JY 1992 Y83 Trans Am 350 59K MI $10K
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
1G2FW2382NL217761
1 of about 44 Y83 Trans Am JY Coupes
I do not know how many L98 JY trans Ams there were..
http://www.cargurus.com/Cars/invento...ting=112466741
VIN: 1G2FW2382NL217761
Vehicle: FIREBIRD 2 DR
Year: 1992
Build Date: 1992-04-24
AAA Unknown 21,257
AH3 ADJUSTER,SEAT,4-WAY MANUAL,DRIVER 4-WAY MAN D/SEAT ADJR(AH3) 8,697
AJ3 RESTRAINT SYSTEM,FRONT SEAT INFLATABLE DRIVER SI INFL RST SYS(AJ3) 22,334
AR9 SEAT,FRONT BUCKET,DRIVER,PASSENGER,MANUAL RECLINING(EUROPEAN STYLE) MAN RECL FRT BKT ST,DELUXE(AR9) 21,980
AU3 LOCK,SIDE DOOR,ELECTRIC ELEC S/D LK(AU3) 20,734
A31 WINDOW,ELECTRIC OPERATED,SIDE ELEC SI WDO(A31) 20,734
A90 LOCK,REAR COMPARTMENT LID,REMOTE CONTROL,ELECTRIC RELEASE ELEC REL LID LK(A90) 18,825
BC8 ORNAMENTATION,INTERIOR,FRONT DOOR MAP POCKET RH AND LH DR MAP PKT(BC8) 20,734
B2L ENGINE PACKAGE-V8 5.7L, PFI ENG PKG(B2L) 828
B84 ORNAMENTATION,EXTERIOR,BODY SIDE MOLDING(USED WITH TROFEO SPORT COUPE WL3) BODY SI MLDG(B84) 22,096
C49 DEFOGGER,REAR WINDOW,ELECTRIC ELEC RR WDO DEFG(C49) 15,872
C60 AIR CONDITIONER,FRONT,MANUAL CONTROLS A/C MAN CONT(C60) 22,220
DC4 MIRROR,INSIDE,REARVIEW TILT,DUAL READING LAMP I/S DUAL READING LP RR VIEW MIR(DC4) 22,062
DG7 MIRROR,OUTSIDE,RH & LH REMOTE CONTROL,ELECTRIC(PAINTED) O/S ELEC R/CON PAINTED MIR(DG7) 17,357
D42 COVER,REAR COMPARTMENT SECURITY(SHADE) R/CMPT SECURITY SHADE(D42) 9,781
D5X GEAR-SPEEDO DRIVEN (D5X) 828
D8I SENSOR-VEH SPD (10456089) (D8I) 828
D81 SPOILER,REAR,AERO WING RR AERO WING SPLR(D81) 3,122
E5Z ADAPTER - SPEEDO - DELETE 22,334
E9Z KEY - SPEEDO - DELETE 22,334
FE2 SUSPENSION SYSTEM,RIDE AND HANDLING(USED WITH TOURING YP5) RIDE & HANDLING SUSP(FE2) 1,682
GU5 AXLE,REAR,3.23 RATIO 3.23R(GU5) 13,231
G80 AXLE,REAR,POSITRACTION,LIMITED SLIP POSITRACTION L/SLIP R/AXL(G80) 1,782
IPC TRIM,INTERIOR DESIGN (IPC) 21,980
J65 BRAKE SYSTEM,POWER,FRONT AND REAR DISC 4-WHL DISC BRK(J65) 1,051
KC4 COOLING SYSTEM,ENGINE OIL ENG OIL CLG(KC4) 1,051
K34 CRUISE CONTROL,AUTOMATIC,ELECTRONIC CRCONT(K34) 14,670
K68 GENERATOR,105 AMPERE 105 AMP(K68) 8,465
L98 ENGINE, 5.7L, (5.7-8) 350 CID, V8, TPI 5.7-8(L98) 828
MD8 TRANSMISSION,AUTOMATIC 4-SPEED(THM700R4/4L60) 4-SPD A/TRANS(MD8) 19,979
MX0 TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION) A/TRANS PROVISIONS(MX0) 19,979
NA5 EMISSION SYSTEM,FEDERAL REQUIREMENTS FEDERAL EMIS(NA5) 20,205
NP5 STEERING WHEEL,LEATHER WRAPPED(USED WITH GRAN TOURING PKG Y56) (NP5) 1,056
N10 EXHAUST SYSTEM,DUAL(USED WITH TROFEO SPORT COUPE WL3) D/EXH(N10) 1,051
N64 WHEEL AND TIRE,SPACE SAVER SPARE(ALUMINUM) STOWAWAY SPARE(ALUM)(N64) 1,091
PW7 WHEEL,16X8,STYLED(ALUMINUM)(SUPERLIGHT) STYLED AL WHL(PW7) 1,446
QLC TIRE,ALL P245/50ZR16/N BL R/PE ST TL HWY TIRE(QLC) 1,682
R6P CONTROL - SALES ITEM NO. 15 836
T93 LAMP,TAIL AND STOP(SPECIAL)(USED WITH TOURING YP6) SPECIAL TAIL & S/LP(T93) 684
T96 LAMP,FRONT FOG(USED WITH BERETTA GTZ Z04) FRT FOG LP(T96) 18,323
