LG4 vs L03
Transmission: World Class T-5
Axle/Gears: BW 3.45
LG4 vs L03
If you had to choose between the final 1987 version of the LG4, with the centerbolt heads, 9.3 to 1 compression and roller cam and the '88 and up L03, which would you choose.
I know that many are tempted to post neither one and stick to a TPI, but I'd like to hear the pros and cons of both of these base V8 engines, which were sold in the tens of thousands every year the 3rd gens were produced.
I don't think I've ever driven the 1987, 165-170 hp version of the LG4, but the last L03 I drove reminded me a lot of a good truck motor. Lots of torque down low and very little grunt after 3500 RPM.
1 Post
Car: 90 formula, 89 formula 350 vert
Engine: 305, 355
Transmission: T5, t56
Axle/Gears: 3:45 9 bolt, 8.8 3:73
Re: LG4 vs L03
Id rather have the 86 9.5:1 compression non center bolt lg4 over either for cheaper parts to build it up, but id choose the later lg4 over the l03. Mainly because of the fuel lines being on the passenger side making a carbureted motor easier to build when you want to swap a real motor in. Id prefer carb over a tbi which is another reason why i made my choice, but I've driven cars with both motors and they felt pretty much the same.
Re: LG4 vs L03
My first Camaro was an 85 sport coupe with an lg4 and my friend had an 87 lg4 with the roller cam and center bolt heads. My 85 was a full three car lengths faster in quarter mile. I have no idea why my early lg4 was so much faster. Maybe it was gearing?
I have driven a couple of TBI LO3 cars and did not like the feel of them. I would take the carb'd LG4 over the LO3 any day. I also found after doing some basic bolt on's to my LG4 I could run faster then any LO3 and equal to a stock LB9 TPI auto car.
LG4 are not as bad as everyone makes them out to be.
1 Post
Engine: 305, 355
Re: LG4 vs L03
LG4 are not as bad as everyone makes them out to be.[/QUOTE]
I think that depends on the year. 82-84 were the bad ones with only like 140 hp and low compression. The 85-87 were the better years with flat top pistons allowing 9.3:1 and 9.5:1 compression which makes for a better engine to cheaply modify effectively. 86 and 87 also had the electric fan over the mechanical freeing up a few horses. With a full exhaust and a higher stall converter in front of decent gears they're pretty fun to drive.
Car: 89 Firebird
Engine: 355 TBI
Re: LG4 vs L03
I had an 87 LG4 and now have an 89 L03. I prefer the Lg4. Stock it was about 3 tenths faster in the 1/4 than my L03 and simpler to work on.In defense of the L03 I do like the reliability and great gas mileage. Ive gotten as good as 26mpg on the hwy and the best I can remember was around 20-21 with the LG4. The L03 has a lot of low end torque and would be great in a pickup. It does not in my opinion belong in a sports car. The Lb9s should have been the only alternative to the L98 in Firebirds and Camaros alike after the L69 was taken off the table.
Car: 1983 G20 Chevy
Transmission: 4L60
Re: LG4 vs L03
I have driven both stock for stock, IMO the TBI has a slight edge in driveability and ease of simplicity. The last of those LG4s had about 50 vacuum hoses nestled all over the electronic Q-Jet. The Q-Jet was also neutered in those cars, setup to run very lean.
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: LG4 vs L03
I have had both... the last year LG4 actually had the same heads as the LB9, but the L03 had its own unique neutered heads. I made reasonable power with my LG4 with a mild cam, but the rats nest of vacuum hoses was possibly the worst part about it. Ever have a vacuum leak? what nightmare trying to figure out where to start without replacing everything, only to realize that the parts store does not have the correct size hoses..
In so many ways I actually find the TBI more simple to work on... I understand it better...
As for power... I did not do a side by side comparison, my LG4 started up perfectly every time, and it ran like a dream...
I think I actually have the original fuel lines around here somewhere...
Axle/Gears: BW 3.45
Re: LG4 vs L03
As has been stated already, it seems the later LG4s can be awakened a lot more easily with simple mods than the L03 can.
Car: 1983 G20 Chevy
Transmission: 4L60
Re: LG4 vs L03
Actually IMO a L03 can awaken just as well if not better than the last LG4s. The heads are not really a restriction until you are start making more than 250 HP. Its more the exhaust system and camshaft.
Axle/Gears: BW 3.45
Re: LG4 vs L03
I wonder what a bone stock L03 would feel like, if it a factory N10 exhaust from the manifolds back?
Re: LG4 vs L03
If I were planning to stay totally stock, I'd go TBI. Much less underhood clutter, better reliability, better mileage, same gutless performance.
If I wanted to build something that would actually run, I'd start with a late LG4. They are just a cam and L98 vette head swap away from 300+hp capability.
