Vin break down
Car: 1986 Black IROC
Engine: 305 Quadrajet
Transmission: 5 speed
Axle/Gears: 273
Vin break down
Title reads as an 86 Z 28 but the Vin is causing me confusion. It's a 305 tpi with 700R4 and 4 wheel disk breaks. It's leading me to think it may have been a hold over 85 IROC. What do you guys think?
1G1FP87F7GL169450
1G1FP87F7GL169450
Transmission: World Class T-5
Axle/Gears: BW 3.45
Re: Vin break down
1G1FP87F7GL169450
1G1FP87F7GL169450
What would make you think that?
Axle/Gears: 273
Received 1,666 Likes
Re: Vin break down
The only numbers I see, say "86".
It has "F" in the 8th char of the VIN. Would be "E" if it was 85. That's all there is to that. The VIN does not lie.
Axle/Gears: 273
Re: Vin break down
I ran some of the numbers last night while I was looking it up and best I can remember if they were transplanted to the 85' year it would list as IROC. First thing I noticed about car is that it has four disk breaks (not necessarily rare but kind of uncommon).
Axle/Gears: 273
Re: Vin break down
Would GM have held some 85's over and restamped them 86'?
Axle/Gears: BW 3.45
Re: Vin break down
I still don't know what would make you think it's an '85 when the VIN clearly states it's an '86. Four wheel disc brakes was a common option from '82 through '92.
Re: Vin break down
There are FEDERAL LAWS concerning that sort of thing. The car IS what it IS, and was stamped accordingly.
Fuhgeddaboudit. The car is a 86, plain and simple. I have no clue what's put this 85 bug in your mind, but it's WRONG, and it would be a great idea to clear it out once and for all.
Re: Vin break down
Can you also stop referring to the car as an 85 foot car or an 86 foot car? The apostrophe goes before the digits to show a shortened year, not after. Remember that an apostrophe marks the place where letters have been omitted. An apostrophe is also used to indicate the omission of the first two digits of a year or years.
As to this post, I'm also trying to understand why you think the car may be an '85. The '86 Z28 could come with the 305 TPI and J65 brakes. All IROC-Zs have the Z28 RPO code, so the title saying it's a Z28, is correct. Now, if the car has the RPO B4Z, then you have an IROC Z28. If there is no B4Z, then the car is a regular Z28, not an IROC-Z.
Please provide more detail into what you're looking at and we'll help you understand the car more.
Car: 91 Chicken (Firebird LO3)
Engine: 305 TBI with 200k+ miles
Transmission: Rebuilt 700R4
Axle/Gears: 2.73 single tire fryer for now
Re: Vin break down
Gonna start here. Bought a 91 firebird, formula, LO3 engine a couple years ago. What has me confused is the "plastic" lower ground effects and the " T/A" bird on the hood as well as the "bird of prey" decals on the B post. Were those standard on the firebirds or were those added after the fact? The car was originally green with gold graphics. Thanks for the input
Community Administrator
Re: Vin break down
Formulas didn't have ground effects. The large hood bird wasn't an option on anything but the Trans Am and 1987 was the last year it was available. Also, Formulas had the bulge hood.
If this is pictures of your car:
https://www.thirdgen.org/forums/body...ml#post5934655
Make sure you actually have a Formula, not just by the VIN because a base Firebird and Formula have the same 1G2FS VIN prefix, but by the SPID showing W66 for Formula. You may have a base Firebird as your pictures suggest it's a base Firebird.
Re: Vin break down
Ok thanks. Not sure what you mean by SPID, but at least if I hack up a car, it's not a "gas monkey" resto.. lol
Re: Vin break down
The SPID is the label inside the center console or rear lock box. It has the VIN and multiple lines of 3 letter/number combinations. Those are the RPO codes of the options built in the car. Look for W66 for the Formula. Also, verify the VIN on the label matches the car, just to be sure the codes are for the correct car.
**edit** Looks like I said the same as DynoDave but he submit before me. Duplicate info now.
1 Post
Car: 1989 IROC G92 LB9 MK6
Engine: LB9
Transmission: MK6
Axle/Gears: 3.45
Re: Vin break down
Do what you want to the car and enjoy it..it is your car and it does not matter what others think. Drive that thing and smile.
Re: Vin break down
Sorry; 10th digit is the year, not 8th. Brain cramp on my part.
"F" in the 10th digit = 86. Period.
Re: Vin break down
Dammit, I hate it when I outsmart myself!!
Sorry. I should go back and re-read stuff sometimes.
The OP's VIN (...F7GL... has "G" for the year digit; the code for "86". His car is a 86.
Re: Vin break down
Yes it is true. I screwed up. I really really really try hard not to, but occasionally, my human half takes over and drives me off a cliff or something.
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: Vin break down
IMissMy86TA
Exterior Parts for Sale
12-14-2015 03:11 PM
L98GTA87
11-24-2015 05:54 PM
