gray valve stem caps
My 89 T/A had two of these gray caps on it. I recently saw a few pictures of low mileage 89 TTA's that also had gray caps. Are these originals? If so, any idea where I could get a few of them? I looked on ebay & found some that claim to be oem for buick GN's they look a lot different from these.
Any thoughts?
Any thoughts?
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
Re: gray valve stem caps
As close as I can come, can't seem to find the pictured ones exactly.
I did find this image on this forum. Pretty good shot of the stem. No doubt these got tossed every time our cars got fresh rubber with new stems. Funny how things like this can make a small difference now, but when the cars were new they would just get discarded.
Heck , I am sure I would have put black ones on back then for a better appearance. Now I am looking for some.
Car: 88GTA
Engine: 5.7TPI
Yes, the sticker on the wheel and the caps came on the car as original. My TTA has the gray caps. Stickers are long gone. Yeah, It'll be hard finding "real originals."
Car: 88GTA
Engine: 5.7TPI
As close as I can come, can't seem to find the pictured ones exactly. Amazon.com: BMW TPMS Wheel Valve Stem Cap set Gray ( x4 ) tire air fill screw on cover: Automotive
Engine: 4++,350 & 305 CIs
Look in the trunks at the spares from the same yrs GM cars in junk yards.
When I go, I get piles of these.
Speaking of spares, I was surprised to find this 89 has a steel spare. Everything intact & unused, but I thought it should have had an aluminum spare. My Iroc does & I thought I read all 16" wheeled cars had them?
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Would have never thought of that. Do you know if they were used on a lot of GM cars in the era? I wonder if my own spare has one.
Transmission: 5-Speed Manual
[QUOTE=F-body-fan;5975527]My 89 T/A had two of these gray caps on it. I recently saw a few pictures of low mileage 89 TTA's that also had gray caps. Are these originals? If so, any idea where I could get a few of them? I looked on ebay & found some that claim to be oem for buick GN's they look a lot different from these.
Yes They Were Original,My Car Came With These From The Factory.
RPO N64 So either someone at GM didn't follow the sheet, or somebody swapped it at some point. I can find out easy enough from the 2 previous owners, but I don't think either of them touched it. Is there any identifications on the spares/tires that indicate the year? Not a big deal, just curious now.
is this just for 89 or would 88 GTAs have them? as well? was this an all GM car thing?
I guess we will be going to some junk yards this year
Engine: 5.0 EFI
I'm not 100% positive if my 86 had the Gray Caps, but I kinda think they were,not sure.
,if they were their long gone now.I did check my spare (never been used) and it has a metal cap on it.
Didn't you need those to remove the check deflate many of the space saver spares? I recall some of the wheels having a built in (air release) check valve in the rim however. No clue what cars had them though.
Yes the stamp codes next to the valve stem will tell you the year, MFG, month & date of manufacture.
Here's an N64 Aluminum spare.
Success! I found a bunch of original caps. I got in touch with a guy who used to work at a GM dealer in the 80s. For some reason he started throwing some of the gray caps he would end up with in his tool box. He still had these caps in his tool box today & was kind enough to sell them to me. Interestingly, only 7 of the caps are the same as whats on my 89. All of the other ones he said are from GM cars of the era, but it would seem the smooth top style was not the common ones used. Based on this collection anyway.....
Engine: 5.0 EFI
I found these at Summit.
http://www.summitracing.com/parts/smp-tpm630n/overview/
Those 7 look to be the correct caps for the Firebirds.
I have enough of the smooth top ones now to put them on my 87 iRoc as well, maybe that's not the style the camaro's had?
Transmission: World Class T-5
Axle/Gears: BW 3.45
GM May Have Used Different Vendors Over The Years,So The Styles May Have Changed Slightly.
johnblacksox
Wheels and Tires
11-03-2015 01:03 PM
