Locating my build sheet
Old 01-10-2013, 11:31 PM
87 mm5's Avatar
Car: 87 IROC
Engine: LB9
Transmission: 5 speed
Hey guys! I'm trying to locate my build sheet for my 87 Iroc any ideas where I can find it?? I already looked under both front seats no luck. HELP
Old 01-11-2013, 11:39 AM
lozantius82's Avatar
Car: 89 Camaro Iroc Z
Transmission: MK6 World Class T5
Axle/Gears: 9 bolt had 3.45's, now 3.27 gears
Re: Locating my build sheet
Under the rear cargo carpet?
Old 01-11-2013, 12:08 PM
82RZ's Avatar
Car: 2000 SS Camaro LS1
Engine: 347 cu in mild mods
Axle/Gears: 3:42 or 4:10 depends on what I'am d
Under rear seats and seat back.
On top of inside heater box.
Old 01-11-2013, 01:37 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
I think they played Hide&Seek with them,I've even herd they could be on top of the fuel tank,but not all cars came with them for some reason or another.
Old 01-11-2013, 01:38 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
In the landfill outside of Norwood Ohio. It may be under 20ft of fill. Good luck.
Old 01-11-2013, 01:57 PM
mantaguy's Avatar
Engine: 5.0 EFI
Old 01-11-2013, 07:48 PM
davidj3594's Avatar
On my 87 vn iroc it was under the drivers seat .or what was left of it on. A junkyard car I found one under the carpet.just a few locations but I've heard of people finding them in strange places.
Old 01-11-2013, 09:42 PM
two-if-by-sea's Avatar
Car: 89 RS Vert, 89 Formula, 89 Bird
Engine: L03, TBI 350, none
Transmission: 700R4, 700R4, none
Axle/Gears: 3.42, 3.45, none
I found one under the radiator overflow bottle of my current car. The bottle had a small crack, and I was surprised to find it there when I replaced teh bottle. But it not for my car, it's for the car that went down the line ahead of mine. VIN is one less than mine.
Old 01-16-2013, 01:40 PM
Junqueboi's Avatar
Very interesting information about the sheet under the coolant bottle...
Can anyone confirm (firsthand only) finding a build sheet for a 3rd-gen Camaro/Firebird in any location OTHER than under the two front bucket seats or under the carpeting? If so, which assembly plant?
I'm asking because I've taken lots of these vehicles apart at my favorite scrapyard and as with my own fleet, NEVER found a build sheet in any location other than under the seats or carpet. I very seldom find build sheets (or even trim sheets) in 3rd gens.
Thanks in advance.
Old 01-18-2013, 09:37 PM
nascar2496's Avatar
Car: 1986 Camaro IROC-Z
Engine: 305 tpi
Transmission: BW t5 W/ short shifter
Axle/Gears: 9 Bolt 3.27 posi
a buddy of mine of mine deals with tons of f bodies, we find the sheets in the doors, trunk, headliner and sometimes behind the dash. its very cool to see. I found a build sheet in my old blazer in the headliner.
Old 01-18-2013, 10:54 PM
drjewalton's Avatar
Car: 1956 Chevrolet 210
Engine: Chevy 305 V8
Transmission: TH350
Axle/Gears: Posi 3.42
Found mine under the rear driver's side seat cushion (which I had to remove) while I was changing the rear shocks.
Old 01-19-2013, 06:40 PM
FJA1791's Avatar
Car: 1990 IROC-Z
Engine: 350/IRON DART 200
Transmission: POWERGLIDE
Axle/Gears: MOSER 12 BOLT 4.88
Found mine in spare tire well
Old 01-19-2013, 11:10 PM
Our83Z's Avatar
Car: Black '83 Z/28
Mine was under the carpet in the floorpan in front of the right rear seat. Problem was it was stuck to the floor by the sealer that was used in the floorpan at the factory. I tried to remove it but couldn't without damaging it so I photographed it then put the carpet back over it where it will remain for future generations to find.
Old 01-20-2013, 04:45 PM
82RZ's Avatar
Understand that there was no Factory requirement to place the Build/Broadcast Sheet in the car.
Most wound up in the Trash or on the floor at the final assembly line.
Old 01-22-2013, 09:08 PM
Michael Knight's Avatar
Car: 1985 Pontiac Firebird
Engine: 2.8 v-6
I found one under the drivers seat in the set of PMD seats I pulled from the salvage yard. It was off an '82 S/E. My '85 has yet to be found. I've looked everywhere except the top of the fuel tank. All of my interior including the heater assy is out so that's the last spot left.
