Correct rear hatch motor
Found this on Amazon. Is it the right motor for a third gen? It looks just like the ones I've seen.
https://www.amazon.com/dp/B001KQ43RE...070f02cc9fbd_S
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Correct rear hatch motor
According to the P/N it's for our third gens.P/N 22021675 86/90 and 91 it's the 1st design.
The last one I replaced in my '88 IROC came from a Cadillac DeVille trunk pull down in the junkyard. The motor and housing were the same. Since all I needed was the worm gear and housing, I took apart the DeVille pulldown, and swapped out the parts. It's worked for nearly a year now, and the total cost was $10.00 at the junkyard.
