Least amount of smog restrictions
I am looking for a very specific set of information in order to narrow down which car would be best for building up in a smog state like california.
I am thinking earlier year Z28 or Iroc-Z with carb and smallest quantity of smog devices OEM (no tbi, no tpi, no crossfire, no computer). Just air, spark, fuel.
Any thoughts?
Any thoughts?
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Re: Least amount of smog restrictions
All third gens have computers, carbs as well. All third gens came with CA emissions option. If you are looking to get around smog equipment, you have to go earlier than 80's
1 Post
Car: 1991 GTA
Engine: LB9
1975 is the cut off year in CA from what I recall for exemption.
As far as anything after that, especially anything made in the '80s, has the full monte of emissions control devices, including AIR, EGR, EVAP, PCV(which isnt a bad thing) and catalyst. Having a carb vs EFI and mechanical vs. electronic controlled ignition really isn't going to be the make or break factor in passing emissions.
Having a motor in good working condition and tune, along with all the emissions devices operating properly and installed correctly is the key.
Transmission: Pro-built 700R4
Regardless of carb or fuel injection, if the engine isn't operating properly then you're going to have issues regardless. I have a mildly modified '91 with TPI and I haven't had too many issues with smog in the fourteen years I've had the car.
Thanks all! To clarify, i was hoping that some of the younger models of carb cars did not have computers for starters, but it sounds like they do? After having dealt with an 87 and 88 iroc-z tpi, i have tired of the many sensors and computer malfunctions, they are pricey and ultimately not worth the headache. Also, I would prefer as clean of an engine bay as possible, which is why I was also searching for least amount of smog devices, or if all 82-92 have the same quantity, maybe the most low profile?
Could you all explain, for example, what a computer is doing for an 82 LG4? I was under the impression those had none? I also had an 83 SC L4 and I didn't think it had a computer....
Also, in terms of smog tests...I am assuming that certain years of third gens or certain combinations thereof (manual, automatic, tpi, carb, etc) would demand different criteria for smog performance. I was hoping someone knew which carb'd vehicle allowed for the most emissions.
All 1981 and newer GM cars (NOT trucks and vans) had computers. I've heard rumors that some 1980 model year GM cars also had a more basic computer system, although I've never seen one personally.
If you're looking for something with NO computer equipment, you need to get something 1980 or older. Honestly, I'd say the earlier computer controlled cars had more ugly emissions equipment, vacuum line nightmares, and sensor crap than the later ones. The TPI engine bay in my '91 looks a LOT cleaner than the '85 LG4 305 I used to have, as far as that kinda stuff.
And an export model isn't going to be Cali legal.
Received 1,664 Likes
All of these cars have to meet roughly the same specs. (as far as the chemical composition of the exhaust)
It's relatively MUCH harder to maintain a carb at those specs, than EFI.
All of these cars that are legal in the US came with computer controls of some sort.
The computer-controlled carb system is now over 25 years old. Things in those cars that can't be replaced easily, or maybe even AT ALL, are going to be crumbling and turning to dust CONSTANTLY. Wiring, connectors, plastic pieces of all sorts, those air injection tubes, and so on. Major maintenance headaches when they go bad.
Life will be easiest with a newer car, with EFI, with relatively few miles on it.
Thanks guys. But the goal is to have a street legal non computer controlled carb'd third Gen here in Cali. Currently talking to a state smog rep about a potential loophole for 'classic certification' granted to Canadian cars, which I also have read about here. Will keep you posted.
You could just get an 82 car with all the junk on it and take it off between inspections. I had a similar problem in the early 80's in Houston with my 82, I swapped the engine for a 400 , I just put the stock exhausts intake and smog pump, and dizzy on for the inspection, then yanked it off again after. I had 67 vette style side pipes and hooker headers, edelbrock intake and a Holley carb with a Mallory dizzy most of the time.
Car: 1983 G20 Chevy
Transmission: 4L60
Nobody in their right mind can argue that a computer carb runs cleaner than my OBD2 LS1 PCM controlled TPI inducted Vortec 350 engine.
Sometimes the laws, including this smog law, are so asinine that I find myself ready to start Judas Priest - Breaking The Law - YouTube
Which is exactly what I will do if I can't find an exemption! There's still morality in this world and that's all I will stick to!
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Suggestion: Move out of CA...