Old 01-23-2013, 12:40 PM
Engine: 2.8 v-6
Here's a shot of the build sheet I found for the '82 s/e
Old 01-31-2013, 11:06 PM
MrPackstin's Avatar
Car: 1989 GTA
Engine: 5.7 w/Paxton
I found my '89 GTA build sheet today under carpet on the passenger side in the floor pan (where rear passenger's feet rest).
Old 01-31-2013, 11:15 PM
Blue1990camaro's Avatar
sometimes under the hood insulation, thats where i found one in a 91 rs and one in my 92 cavalier z24
gfs car found it in the spare tire well
Old 01-31-2013, 11:21 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I have a 92 Z24 vert and the huge Broadcast Sheet was under the hood blanket but I havent ever looked for the build sheet.
Old 02-01-2013, 10:57 PM
Thats where i found mine on my 92 z24, i gues its the broad cast sheet, wasnt really readable and was falling apart
Old 10-30-2013, 03:22 PM
Avarice's Avatar
Car: 1987 Camaro Z28
Engine: LB9
my 87 z28 had it below the driver seat under the carpeting
Old 10-30-2013, 08:53 PM
minigunz's Avatar
Car: 1992 firebird
Engine: 3.1.... soon to be... bigger.
Transmission: 700r4, looking for t5
Axle/Gears: I havent a clue.
Anybody ever found build sheets from 91 -92 cars? If so, where?
Old 10-31-2013, 12:34 PM
88monteSS's Avatar
Car: 92 RS/97 K3500/07 ISS
Engine: LT1/454/LS4
Transmission: 4L60E/4L80E/4T65E-HD
Axle/Gears: 2.73/4.10/3.29
I have the one from my '92, but I couldn't tell you where it was found originally, I found it in the folder the po gave me along with the window sticker.
Old 01-21-2014, 04:22 AM
91camarosRS's Avatar
Car: 02wrx/88 rs
Engine: 2.0L turbo/nothing yet!
Transmission: 4eat/waiting on a t56
Found what appears to be a build sheet under my cargo carpet. But it got wet and un readable
Old 01-21-2014, 10:53 AM
RockinGTA89's Avatar
Car: 1989 GTA Trans sold :(
Engine: 350 TPI L98 (B2L)
Transmission: TH700 R-4
Lucky you....I literally removed the seats and carpet on my car a few years ago and to no avail. was i able to find it. Or even the trim sheet. I never did look near the dash where the heater box was. Never would think to look there.
I mentioned before that someone on ebay was selling a 89 GTA, he was the original owner of the car and had a photo of the build sheet. When i asked him where did he find that on his car, he told me that it wasn't on the car, however it was given to him "intact" from the dealership(!?) Never heard that before!
Old 01-21-2014, 09:51 PM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
On my 88 the build sheet was under the drivers side seat tucked into the seat fabric. The only way to see it was pull the entire seat out of the car and flip it over.
Old 01-21-2014, 10:31 PM
RyanJB's Avatar
Car: 92 Firebird, 91 Trans Am
Engine: L31 with HSR, LB9
Axle/Gears: '99 10 bolt 3.90, '01 10 bolt 3.42
The ones in my 91 RS and my 92 Bird were both in the locking container in the trunk and also in the center console I did not find the one under either driver seat
Old 01-25-2014, 11:53 PM
David M's Avatar
Car: '84 Z28
Engine: L69
'92 build sheets were just thrown on the passenger side floorboard. They usually got tossed during PDI (Pre Delivery Inspection) at the dealer. In '92 I was working at a Chevrolet dealer and was good friends with one of the PDI guys. He saved all paperwork from every '92 Camaro we received. Thanks Randy!!
Old 01-26-2014, 03:55 PM
88monteSS's Avatar
Engine: LT1/454/LS4
That would probably explain why mine is in such good shape (no signs of being folded or wrinkled at all), it was probably saved & given to the original buyer by the dealer.
Old 03-06-2014, 09:31 PM
cs2000's Avatar
I found my build sheet for my '82 pace car under the rf seat, and under the lf seat on my '83 Z28 (both Van Nuys cars) My '89 and '91 that I bought new were just thrown on the floor ( I rescued them before they were cleaned for delivery) I never found one in my '85 Trans am or my '87 Convertible
Old 03-07-2014, 09:51 AM
sweetmelissa's Avatar
Car: 1989 Iroc-Z
Engine: TPI 350
Axle/Gears: 3:27's
I have my trim tag !! My car is also a Van Nuys Car !!
