Original or Aftermarket Firebird/Formula Hood Bulge Insert/Screen
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
Does anyone have any information on this Firebird/Formula Hood Bulge Insert/Screen? I got it from somebody who had a ton of NOS GM parts, but they had no part numbers on this.. nor can I find anything after some extensive searching.
Thank you!
Thank you!
Car: '84 Firebird TA & '87 Camaro LT
Engine: 350 V-8 & V-6
Axle/Gears: 3.23 & 3.42
Re: Original or Aftermarket Firebird/Formula Hood Bulge Insert/Screen
AFAIK, only the '82-84's actually had the air induction system. After that, I believe there was just a blank plate in the hood bulge intake. Should be GM part # 10024254, Cover, Orna (Exc Turbo)
I figured it was geared towards the 82-84 cars, but I had never seen it previously. It's not a 3D printed item from what I can tell, and the plastic 'feels' like it's been around since the early 80s. It's pretty thin and flimsy so I can see these not lasting long when in-use.
I am just curious if a company made these aftermarket at some time (maybe for the 80-81 TTA? I think their hood only has 2 tabs not 4 though), or if GM produced them but never got to use them.
A friend picked up one of the two the seller had, and put it on his Formula. Here's what it looks like installed.
I've never seen this insert...I'd think aftermarket. Only ones I've seen on cars were the honey comb type.
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
It is definitely an aftermarket thing. All of the ones I have seen are a honeycomb pattern from the factory or just a block off plate. Interestingly I have seen some early cars that did not get the air induction actually got both the honeycomb piece and the block off plate.
That's what I figured based on everything I searched, but I wanted to make sure.
Seems uncommon enough to at least be a conversation piece. Keeping it for my wife's Formula, as soon as we find her one.
Engine: 4++,350 & 305 CIs
From what I have heard, the guy that made them has died and family is selling the last of the stock. (who knows if that's true tho)
I think 1 should be saved in its current unused form and copies made from it to preserve the uniqueness of it. I looks like it was designed in the late 70s early 80s. Maybe the guy was in the design department at GM or a outside company? Wouldn't that be cool?
They sold out b4 I could get one or I'd have one.
89irocz355
26
09-12-2016 01:28 PM
