In search for a 1988 TA Digital Dash Wire Harness
Car: 1989 Trans Am
Engine: 5.0 TPI
Axle/Gears: 3.45
I have the whole digital dash but the wire harness was all cut up so I am looking for another
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Re: In search for a 1989 TA Digital Dash Wire Harness
I'm pretty sure they dropped the digi dash after 88, so I don't think there is an 89 digi dash harness.
I think they also made some changes in the wiring pattern in 89 so if you are trying to swap an earlier year digi dash into an 89 TA, it won't match up to the engine harness. Plus with the changes to tpi and addition of VATS in 89 I would think that it would involve a lot of repinning connectors and other wiring adaptations.
It might be better to find complete harness (cabin and engine) from a digi dash car.
However, none of the digital dash harnesses are easy to find, good luck.
Car: 1989 Trans Am
Engine: 5.0 TPI
Axle/Gears: 3.45
Yes the dash was out of a 1988, it was part of a whole lot that I bought. I wasn't sure if they made any in 1989. But thanks so much for the info.
Might want to change the title of this thread to remove the 1989 or you might not get many responses
The_Phoenix
02-04-2016 07:10 AM
Sanjay
08-12-2015 03:41 PM
beachrodder
08-07-2015 04:27 PM