Old 03-11-2014, 08:50 PM
89FormulaGirl's Avatar
Car: 1989 Pontiac Firebird Formula T-Top
Engine: 305 V8 5.0L
Transmission: Automatic
Mine was under the back seat (1989 Pontiac Firebird Formula T Top, Van Nuys Assembly Plant) if that helps anyone.
Old 03-12-2014, 04:15 AM
((Mike))'s Avatar
Car: 1969 RS Z28 X33 Norwood built
Engine: 383 Stroker
Transmission: T10 4 speed
I recently took out the rear seat cushions poking around in my car. All I found was a gas receipt from 1987 when Gas was 94 cents a gallon. My friend found his build sheet in his spare tire well. His was an 89 IROC.
Old 03-13-2014, 02:27 PM
71nova's Avatar
Car: 1990 Iroc Z
Axle/Gears: 9 bolt
Is this a build sheet? If so I found it between the foam and cover on the bottom of my drivers seat.
Old 03-13-2014, 03:14 PM
mantaguy's Avatar
Engine: 5.0 EFI
No that's not it,but keep that piece,it goes with the paperwork.I'm telling ya,they play hide and seek with that build sheet.
Old 03-13-2014, 03:42 PM
kymmee's Avatar
Both my 82 birds had them under the front seat cushion, one on the drivers side, one on the passenger side. Both are Van Nuys cars. Found remenants of one under the carpet imprinted on the passenger floor pan of the 84 Z 28. That car is long gone, but it was a Norwood car. Haven't found anything in my two 89 birds.
Old 11-24-2014, 01:01 AM
92rsvortec350's Avatar
Car: 92 rs z28 clone
Engine: forged 350
Transmission: 700r4 fully built
Axle/Gears: moser axles eaton posi 3.73 gears
My 92 Camaro had it behind my pass. door panel.
Old 11-24-2014, 03:10 PM
92GTA's Avatar
I've ripped my entire 92 GTA apart over the years, never found it. I ended up getting one with my PHS packet 14yrs ago tho I think. Hmmm, I'll have to check, I haven't even looked at it in over 10yrs lol.
Old 11-24-2014, 03:32 PM
JT
Community Administrator
JT's Avatar
You sure about that? There are no known copies of the build sheets - unlike there are for Corvettes - and never heard or seen PHS able to send one.
Old 11-24-2014, 04:21 PM
92GTA's Avatar
Nope, you might be right. It's probably the invoice I'm thinking of or something.
Old 11-24-2014, 05:50 PM
  #42
Engine: forged 350
What is a PHS and where can you get it?
Old 11-24-2014, 05:59 PM
  #43
JT
JT's Avatar
Pontiac Historical Services:
http://www.phs-online.com/
Note that they do not provide the full RPOs for your VIN like your SPID would have. It will merely be an invoice with some major RPOs and selling dealership information.
You don't have a Pontiac, so you'd use GM Media Archive:
http://www.gmmediaarchive.com/
Old 11-24-2014, 06:14 PM
  #44
Engine: forged 350
Old 11-24-2014, 07:30 PM
  #45
JT
JT's Avatar
If you have the SPID, unfortunately either service won't tell you a lot more other than selling dealership name, address and a few pricing information. Past packages also included general specifications for the year of the VIN but that information is online.
These services are best for those who don't have an SPID and want to verify the car and/or for supplemental documentation.
They are valuable services but are more valuable to some more than others.
Old 04-29-2017, 08:59 AM
  #46
Shawn Mills's Avatar
Couple months ago I got a1987 iroc-z 5.7 tpi red and has the t-tops. I've put the original motor and transmission back in it, and now I want to find my build sheet also. I've read this thread, but I would also like more opinions on where the build sheet could be. I haven't really tore the interior out trying to find it because I don't know if it might be special or anything. I know it is a numbers matching original.
Old 08-28-2021, 07:38 PM
  #47
Franktransam's Avatar
Good Day. I decided to try and find my build sheet. In 1997 I had my driver's side seat reupholstered and saw a build sheet on the bottom side of the seat. Great idea and threw it out. Today I decided to look for another one and found it under the carpet under the driver's seat. Looks great!
83 Crossfire TA
01-03-2016 01:26 PM
Jorlain
10-08-2015 01:57 AM
86CamaroDan
09-29-2015 10:08 PM
89-S-dime
Southern California Area
09-04-2015 10:34 AM
gixxer92
09-01-2015 04:32 PM
Quick Reply: Locating my build sheet
