Phoenix Graphix Gold is the Wrong Color!!
Old 02-14-2017, 07:29 PM
firebirdta84's Avatar
Car: 84 Trans Am
Engine: V8 305 4bbl
I recently purchased a low mileage, all original 1984 Trans Am in the semi-rare Dark Gold Metallic color, with gold decals. One of the stripe graphics needed replaced, so I bought a replacement from Phoenix Graphix. The color is WAY off! Check out the attached picture...it's even more noticeable in person.
Are there any other companies out there that sell the correct color graphics?
Do any of you ever see NOS GM stripes come up for sale?
I may just have to have a custom graphic made in the correct color, because this obviously won't do.
Old 02-14-2017, 09:44 PM
thtanner's Avatar
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
Re: Phoenix Graphix Gold is the Wrong Color!!
What did Phoenix say?
Old 02-14-2017, 10:21 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Which kit did you get? They have an "economy" kit and a more expensive kit, usually.
Old 02-15-2017, 12:44 AM
Twin_Turbo's Avatar
I got my kit from classic industries because I knew PG was wrong (had the wrong color on other cars as well, the gold is much more bland and not " vegas gold" at all)
I THINK (not sure) the CI kit is from stencils and stripes. I have had good luck with S&S in the past.
I'll check mine, I did look at my decals briefly and they looked OK. Sure hope it's not as bland as a color as that. I have the same greenisch gold trans am decals on my trans am. They need to go (fortunately I got some OEM ones)
Old 02-15-2017, 04:13 AM
Car: 84 Trans Am
Engine: V8 305 4bbl
This is the kit I purchased:
https://www.phoenixgraphix.com/transam/1984ta.php
There doesn't appear to be an "economy" and "professional" version - just this one.
Old 02-15-2017, 04:33 AM
Twin_Turbo's Avatar
Good to know. I was going to order that for my ta since I'm missing most of the stripes (and I like the hood decal even thoigh not correct for mine)
Hope they come through with something that does match
Old 02-15-2017, 09:08 AM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Your stripes (originals) most likely faded after 34 years,their is no way they are going to match a fresh set. Me personally, I would have replaced them all.
Old 02-15-2017, 09:09 AM
Twin_Turbo's Avatar
Did you even look? The right olive greenish is phoenix graphics. It's nowhere near the correct color
Old 02-15-2017, 09:13 AM
mantaguy's Avatar
Engine: 5.0 EFI
Yea I looked
Old 02-15-2017, 09:17 AM
Twin_Turbo's Avatar
I have several nos gm decals and they all resemble the left side in his pic and match the lower painted gold perfectly
Old 02-15-2017, 09:18 AM
mantaguy's Avatar
Engine: 5.0 EFI
I had returned a set to PG because the clear film was yellowish,so I assumed they were on their shelf too long,maybe that's what happing here.They replaced them with a fresh precut version that I didn't know was available.
https://www.thirdgen.org/forums/pict...&dl=1380233351
https://www.thirdgen.org/forums/pict...&dl=1384619350
Old 02-15-2017, 04:06 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Just an FYI that most decals have a limited shelf lifespan on the glue. You don't want to put NOS decals on your car today. They will peel off in no time.
Old 02-16-2017, 06:03 AM
Twin_Turbo's Avatar
I just checked the part number on mine and they are phienix graphics. They are the correct color
Old 02-16-2017, 06:27 AM
82tarecaro's Avatar
I had bought a set of Phoenix Graphics for my 1982 Recaro TA. The color, when compared to what was on the car was way off. Granted things fade, but I think they are just not the proper gold. I had a set custom made and it was closer to the original color. The Phoenix Graphics set was also not made like the original set, which was gold stripes on a black background. The new set was just individual gold stripes on a transfer paper. So I had a set made more like the original set. I just found it odd that I was able to get a better set made by a small business graphics guy and a set made by a big company was so far off from what was original to the car.
Old 02-16-2017, 11:59 AM
Car: 84 Trans Am
Engine: V8 305 4bbl
82tarecaro -
I think that's the route I will go as well.
Did you just buy an aftermarket stripe kit, take it to your local graphics guy and say "I want exactly this, only in the correct color" - or how did you make sure the stripes you created were the correct size?
If you don't mind me asking, what did a project like this run you?
Old 02-21-2017, 02:17 PM
tavert91's Avatar
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
I have purchased 2 products from PG over the years. One was fine (size, color and letter font) but the other was "off" in color and adhesion. I think my problem was that they shipped me something that had been sitting for too long after manufacture.
Old 02-22-2017, 07:39 PM
82tarecaro's Avatar
Originally Posted by firebirdta84
82tarecaro -
I sent you a pm