If I wanted a cruiser that did good burnouts. I'd go with the L03. Fast355 is right. The swirl port heads have their place. I built a swirl port headed LB9 with an LT1 cam for my 91 TA a few years ago and that was a fantastic combination. Great part throttle and low rpm torque and response, even with stock manifolds and Y pipe. It got 27mpg on the highway but was still was musclecar fast. I could slide sideways coming off a corner in 2nd, pop the clutch and roast the tires from a dead stop, all with a 2.73 posi. It was a surprisingly lively combo.
Re: LG4 vs L03
An L03 with the ultimate TBI mods, a cam swap and stock swirl port heads with L98 manifolds and N10 Y-pipe would run as good or probably better than a stock LB9. Somewhere on this site is some good documentation comparing swirl ports to regular heads on 305s. As I recall, comparing swirl ports to regular LB9 heads, the swirl ports made more power and torque on a 305 everywhere below something like 4000rpm. There were actual chassis dyno numbers posted. It's the reason I ran swirl ports on the LB9 in my TA, and I didnt regret it one bit.
Axle/Gears: BW 3.45
Re: LG4 vs L03
The L03 manifolds AND the tiny 2.25" Y-pipe suck. If you did L98/Lb9/L69 manifolds and a larger single cat Y-pipe, or a dual cat Y-pipe I think it would feel the same. The cam is so lame on an L03 that by the time it's turning enough rpm to need a dual cat Y-pipe, the cam is out of breath already. As is the stock throttle body....
Car: 1983 G20 Chevy
Transmission: 4L60
Re: LG4 vs L03
Nope...Its mainly the exhaust and lack of lift at the cam. You could retard the factory cam 4* and add 1.6:1 rockers and wake it up a good bit but might as well swap the cam.
I put 1.5" primary long tube headers with 3" collectors, 2.5 to single 3" exhaust, high flow cat, flowmaster 40 series single in/dual 2.5" out muffler, a 1" open center TBI spacer, and an ultimate TBI moded TBI with 350 injectors on a 305 in a G-van. Turning the factory 700r4, 2 piece driveshaft with carrier bearing, factory clutch fan, and all accessories it put down 178 RWHP and 268 RWTQ.
Car: 1983 G20 Chevy
Transmission: 4L60
Re: LG4 vs L03
Re: LG4 vs L03
The Cam in the LG4/L03 IIRC is actually the same cam used in the LB9/A4 from 1986-1992
Car: 1983 G20 Chevy
Transmission: 4L60
Re: LG4 vs L03
Actually that is not a completely accurate statement. The 90-92 speed density TPI 305s ALL had the L98 cam. No peanut cams in 305 TPIs after 1989. I have had 3 1990-1992 TPI 305 engines apart, all 3 were automatic cars, all 3 had L98 cams.
Car: 89 Firebird
Engine: 355 TBI
Re: LG4 vs L03
The difference in a stock L03 and stock Lb9 auto car with same gearing is about 1.4 sec in the 1/4 mile. I know because I tested them myself. So the exhaust, heads, and fuel injection setup in the L03 must be very sorry performance wise. I know they had the same peanut cam. 14.76 vs 16.16 in the 1/4 mi.
Car: 89 Firebird
Engine: 355 TBI
Re: LG4 vs L03
Interesting i never heard that. I always thought my automatic 5.0 TPI 91z28 ran great for what it was I had always been told it had the weaker "peanut cam".
Re: LG4 vs L03
I don't necessarily agree...The LG4/L03 manifolds and Y-pipe suck. They are already building substantial back pressure by 2,500 rpm. The factory cam peaks HP around 4,000-4,400 rpm. The larger L98 manifolds and N10 or larger single Y-pipe make a good bit more HP. The only difference in the 1990+ LB9 engines was the crappy LG4 exhaust on the lower HP model and the L98s N10 dual cats on the higher HP.
L03 manifolds 2.25" Y-pipe = sucks
L98 manifolds and large single cat Y-pipe = better
L98 manifolds N10 dual cat Y-pipe = best
Can you tell difference between better and best on an stock L03, probably not. Either setup is a vast improvement over stock L03 stuff.
Re: LG4 vs L03
The biggest difference from 90-92 was the gear ratio... If you were to take an (90-92) LB9 & put a taller gear in it I bet it would wake it right up... I know my 87 looooves the 3.73... I digress.
Axle/Gears: BW 3.45
Re: LG4 vs L03
Was the cam change in '90? I always thought it was in '91-'92?
Axle/Gears: BW 3.45
Re: LG4 vs L03
BTW, this often copied and pasted, definitive post, tells you all you need to know about factory exhaust systems for our cars:
There were only 2 different manifolds for the V8's throughout the years, but they were different depending on what motor and gearing package they came on. Here is the breakdown.
