Some '85, yellow IROC, updates.....
#201
Administrator
Re: Some '85, yellow IROC, updates.....
ROFL, that's funny. Though I look at this board as a preservation type of board already. Body and Interior are somewhat included in that. But no, we cannot make a board for you two. Yet. It might also result in two people owning half of the remaining mint Third Gen population.
BTW, the Parts for Sale board now contains this in the description, "Please do not part cars that don't deserve it. Remember, don't crush them, restore them!" Better than nothing I guess, but I hope it makes people realize what they're doing a little when a car can easily be saved.
#202
Transmission: World Class T-5
Axle/Gears: BW 3.45
That's a great first step!
#203
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
BTW, the Parts for Sale board now contains this in the description, "Please do not part cars that don't deserve it. Remember, don't crush them, restore them!" Better than nothing I guess, but I hope it makes people realize what they're doing a little when a car car be easily saved.
With that said, apparently I am not allowed to sell either of my TAs because Charlie will feel left out. Now, if Charlie wanted to BUY one of my TAs....well? I gotta prospect the sale...
Just tossing it out there...
#207
Axle/Gears: BW 3.45
Took the T-tops off for the first time and took it for a spin. Is it possible that this car has never been driven with the tops off? The straps look unused and weren't even attached. Huh. Anyway, it's sweet ride on a beautiful day, with the tops off. Still smells like I'm burning off some mouse poop/nesting in the muffler. The exhaust note seems to mellow as I drive.
I have noticed that the trans doesn't shift as expected at full throttle. 1st to 2nd might not come until over 6000 RPM. I've adjusted the the TV cable in the recommended manner several times. I'm not sure if it's a trans problem, or the right rear tire is just spinning??? I also noticed that on aggressive downshifts, the engine sort of freewheels for a second, almost like the trans is slipping. Again, could be spinning rear tire?
#208
Axle/Gears: BW 3.45
Definitely not tire spin. It does it now even at light throttle. It's like it doesn't want to upshift. Sounds like the same problem Cerberus had with his.
Also, the replacement fuel pump got very noisy today and I smell gas from back there. Not having a good day.
#209
How's the fluid level? Did you ever find the source of the trans leak.
#211
For the trans, sounds like it's time for a T5 swap!
#213
TV valve could be sticking in the trans. It just takes a very small piece of dirt or metal shaving to restrict it's movement and cause late and inconstient shifting.
You should really drop the pan, clean the magentic, and put in a fresh filter. Also, I noticed the latest GM Dexron VI synthetic fluid can really improve shifting performance. I just upgraded to it in my Silverado and my IROC.
http://paceperformance.com/i-5131365...container.html
This is all just a guess without driving the car and looking in the pan. Can you youtube the shifting?
#214
Car: 1985 IROC
#216
Car: 1987 Camaro IROC-Z
Engine: LB9
When I got my old 87' sport coupe it had awful shifts, hung, downshifts sucked. I ended up romping on it quite abit then one day it slammed a downshift, broke a tire loose on it and it was perfect ever since.
probably not recommended service, but it worked good for me.
#217
My 91 TA would do a similar thing but it was pressure. It would build up so much pressure that you could hear the fuel tank "oil canning" as it expanded. I put a new cap and tank vent on it and I disconnected the vent line from the charcoal canister and blew air through it to make sure it was clear. I also put a used charcoal cannister and purge solenoid on it I had laying around and the problem went away.
If I were you the first things I'd do is replace the tank vent and put a fuel new cap on it and go from there. If the fuel odor is strongest inside the driver side rear wheel well you can guarantee the vent is bad. Try those simple things and let us know what happens.
As for the trans..... You know you want to put a T5 in it. It will be our little secret, I won't tell anyone over on the "Preservation and Hoarding" board.
#218
Axle/Gears: BW 3.45
Well your whoosh could be positive or negative pressure so bear that in mind.
How do fuel caps go bad????
#219
Car: 1985 IROC
#220
I've seen the o-ring in them crack and leak. Some are vented and some are non-vented as well. I'd say if you are getting the whoosh when you open the cap it's probably good, but they are normally only a few bux so I tried one. I'd put the tank vent higher on the priority list than the fuel cap though..
#221
Axle/Gears: BW 3.45
Where is the tank vent, exactly?
#222
Car: 1985 IROC
Axle/Gears: BW 3.45
Okay, good, I thought that there might be something on the tank. I was under the car yesterday, and the canister did give me a whiff of gas smell.
#224
no the tank vent is attached to the chassis of the car just inside the "frame rail" in the driver side rear wheel well. It is hanging on the same bracket that your rear axle to chassis brake hose attaches to. It is a white or gray plastic round thing(about 2" in dia) that will some slits at the bottom of it with a spring loaded diaphragm inside.
