I think I have a rare one
Thanks to okfoz for running my vin.
I picked up a 1991 rs Convertiable the other day with only 33,083 miles on it everything stock. My very first car was a 1991 camaro and going through more camaros, corvettes, challenger and many other cars I'm back to where I started
I couldn't figure out why there was no ac in my car and it didn't look it was removed after the fact as it was very neat with no wires or any trace anywhere apparently I'm one of 103 from the factory with no ac.
Vehicle: CAMARO RS CONVERTIBLE
Year: 1991
Build Date: 1990-05-23
Found 8,255 vehicles matching that year and model in our database.
RPO Description Matches
UB3 CLUSTER,INSTRUMENT(OIL,COOLANT TEMPERATURE,VOLTMETER,TACHOMETER,TRIP ODOMETER)(USED WITH DELUXE SPORT PKG W32) GA(UB3) 8,255
UN6 RADIO,AM/FM STEREO,CASSETTE,ETR,INCLUDES CLOCK(EXPORT) STEREO CASSETTE(UN6) 6,298
UQ1 RADIO,PROVISIONS FOR STEREO STEREO RDO PR0VISIONS(UQ1) 8,252
UX6 SPEAKER SYSTEM,FRONT DUAL DASH MOUNTED SPKR SYS(UX6) 8,252
VAN PLANT CODE VAN NUYS, CA, CPC VAN NUYS,CA PLANT CODE(VAN) 8,255
VK3 LICENSE PLATE,FRONT MOUNTING PACKAGE FRT LIC PLT MTG PKG(VK3) 7,057
V73 VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73) 8,151
Y86 CAMARO "RS" PACKAGE(MERCHANDISING OPTION) RS PKG(Y86) 5,166
1AY ORDER MODIFICATION - STOCK 4,874
1SA PACKAGE-OPTION 01 (1SA) 66
10U EXTERIOR COLOR,ARTIC WHITE (10U) 2,203
11P WHEEL COLOR,WHITE (11P) 2,099
6XT COMPONENT FRT LH COMPUTER SEL SUP (6XT) SUSP(6XT) 650
7XT COMPONENT FRT RH COMPUTER SEL SUP (7XT) SUSP(7XT) 650
8NL SPRING-COMPTR SELECT RR LH SUSP(8NL) 3,990
82C TRIM COMBINATION,CLOTH,MEDIUM DARK GRAY (82C) 1,994
82I INTERIOR TRIM,MEDIUM DARK GRAY (82I) 3,717
829 SEAT BELT COLOR - MED DK GRAY (829) 3,717
9NL SPRING-COMPTR SELECT RR RH SUSP(9NL) 3,990
AJ3 RESTRAINT SYSTEM,FRONT SEAT INFLATABLE DRIVER SI INFL RST SYS(AJ3) 8,255
AM9 SEAT,REAR,FOLDING SPLIT BACK(USED WITH BERETTA GT PKG Z21) FLDG SPLIT BK R/SEAT(AM9) 7,515
AR9 SEAT,FRONT BUCKET,DRIVER,PASSENGER,MANUAL RECLINING(EUROPEAN STYLE) MAN RECL FRT BKT ST,DELUXE(AR9) 8,255
B18 ORNAMENTATION,INTERIOR(DELUXE)(USED WITH TROFEO SPORT COUPE WL3) DELUXE INTR(B18) 7,515
C41 HEATER,OUTSIDE AIR,WITH FAN AND DEFROSTER HTR(C41) 103
D35 MIRROR,O/S LH REM RH DIRECT CTL,PAINTED PAINTED O/S MIR(D35) 2,807
D5V GEAR-SPEEDO DRIVEN (14085513) (D5V) 878
D8M SENSOR VEH SPD (10456087) (D8M) 684
E5Z ADAPTER - SPEEDO - DELETE 8,255
E9Z KEY - SPEEDO - DELETE 8,255
F41 SUSPENSION,FIRM RIDE HANDLING,FRONT AND REAR(USED W/TOURING PKG WF1) FIRM RIDE & HANDLING SUSP(F41) 4,716
GU4 AXLE,REAR,3.08 RATIO 3.08R(GU4) 878
IPC TRIM,INTERIOR DESIGN (IPC) 5,078
J41 BRAKE SYSTEM,POWER,FRONT DISC,REAR DRUM(CAST IRON) CAST IRON FRT DISC/RR DRUM BRK SYS(J41) 8,255
K60 GENERATOR,100 AMPERE 100 AMP(K60) 5,166
L03 ENGINE,5.0L(5.0H),V8(T.B.I.) 5.0H(L03) 4,767
MM5 TRANSMISSION,MANUAL 5-SPEED PROVISIONS(MERCHANDISING OPTION) 5-SPD M/TRANS PROVISIONS(MM5) 894
M39 TRANSMISSION,MANUAL 5-SPEED(BORG-WARNER) 5-SPD M/TRANS(M39) 878
NA5 EMISSION SYSTEM,FEDERAL REQUIREMENTS FEDERAL EMIS(NA5) 7,143
NK3 STEERING WHEEL,SPORT,SOFT RIM,SIMULATED LEATHER(USED WITH EUROSPORT B2T) SIMULATED LEATHER STRG WHL(NK3) 5,166
N96 WHEEL,16X8(CAST ALUMINUM) AL WHL(N96) 6,850
QMT TIRE ALL P235/55R16/N BL R/PE ST TL AL2 TIRE(QMT) 4,716
Year: 1991
Community Administrator
Re: I think I have a rare one
Keep in mind that rare does not equal desirable. Also keep in mind that given some of today's cars produce over 700HP while still having factory a/c, some are not going to look at a car like this as being desirable.