2" outlet manifolds with single 2 1/4" y-pipe
82-87 305 LG4 (VIN H)
88-92 305 L03 (VIN E)
82-83 305 Crossfire
90-92 305 LB9 w/o G92 axle (VIN F)
2 1/4" outlet manifolds with single 3" y-pipe
83-86 305 L69 (VIN G)
85-89 305 LB9 (VIN F)
88 350 L98 (VIN 8)
89 350 L98 w/o G92 axle (VIN 8)
2 1/4" outlet manifolds with dual 2 1/4" cats
89 350 L98 w/G92 axle (VIN 8)
90-92 350 L98 (VIN 8)
89 305 LB9 w/G92 Axle (VIN F)
90-92 305 LB9 w/G92 (Vin F)
The manifolds from the single 3" cat and the dual 2.25" cats are interchangeable. On the passenger side manifold, some will have the heat riser butterfly valve, some will have a spacer, and some will just have a donut gasket. You most likely have the wrong manifold for your application. If you have the larger manifolds, then it may be worth it to get the larger y-pipe for some more
82-83 305 Crossfire
88 350 L98 (VIN 8)
Car: 1983 G20 Chevy
Transmission: 4L60
Re: LG4 vs L03
Car: 1983 G20 Chevy
Transmission: 4L60
Re: LG4 vs L03
Honestly that would not be the only strangled 305 due to the factory GM exhaust. The L30 vortec trucks had a single catalytic converter with 1 7/8" pipes leading into it and a 2.75" exhaust. At 230 HP it had a design/test restriction of 10.5 in/hg at 4,600 rpm, which is over 5 psi of backpressure!!! The L31 trucks with dual 1 7/8" pipes into dual cats faired a bit better, but not much. They tested at nearly 8 in/hg of back pressure @ 4,200 rpm.
Re: LG4 vs L03
I'm biased as I have a 1987 LG4. I love the sound of a carb'd car when accelerating. But, I have driven the LO3 and it is smoother but not by much.
Yea, the LG4 has many vacuum lines and looks cluttered compared to the LO3 but it's really not that bad as you should replace vacuum lines since they do rot over time.
Axle/Gears: 10 Bolt 2.73 Open
Re: LG4 vs L03
If I can get mine running low 15s, I'll be one very happy camper.
Axle/Gears: BW 3.45
Re: LG4 vs L03
I don't know Fast...those numbers dmccain posted are pretty close with my experience. My new '90 L03/T5/3.08 Camaro ran a 16 flat, which matched the time Car & Driver had gotten from the same combo. My T/A with L03/700 and 2.73 is about a .5 second slower than that.
Re: LG4 vs L03
No, and there's a typo in my post too.
My first new car was a '91 RS (not '90). I sold it long ago. Should have run the VIN when I had my CarFax membership back when I bought my T/A, but it slipped my mind. I'd like to know what happened to it.
Car: 89 Firebird
Engine: 355 TBI
Re: LG4 vs L03
NO. That car was running PERFECT. PERFECT. Just stock. Almost everything in the suspension from end links to sway bar bushings to shocks, coil springs.. etc had been replaced also. I am certain the L03 would turn 15s but it would take headers and full exhaust replacement at the least, and taller gears would help. My bone stock Lg4 turned 15.80 before any mods then turned 14.88 with cam, headers,and aftermarket intake and holley 650 DP.
Car: 1983 G20 Chevy
Transmission: 4L60
Re: LG4 vs L03
Apparantly it wasn't running that perfect. I have seen the fuel pressure regulators on those cars alone set at anything from 9 to 13 psi in STOCK form.
Car: 89 Firebird
Engine: 355 TBI
Re: LG4 vs L03
Ok Fast I know you are a smart guy and I respect that and wont argue with you or be disrespectful. But I know my car, DynoDaves car, and others I have seen over the years had nothing wrong with them and I have saw what they turn and will leave it at that. The 16 sec pass surprised me because it felt really good out of the hole with 2.2 sec 60ft but it just didn't pull over 60mph with the anemic 2.73 gears. Now I have 3.73s it seems much faster and I will test it again after I do a few more mods, headers + y-pipe,etc.. if I don't swap engines first. Saying that im sure its probably already a solid 15sec performer with the gears and 3in exhaust now. I don't consider that exactly STOCK though.
Car: 89 Firebird
Engine: 355 TBI
Re: LG4 vs L03
Re: LG4 vs L03
I have considered doing the Vortec Heads on my 87, but I just have not been that ambitious AND I would need to have them machined for my cam...
