite a lot. Is there an aftermarket sub frame replacement or is fabrication the only way to fix the problem.
Old 03-16-2010, 11:45 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
Re: Subframe problems
pictures are worth a thousand words...
Old 03-16-2010, 12:14 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
very true. let's have a look at what you're working with and go from there.
Old 03-16-2010, 12:32 PM
Stephen's Avatar
Car: 87 GTA
I've never seen an aftermarket subframe repop, so regardless of what rust you do have? A custom rebuild is most likely your only choice. The question is though.....How far gone is it? And how much will have to be rebuilt?
Old 03-16-2010, 12:40 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Stephen, my thought was that when someone says "subframe" they may very well mean floorboard, rocker panel, or even lower radiator support. As you said, it could be one small region that can be repaired, or at the point where the car is a lost cause. I've seen theads totally change direction once pictures are introduced, so why not just cut to the pictures so we can give better advice.
Old 03-16-2010, 12:54 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
This is a good idea right here. Now I have seen much of the sub-frame totally replaced through custom fabrication. You may also be able to find a car that's pretty well trashed with an intact sub-frame. You can move over the parts you need but you'll either need mad welding skills or you'll have to spend a ton of money at the body shop to fix it.
Old 04-03-2010, 01:24 AM
nemisis02's Avatar
I will try to get pics, but am using as a daily drive at the moment. I can say this though 2-3 inches ahead of the connection for the rear control arm on the driver's side was rusted so bad that you could stick your finger in one side and out the other. Welded some new metal in to that area for now but not gonna hold for long I don't think.
Old 04-03-2010, 01:40 AM
87WS6's Avatar
I've seen new subframes custom fabricated, so I know it can be done.
Old 04-04-2010, 11:29 AM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
scroll down to the bottom of the page there about 700 each
http://www.classicindustries.com/con...&currentPage=2
Nick McCardle
09-10-2015 08:36 PM
383cam
09-09-2015 06:01 AM
Glowsock
09-06-2015 06:40 AM
andy74
09-03-2015 08:41 AM
greenyone
09-02-2015 03:39 PM
Quick Reply: Subframe problems