#225
Axle/Gears: BW 3.45
#229
Axle/Gears: BW 3.45
Did you, really?
I will admit to blowing/sucking certain clogged lines. But it's one thing to get a mouth full of windshield wiper fluid and it's another to get a mouth full of what ever is in that line.
Maybe, I'll just squirt some Chemtool or Seafoam in there....
#230
No I'm taking the valve off the car, unclamping it from the vent hose. cleaning it with brake parts cleaner and blowing it dry with compressed air. Then blowing or sucking through it. It takes longer to get under the car than it does to loosen the clamp and take the valve off.
#231
Axle/Gears: BW 3.45
Okay, remove and clean. That makes me feel better.
#232
Axle/Gears: BW 3.45
You know which guy I am? I'm the guy that spends a couple of hours trying to undo the 15 minutes I thought I would save.
The turn signal lamps. To get them clean, it's best to remove them, let them soak in soapy water, rinse/repeat, rince/repeat. Of course, I figured I'd save afew minutes, leave them on the car and squirt Simple Green into the drain holes, let it dwell and then rinse. It was working, but slowly. So, I thought, what if I sprayed just a little squirt of carb cleaner in that drain hole? Well, it sure didn't get anything cleaner. It simply fogged up a portion of the lamp, dripped out the bottom and discolored/melted my decal stripe. Damn. It.
So, I did end up removing both lamps, soaking them in the sink, like I should have in the first place. I still have a partially fogged up driver's lamp though. BTW, while everything was apart, I figured I'd change the light bulbs. Apparently, the bulbs need to be oriented in the sockets a certain way for the turn signals to work. I figured that one out AFTER I had every thing all buttoned up.
#233
Damn Charlie that sucks to hear. Believe me if I had a second set of NOS parking lights Id practically give them to you wholesale. That car deserves new ones. Unless of course if you can get yours cleaned enough to your liking.
Now I know why you asked about the "stripe only" kit the other day.
#234
Axle/Gears: BW 3.45
Yup!
I think If I put that one in the oven and let the glue soften, I can take it apart and polish it out. I know it's easier to just get a new one, but I get a weird satisfaction if I can restore the old one.
#235
Axle/Gears: BW 3.45
I was gonna get new stripes anyway, but the one I ruined was, (as luck would have it), the only perfect one on the car. Duh.
I also noticed that the temp gauge needle is stuck again.
You know this car is not very appreciative of the TLC I've lavished on it. I might have to park it out in the rain for afew days, just so it can get an attitude readjustment.
#236
Axle/Gears: BW 3.45
So, anyways......
Yesterday this PDR guy comes to my house. He was highly recommended by a friend with many old and expensive cars. Took me forever to get an appointment with him. I figured, you know, he'd take out the dings on both my yellow IROC and my '83, while he's here. What a disappointment. He couldn't get access to anything on the '85 and didn't even try on the '83. I offered to remove the door panel, but he said it wouldn't make a difference.
I'm thinking, this is just ridiculous. I'm willing to pay professionals, money to do their magic on my cars, and no one can get it done. Four PDR guys have tried and failed on my '83. One guy said that if I delivered the car to him with the door panels and interior plastics removed, he'd do the '83 for $900. Come on. I mean, do I have to learn how to do it myself or something?
So I decide to look up the guy that Scott Moyer mentioned earlier in the thread. I called, but it was probably too late in the day, and I wouldn't have time to stop by there for several weeks. I perused his website and noticed that they also do glue pulling PDR. Huh, that's interesting. Interesting because I bought a cheap, glue pulling PDR kit off of ebay a couple of years ago, and after getting poor results, just figured the whole concept to be a bunch of BS. But after seeing pictures of Scott's highly recommended PDR fellow doing it, I figured I should do more research. I watched a whole bunch of Youtube videos on glue pulling PDR and really got a better feel for how it's done and decide, what the heck, I'd give it another try.
The driver's door of my IROC was pretty badly banged up with dings and a couple of pretty big dents. What do you know, after watching all those videos, I became one with the sheetmetal and pulled 90% of the dents/dings out with my glue puller tabs. I even made some headway on my '83. I have to get one of those plastic tap downs, because one or two of the repaired dings have small peaks now, and there are a couple of spots I want to work a little more. I would have easily paid that guy $250-$300 to get it to where it is right now, though.
#237
If you get tired of dealing with all of the idiots you may want to stop by my brother's shop and see what he can do for you. He truly is a master of the craft. Just let me know if you are going to stop by ahead of time so I can tell him you are coming.
http://www.myabcspace.com/allautobody/
#238
WHAT??? You attacked this yourself? You need to be very careful with this. The cheap tool you buy at the store uses a bridge technology. The problem with that is that it creates two pressure points while pulling the center up. The reason this tool works on TV is because most people don't see the impressions left in the metal by the two support locations. The other problem you have that you can over pull and create a high spot. Without the proper tools and techniques, you can quickly create a mess out of a small dent.
