Any of the 1988 or 1989 1LE Trans Ams have T-tops?
1 Post
Car: 1989 IROC G92 LB9 MK6
Engine: LB9
Transmission: MK6
Axle/Gears: 3.45
Anyone know if any '88-'89 T/A 1LE cars had CC1? 90-92 T/A and Formula 1LE's show some T-top cars but did not know about the earlier cars.
1 Post
Engine: LB9
Transmission: MK6
Axle/Gears: 3.45
Re: Any of the 1988 or 1989 1LE Trans Ams have T-tops?
No responses....so next question? IF no T-top 1988 or 1989 1LE Trans Ams then what changed so that they were produced or allowed to be ordered in 90-92?
We unfortunately don't have the Compnine data for anything prior to 1990 so it's hard to pull the numbers.
Of the TA's, only 3 were built in 1988 and 26 in 1989. Not saying that none of those could have been built with CC1 T-Tops but I would bet that most of them were built for the Players Cup and were export models. That being said, Compnine shows that of the 4 TA's built in 1990 - 2 were domestic & 2 were export with one each of those being T-tops, so you never know.
1 Post
Engine: LB9
Transmission: MK6
Axle/Gears: 3.45
I agree to probably none built '88-89 and no reasonable way to know. Still makes me wonder why the General decided OK for Formulas to have 1LE in 91-92? Seems like the Formula was a better platform for the 1LE option than the T/A. Maybe due to Firehawk production in 91.
2 of the 4 TA's in 1990 got them...no idea.
I believe at least one of the 1989 TA's got C60 A/C as well. Remember talking to the owner in the DC area several years ago unfortunately I never saw any documentation. He did run it through e-bay at least once however.
Looking at the plate on your car you are another one of the 1LE CC1 owners then?
Was your TA one of the 4 US delivery units or one of the 15 built for export?
1 Post
Engine: LB9
Transmission: MK6
Axle/Gears: 3.45
Yes, a fellow 1LE-CC1 owner. Mine is the one of 15 export .I bought ML205130 off this board on Christmas Day last year. It was posted in this section and folks really tore into it because of condition. I contacted owner, verified numbers match on all but warranty MK6 from 1992 and bought it. This sucker pulls like a freight train and is original to the plug wires. I've laid low about it as it needed sorting but have been very pleased with it. I think there is one other Trans Am around on this board but most 1LE-CC1 that survived appear to be Formulas. Your red car is the nicest one I have seen. I've not even seen a picture of the T/A's except mine.
Greg Williams had one of the T-Top TA's that I believe is in the Hawks collection now, white I think. There is another T-Top 91 Formula I know of other than the one that was on e-bay last week with the title issue.
Is yours the black one that was in Michigan?
Mine is getting better each week and was a good car to start with, Andy was a good steward.
1 Post
Engine: LB9
Transmission: MK6
Axle/Gears: 3.45
Mine is the black one from Michigan, it came from Nova Scotia. I spoke with one of the former owners in Nova Scotia, he had purchased it to make a KITT conversion car but did not follow through thankfully. He had not heard of a 1LE and did not know the car was one. He bought it off of Kijiji. I'm still moving forward in documenting ownership trail....apparently itis was not known it is a 1LE until the person whom I bought it from.
One of the 3 1988 1LE Trans Ams was sold new at Sidney Moncrief Pontiac/GMC in Sherwood, Arkansas. I have seen it on several occasions (had a chance to buy it in '00 for $10k) and that car was a white hardtop with white PW7 rims...later changed to black.
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
I have the VIN of a 1991 (05/90 build date) 1LE T-Top trans Am. The RPO sticker was missing on the car, so no pics. I did verify the VIN and RPO codes. It was an odd car ... hard to verify as genuine. With Compnine ... you can look it up as it was CDN.
Mark.
Mark.
1 Post
Engine: LB9
Transmission: MK6
Axle/Gears: 3.45
Hey Mark, could you post the VIN. Probably someone with a compnine acct can run it. I only have one Canadian VIN so would love to have another.
What did you mean "It was an odd car...hard to verify as genuine'?
Was the car in good condition? Run and drive?
Engine: TPI(s)
I saw it in person in 2003. Ran and drove then ... but wow that was 13 years ago. No idea where it is now. As it had no RPO sticker on it, tough to quickly ID as a 1LE. You'd have to run to the dealer to check it. No Compnine back then.