Car: 1983 G20 Chevy
Transmission: 4L60
Re: LG4 vs L03
I see many of these cars with 048 ignition modules in them. The 048 modules retard the timing 6* at 4,200 rpm while the 369 advances 2* above 3,200 rpm. That alone could make an 8* difference in timing advance between the cars, then throw in the fact that a TBI car not running at 13 PSI is running too lean, it is easy for the car to have poor WOT performance despite driving around on the street perfectly fine. Also many 700r4s no longer have the correct governors in them and shift in the 4,000 rpm range rather than the 4,500 rpm range that these cars will run through. TV cable adjustment and weak TV springs also compound this issue.
I can tell you in decent air, with decent track prep, a slightly wider tire and lower control arm relocation brackets an otherwise stock L03/Auto/2.73 Camaro ran into the lower 15s. Just a few weeks before the car had run mid 16s in warmer weather. It would spin the right rear tire off the line and then fall on its face. It had an 048 module and 9.5 psi of fuel pressure to start. Simply swapping in the correct IC module and replacing the old regulator spring made a dramatic difference in the way the car ran.
With good traction and a good launch your 60' should have been closer to a 2.0x even with a stock engine. That alone is close to 4 tenths ET reduction.
Car: 1983 G20 Chevy
Transmission: 4L60
Re: LG4 vs L03
I have read so many good things on the Vortec Heads... Throw a good cam and Cat-back in the mix and I bet it would be a really good runner.
Car: 1983 G20 Chevy
Transmission: 4L60
Re: LG4 vs L03
The little 196/206 marine cammed 305 when GM was still making it made a net rated 250 HP and 300 TQ.
I would use a performer RPM and a TBI-Carb adapter if it will clear your hood.
Axle/Gears: BW 3.45
Re: LG4 vs L03
Agreed not trying to argue with you, rather help you get your car running to its potential. That being said you can have a car that seems to be running perfectly fine that is still out of spec and slower than it should be.
Car: 89 Firebird
Engine: 355 TBI
Re: LG4 vs L03
And this is why I will replace the L03 TBI with an old school carb setup 350. I know how to get full potential out of it I am not very saavy on the TBI.
#43
Axle/Gears: BW 3.45
Re: LG4 vs L03
That makes so much sense now. I drove an L03 Camaro a few weeks ago. Lots of torque off the line and somewhere between 3500 and 4000 RPM it dropped dead, like it hit a rev limiter or something.
#44
Car: 1983 G20 Chevy
Transmission: 4L60
Re: LG4 vs L03
It probably ran out of fuel about that RPM too. I have datalogged 100% stock TBI engines running lower than 12 psi of fuel pressure run out of fuel above 3,500 rpm and watched the narrow band o2 sensors drop into the double digit values which is leaner than 14.7:1!
#45
Car: 1983 G20 Chevy
Transmission: 4L60
Re: LG4 vs L03
There were more than a few times I reved my stock longblock L05 to 5,500 rpm manually shifting while tuning. It pulled strong up to 5,000 rpm then fell off. My G20 had a 700r4 and 3.08s. At 5,500 lbs it would pull a 2.2-2.3s 60' time and ran 10.80 a few times in the 1/8 in cool weather. In hot summer weather, heat soaked it ran 11.40s on a 2.4-2.5s 60', pass after pass after pass. It put down about 176 HP and 260 TQ at the rear wheels with a 190 hp/300 tq factory rating, headers, Y-pipe, high flow cat, and custom chip.
#46
Car: 91 GTA
Axle/Gears: stock
Re: LG4 vs L03
I would be very impressed (and maybe even a little angry if I still had that car) to see a car with the same motor, trans, gears running the same or lower times than mine with engine/drivetrain mods.
#47
Car: 1983 G20 Chevy
Transmission: 4L60
Re: LG4 vs L03
I had a 91 auto L03 Firebird and ran it many times at the track. Bone stock it would do ~16.3. With only an open element and 160 stat, I was knocking on the door of 15's!! I was running 16.0x's consistently. After a gear swap to 3.42's and a set of underdrive pulley's along with some timing, I was able to run a best of 15.38 at 88-89mph with a 2.2 60ft in VERY favorable weather. A few months before that run, I was only able to pull high 15.70's to low 15.80's in hot humid weather.
#48
Re: LG4 vs L03
#49
Axle/Gears: BW 3.45
Re: LG4 vs L03
From this thread, seems like an L03 with the right ignition control module, right fuel pressure and a TPI exhaust would make for a fun driver.
#50
Car: 89 Firebird
Engine: 355 TBI
Re: LG4 vs L03
I wish ole Fast355 lived closer to me I would love to send him my car to tune it! He is very knowledgeable on these cars! Thanks Fast. I will be definitely bumping my timing up to 6* atleast being it is set from the factory at zero checking my fuel pressure,and may get a chip burned for it after a few mods if I don't just pull the lil powerplant out. It runs so good and smooth I really haven't done much to it yet, its just slow.