It's very discouraging that these guys can't do the dents on the doors. I have done them on my car and others. They aren't the easiest to access because of the center brace, but they are doable. Please be very careful tapping these down. A very light tap is all you need. Start at the highest point and very lightly tap it down. The problem you have is that you don't have a reflection board. The reflection board has a fogged line on it that you align the edge of the line to the dented area. You need to look at the metal, not the board. The line allows you to see the depth of the dent or the height of it.
DO NOT STICK ANYTHING DOWN THE WINDOW CHANNEL TO PUSH DENTS OUT! You can easily break the window, you WILL scratch the glass, and any pushing you do on the dent can, and more than likely, will make the damage worse and possibly require a body shop to fix. The glue puller is less damaging as it pulls a larger area. If you try to push a dent yourself with incorrect tools, you can crack the paint and will cause high spots that can't be removed.
Sorry Charlie! I drove through the Chicago area with my tools a few weeks ago. If I remembered this issue with the car, I would have stopped in to fix them. Let me do some digging and see if I can locate some people in your area that can do the cars.
#239
Axle/Gears: BW 3.45
This is NOT one of those bridge ones. All the pressure is on the tab. It has sort of a plastic cage where you apply pressure with a threaded wing nut. I think it would have been easier with a better dent lifter or slide hammer though. And it's not very effective on very small, creased dings.
Thanks for the tips on the tap down. I may practice on my wife's 140K mile Durango.
#240
Part of the problem with the dent pullers is that they don't take into account a sharp dent. If you try pulling on a sharp dent, you'll lift the entire area except the very middle or the deepest part. By doing this, you have now tightened up the center of the dent to the point where it can't easily be repaired. I've reached out to some people and I'm waiting on a response. Send me your contact info and I'll provide it to the techs that contact me. I will also need to know where you are so I can tell them. Also, can you send me the side angle shot of the 83 you sent me before that shows the dents? Thanks
#241
Axle/Gears: BW 3.45
Spoke to the original owner yesterday as I try to piece together the car's history. Nice lady from Minnesota. Her family was big into circle track racing, with her dad owning a track and being a former racer. They would attend IROC races, and that's where she and her husband decided to get a yellow IROC.
The car wasn't ordered, but was located from a dealer some distance from her with the exact options she wanted - that being T-tops and tan interior. She drove it in nice weather until about 1990/91, when she traded it in on a Lincoln.
She told me that whatever she finds on the car she'll send to me. It's kind of funny, that all of the former owners know each other. She called me back to ask if the car still has the Minnesota Collector Car plates which were put on when new. They are. How does that work in Minnesota? Can you do that on a new car?
#242
#244
Axle/Gears: BW 3.45
I power washed (again) the undercarriage of my apparent dirt road IROC. I'm starting to see some isolated clean spots under there.
Today I noticed that my driver's side rear shock is black and my passenger side is yellow. It seems that most early IROCs had yellow Bilsteins and later ones had black Bilsteins. I've never seen one with one of each. I have no reason to believe that one or the other has ever been replaced - but you never know.
Any thoughts?
Any thoughts?
#247
You have a good selection of nice stock thirdgens in your collection. I was wondering if you could tell us your driving impressions for all 3 of your cars?
I'd really be intrested in knowing the comparision between your '85 and '89 IROC's. I know the '89 should be faster with the better exhaust and cam. But your '85 has the highest power LB9 that GM ever bolted to the 700r4. At least stock anyway.
I've just always been curious about those '85 LB9's. Most people that I've seen that have had them (that were in proper running and working order) have said they had very good performance.
I've also been watching what '85 IROC's have been going for on ebay and other sites. Sometimes it's a toss up between an '85 LB9/auto car or an '85 L69/5-speed car on what some people think is better or more valuable stock for stock.
#248
I've never known any other state to issue collector plates before 25 years besides MN, which is kind of nice. Unfortunately though ours are now el-cheapo screen printed rather than stamped like they used to be.
#249
Yeah, I have the stamped Minnesota Collector plate. Too bad I can't use it in FL. Florida requires a car to be 30 before it gets a collector/antique plate. They used to have collector status, but got rid of it a few years ago. Maybe I should register the car in MN again and put my collector plate on it.
#250
30? That's rough.
Ours also changed from 6 numbers with a hyphen to just six numbers:
Looks a bit cheap and doesn't have the "collector" feel like the stamped ones, but still better than the ugly regular plates we have. More than anything I'm just glad I can legally run no front plate now, probably the biggest benefit.