1G2FW23F4ML211764
RPO Description: Usage:
AH3 ADJUSTER, SEAT, 4-WAY MANUAL, DRIVER 4-WAY MAN D/SEAT ADJR (AH3)
AJ3 RESTRAINT SYSTEM, FRONT SEAT INFLATABLE DRIVER SI INFL RST SYS (AJ3)
AN4 RESTRAINT PROVISIONS, CHILD (CANADIAN) CHILD RST PROVISIONS (AN4) (CANADIAN)
AR9 SEAT, FRONT BUCKET, DRIVER, PASSENGER, MANUAL RECLINING (EUROPEAN STYLE) MAN RECL FRT BKT ST, DELUXE (AR9)
AU3 LOCK, SIDE DOOR, ELECTRIC ELEC S/D LK (AU3)
A31 WINDOW, ELECTRIC OPERATED, SIDE ELEC SI WDO (A31)
A90 LOCK, REAR COMPARTMENT LID, REMOTE CONTROL, ELECTRIC RELEASE ELEC REL LID LK (A90)
BC8 ORNAMENTATION, INTERIOR, FRONT DOOR MAP POCKET RH AND LH DR MAP PKT (BC8)
B84 ORNAMENTATION, EXTERIOR, BODY SIDE MOLDING BODY SI MLDG (B84)
CC1 ROOF, HATCH, REMOVABLE PANELS, GLASS HATCH RF (CC1)
C41 HEATER, OUTSIDE AIR, WITH FAN AND DEFROSTER HTR (C41)
C49 DEFOGGER, REAR WINDOW, ELECTRIC ELEC RR WDO DEFG (C49)
DC4 MIRROR, INSIDE, REARVIEW TILT, DUAL READING LAMP I/S DUAL READING LP RR VIEW MIR (DC4)
DE4 SUNSHADE, REMOVABLE HATCH ROOF HATCH RF S/S (DE4)
DG7 MIRROR, OUTSIDE, RH AND LH REMOTE CONTROL, ELECTRIC (PAINTED) O/S ELEC R/CON PAINTED MIR (DG7)
D42 COVER, REAR COMPARTMENT SECURITY (SHADE) R/CMPT SECURITY SHADE (D42)
D5S GEAR-SPEEDO DRIVEN (14085510) (D5S)
D8G SENSOR (D8G)
D81 SPOILER, REAR, AERO WING RR AERO WING SPLR (D81)
E5Z ADAPTER-SPEEDO-DELETE
E9Z KEY-SPEEDO, DELETE
FE2 SUSPENSION SYSTEM, RIDE AND HANDLING RIDE & HANDLING SUSP (FE2)
GU6 AXLE, REAR, 3.42 RATIO 3.42R (GU6)
G80 AXLE, REAR, POSITRACTION, LIMITED SLIP L/SLIP R/AXL (G80)
G92 AXLE, REAR, PERFORMANCE RATIO (MERCHANDISING OPTION) PERFORMANCE R/AXL RATIO (G92)
IPC TRIM, INTERIOR DESIGN
JG1 SHAFT, PROPELLER (ALUMINUM) AL PROP SHF (JG1)
J65 BRAKE SYSTEM, POWER, FRONT AND REAR DISC 4-WHL DISC BRK (J65)
KC4 COOLING SYSTEM, ENGINE OIL ENG OIL CLG (KC4)
K05 HEATER, ENGINE BLOCK ENG BLK HTR (K05)
K34 CRUISE CONTROL, AUTOMATIC, ELECTRONIC CRCONT (K34)
K68 GENERATOR, 105 AMPERE 105 AMP (K68)
LB9 ENGINE, 5.0L (5.0F) , V8 EFI CAR ONLY 5.0F (LB9)
MK6 TRANSMISSION, MANUAL 5-SPEED (BORG-WARNER) 5-SPD M/TRANS (MK6)
MM5 TRANSMISSION, MANUAL 5-SPEED PROVISIONS (MERCHANDISING OPTION) 5-SPD M/TRANS (MM5)
NA5 EMISSION SYSTEM, FEDERAL REQUIREMENTS FEDERAL EMIS (NA5)
NP5 STEERING WHEEL, LEATHER WRAPPED LEATHER WRAPPED STRG WHL (NP5)
N10 EXHAUST SYSTEM, DUAL D/EXH (N10)
N64 WHEEL AND TIRE, SPACE SAVER SPARE (ALUMINUM) AL SPACE SAVER SPA (N64)
PW7 WHEEL, 16X8, STYLED (ALUMINUM) (SUPERLIGHT) STYLED AL WHL (PW7)
QLC TIRE, ALL P245/50ZR16/N BL R/PE ST TL HWY 16"-TIRE (QLC)
T61 LIGHTING, DAYTIME RUNNING DAYTIME RUNNING LGT (T61)
T93 LAMP, TAIL AND STOP (SPECIAL) SPECIAL TAIL & S/LP (T93)
T96 LAMP, FRONT FOG FRT FOG LP (T96)
UB3 CLUSTER, INSTRUMENT (OIL, COOLANT TEMPERATURE, VOLTMETER, TACHOMETER, TRIP ODOMETER) GA (UB3)
UQ1 RADIO, PROVISIONS FOR STEREO STEREO RDO PR0VISIONS (UQ1)
UX1 RADIO, AM/FM STEREO, WEATHER, CASSETTE, EQUALIZER, ETR, INCLUDES CLOCK STEREO AM/FM W/CASS & EQLZR (UX1)
U19 SPEEDOMETER, INSTRUMENT (EXPORT) SPEEDO (U19)
U62 SPEAKER SYSTEM, 4, DUAL COAX FRONT, DUAL COAX PACKAGE SHELF 4 SPKR SYS (U62)
U75 ANTENNA, POWER (CHROME) PWR ANT (U75)