It is generally performance options and combinations that make a care more desirable.
Year: 1991
Year: 1991
Yes I am aware of that. That's why my whole garage is filled with goodies going into the car along with a crate motor and tko tranny
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Perfect candidate for an engine upgrade:
Low miles
Clean
Convertible
305 TBI
Manual trans setup
No A/C
Perfect!
Now tell us. What's in the box?
Low miles
Clean
Convertible
305 TBI
Manual trans setup
No A/C
Perfect!
L31 crate motor, I have an lt4 cam, new springs and so on. I am keeping the tbi but have a bored out tbi unit along with bigger injectors. I have many more goodies too
Spohn sub frame connectors
Bmr control arms, sway bars, torque arm
Hooker headers, y pipe, cat back
3.73 gears, posi unit, new axles and so on
Tko 500 conversion kit
1 Post
Car: 1991 Z28
Engine: 400 ci LS3
Transmission: Jerico DR4
NOBODY does more to perpetuate the undesirable status of third gens like some of the "enthusiasts" on TGO.
Then we have you (the site admin!) chime in to "remind" the owner that the car is not necessarily desirable based on it's rarity. What was the motive behind that?
Rare is objective whereas desirable is subjective, how can you be sure that someone else won't find this car desirable (it's only got 33k miles on it)?
You want to address my comments, noting that I'm a site admin, when your last sentence confirms that you know very well if I didn't say it "nicely" that someone else would have.
This car's value is its mileage, convertible, and originality. But the originality point won't remain when you consider that the O/P is going to take out the original drivetrain and other things on a 33K car. I personally don't mind that the O/P is going to do this, but it makes some of this a moot point because the "rare" no a/c option is going to be less relevant when the car isn't original.
z28wiz has been a member of TGO since 1999 but only has 51 posts. There's nothing wrong with that, however, many new members come to TGO with a car that has a limited option or they think that's it's a super valuable car because of the lack of options. I'm not saying that z28wiz had this intention. JT was just letting him know that rare does not always mean valuable, just in case that was his intent. I agree with JT that the value in this car is the low miles, convertible and originality.
This car is basically worthless to me living in Florida. It's too hot to drive with the top down and no AC would make it unbearable to drive. If I still lived in Minnesota, then it would be perfect. I ran with the tops out and AC off everywhere I went up there.
Also to put into perspective...My 4x4 truck means very little in Florida, but carries large value in Minnesota. That's the point JT was trying to make. A non-AC car has a limited buyer base, which limits the value. If z28wiz intends on keeping the car, then who cares?
Yes I have been a member since 1999 when I bought my very first car when I was 19 a 1991 Camaro RS tbi. Since then I have had many cars 2001 Camaro SS, vettes, and a challenger. I have since come back to square one with 1991 Camaro RS again. Fyi I did have a ton more posts, but years ago when the forum server changed I believe some of us lost our post count.
Anyways regarding the originality claim, I was just stating it seemed rare to me. And yes I have no intention in keeping it stock. I don't plan on selling it anytime soon this will my toy weekend cruiser. The body is completely straight and so is the interior and everything else.
Car: 88GTA
Engine: 5.7TPI
[QUOTE=eseibel67;5919741]Perfect candidate for an engine upgrade:
Low miles
Clean
Convertible
305 TBI
Manual trans setup
No A/C
Perfect!
"I picked up a 1991 rs Convertiable the other day with only 33,083 miles on it everything stock."
I could care less what people do to their cars. But, I can't for the life of me figure out why someone would mess with a car so original and stock being the shape that it is in. IDK, JMO. Had to ask.
Low miles
Clean
Convertible
305 TBI
Manual trans setup
No A/C
Perfect!
[QUOTE=Bob88GTA;5922310]
Apparently you do care to make the comment at the end, lol. You contradicted yourself.
Low miles
Clean
Convertible
305 TBI
Manual trans setup
No A/C
Perfect!
I could care less what people do to their cars. But, I can't for the life of me figure out why someone would mess with a car so original and stock being the shape that it is in. IDK, JMO. Had to ask. :2cents:
Low miles
Clean
Convertible
305 TBI
Manual trans setup
No A/C
Perfect!
Hopefully in the next week ill pull the motor and tranny out. I have the crate motor all ready to drop in. Minus a few odds and ends like the coolant bypass on the vortec manifold. Still trying to figure out what do there. Either drill the thermostat like some do or run an actual bypass.
Car: 1985 Z28
Still a cool car,I wouldn't touch a thing. It is what it is. I do agree with the down playing of the rarity of the car. People are using the same standards as the previous generations in the past. I wouldn't cut the car up at all,but its his car and he can do as he pleases. Just because it's a third gen,folks are already saying ....eh....third gen............think about it.............my two cents.....BILL
Car: 91 Camaro RS T-Top
Engine: 5.0 Tbi
Man that's pretty, looks stock, but I bet it gets up and goes compared to when you got it.
Engine: 4++,350 & 305 CIs
Nice work!
Nice clean engine swap, good luck with your sale.
Really a nice car. Probably a special order, common back then to get the manual tranny, and the AC was a $1000 option. Your original 5 speed trans and parts are probably worth some money too.
sjorgens
10-01-2015 07:54 PM