UB3 CLUSTER,INSTRUMENT(OIL,COOLANT TEMPERATURE,VOLTMETER,TACHOMETER,TRIP ODOMETER)(USED WITH BERETTA GT PKG Z21) GA(UB3) 22,334
UQ1 RADIO,PROVISIONS FOR STEREO STEREO RDO PR0VISIONS(UQ1) 22,334
UX1 RADIO,AM/FM STEREO,WEATHER,CASSETTE,EQUALIZER,ETR,INCLUDES CLOCK STEREO AM/FM W/CASS & EQLZR(UX1) 12,701
U62 SPEAKER SYSTEM,4,DUAL COAX FRONT,DUAL COAX PACKAGE SHELF 4 SPKR SYS(U62) 22,334
U75 ANTENNA,POWER(CHROME) PWR ANT(EXPORT)(U75) 5,491
VAN PLANT CODE VAN NUYS, CA, CPC VAN NUYS,CA PLANT CODE(VAN) 22,334
VK3 LICENSE PLATE,FRONT MOUNTING PACKAGE FRT LIC PLT MTG PKG(VK3) 16,875
V73 VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73) 20,779
WS4 TRANS AM(MERCHANDISING OPTION)(2FS87 + WS4 = 2FW87) TRANS AM(WS4) 1,056
WS6 PERFORMANCE PACKAGE,SPECIAL(MERCHANDISING OPTION) SPECIAL PERFORMANCE PKG(WS6) 1,682
Y83 TRANS AM PACKAGE(MERCHANDISING OPTION) TRANS AM(Y83) 702
1SC PACKAGE-OPTION 03 (1SC) 18,423
1SZ PACKAGE OPTION- (1SZ) 21,331
41P WHEEL COLOR,BLACK (41P) 881
52Q MOLDING COLOR - JAMACIA YELLOW (52Q) 475
52U EXTERIOR COLOR,PRIMARY,COPPER BEIGE (52U) 482
6ZX SPRING COMPTR SELECT FRT LH SUSP(6ZX) 772
7ZX SPRING COMPTR SELECT FRT RH SUSP(7ZX) 772
8NL SPRING-COMPTR SELECT RR LH SUSP(8NL) 1,899
82C TRIM COMBINATION,CLOTH,MEDIUM DARK GRAY (82C) 11,377
82I INTERIOR TRIM,MEDIUM DARK GRAY (82I) 11,405
829 SEAT BELT COLOR - MED DK GRAY (829) 11,405
9NL SPRING-COMPTR SELECT RR RH SUSP(9NL) 1,899
Year: 1992
AAA Unknown 21,257
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: JY 1992 Y83 Trans Am 350 59K MI $10K
This is an exotic bird. Looks good from a distance. Somebody investigate it and if it checks out, buy it!
Here are some pics from the ad if anyone is interested
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Does the front have lowering springs?
Even so, I still think someone should buy it if it hasn't been bent or exposed to salty roads.
I know Chris. Pretty good guy. If I recall correctly he's had this car for a while. It looks pretty darn good from what I remember a couple years ago (but I didn't look at it in detail.)
I can go by and look at it if someone needs help.....
http://www.autotrader.com/cars-for-s...ink=true&Log=0
This car is still for sale. Dealer in Tulsa, OK. I've been watching it for a while. Just happened to google the VIN and found this thread. Did anyone ever check it out?
The owners name is Louie or something. Apparently those that know him say it is a pretty nice car... The price is not out of line IMHO... For a 350 car
Owners name is Chris. Good guy and knows his third gens. I saw it when he first bought it several years ago. Nice car and I tried to buy it at the time but it wasn't for sale. I can put eyes on it if someone is truly serious.
Engine: 4++,350 & 305 CIs
She sure is pretty...
I was tempted, but I got no place to put it inside... My barn is full right now... 8 cars, Travel Trailer and a little Utility Trailer is a PITA to manage in a 40x60 barn
1992 Trans Am
05-10-2023 07:19 PM
IROCZDAVE (88-L98)
10-06-2016 09:08 AM
1992 Trans Am
08-09-2015 04:32 PM