VAN PLANT CODE VAN NUYS, CA, CPC VAN NUYS, CA PLANT CODE (VAN)
VK3 LICENSE PLATE, FRONT MOUNTING PACKAGE FRT LIC PLT MTG PKG (VK3)
V73 VEHICLE STATEMENT - US/CANADA
WS4 TRANS AM OPTION TRANS AM (WS4)
WS6 PERFORMANCE PACKAGE, SPECIAL (MERCHANDISING OPTION) SPECIAL PERFORMANCE PKG (WS6)
Y83 NO DESCRIPTION AVAILABLE
Z31 PRICE SHEET - ADVANCE
Z49 MANDATORY CANADIAN BASE EQUIPMENT MODIFICATIONS (CANADIAN) (Z49) (CANADIAN)
1LE NO DESCRIPTION AVAILABLE
1SB PACKAGE-OPTION 02 (1SB)
18P WHEEL COLOR, CHARCOAL METALLIC (18P)
81Q MOLDING COLOR - BRIGHT RED (81Q)
81U EXTERIOR COLOR, PRIMARY, BRIGHT RED (81U)
82C TRIM COMBINATION, CLOTH, MEDIUM DARK GRAY (82C)
82I INTERIOR TRIM, MEDIUM DARK GRAY (82I)
829 SEAT BELT COLOR - MED DK GRAY (829)
1G2FW23F4ML211764
D8G SENSOR (D8G)
1 Post
Engine: LB9
Transmission: MK6
Axle/Gears: 3.45
Thanks for the VIN Mark. Identical to mine except colors.
There were surprisingly quite a few T-Top Cars built by Pontiac - 31 total. Here is the full breakdown of 90-92 Pontiacs, I hope to do the same with the Camaros in the near future.
1990 Numbers - No B4U Hawk or R7U Players Cup produced:
1LE production 1990 = 4, All TA's
1LE + C60 = 0
1LE + MK6 = 4, All TA's
1LE + L98 = 0
1LE + Z49 Export Models = 1
1LE + CC1 T-Tops = 2, both MK6 1 domestic and 1 Export
1990 numbers are complete - Compnine has a full data set for this year.
1991 Numbers including B4U Hawk & R7U Players Cup info:
1LE production 1991 = 106, 46 Formulas & 60 TA's
1LE + B4U Hawks = 9, All Formulas
1LE + C60 = 9, All Formulas and all L98 and all B4U Hawks
1LE + MK6 = 87, 27 Formulas and 60 TA's
1LE + R7U = 23, All TA's and all MK6
1LE + L98 = 19, All Formulas, 9 B4U Hawks
1LE + Z49 Export Models = 43, All TA's, all MK6, 23 R7U Players Cup Cars
1LE + CC1 T-Tops = 27, 8 Formula & 19 TA, all MK6 and 15 of the TA's were Z49 Export
We are missing two numbers from compilation shown below which appear to be 2 TA's that were delivered domestically.
1992 Numbers including B4U Hawk & R7U Players Cup info:
1LE production 1992 = 27, 17 Formulas & 10 TA's
1LE + B4U Hawks = 11, All Formulas
1LE + C60 = 11, All Formulas and all L98 and all B4U Hawks
1LE + MK6 = 16, 6 Formulas and 10 TA's
1LE + R7U = 5, All TA's and all MK6
1LE + L98 = 11, All Formulas and all C60
1LE + Z49 Export Models = 6, All TA's and all MK6
1LE + CC1 T-Tops = 2, 1 Formula & 1 TA, both MK6 and both domestic
We are missing 4 cars from the numbers in the compilation shown below, 3 Formulas & 1 TA - the yellow car from Musclecar Review could be one of these and it would be the only MK6 C60 that was produced in the 91/92 series if it's for real and coded as a 1LE.
1LE + C60 = 0
1LE + L98 = 0
I don't know how old this post is but I have just picked up a 1989 trans am 1le cc1 which they had know idea what it was and I picked it up for a steal
Engine: TPI(s)
Curious to see. Someone can run the VIN for you and check RPO codes.
Engine: 4++,350 & 305 CIs
Very nice score if its real.
Engine: TPI(s)
17 of the 26 1989 1LE Trans Ams were R7U cars ... all without T-tops. That leaves 3 in Canada (2 of which I have the VIN's on which were GM Test Mules - No T-tops), and 6 in the USA.
Mark.
Mark.
