a/c-heater vent removal
Car: 1988 Iroc convertible
Engine: 305TPI
Transmission: T-5, swapped it in.
Axle/Gears: no clue, but I'll learn
Is there a special tool made to pop out the a/c vents to replace them? Screwdriver seems like it would be too easy to breaksomething trying to pry up the tab with the swivel **** on it. Thanks!
1 Post
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Re: a/c-heater vent removal
Check the tech articles on the home page, it will tell you how to remove and repair. Welcome and a will usually provide you with an answer.
https://www.thirdgen.org/technical-articles
https://www.thirdgen.org/ventfix
Engine: 305TPI
Duke you're everywhere. I looked at tech articles, only saw like a door panel restoration, didn't really tell how to remove the screw cover. didn't see anything else. I'm fairly new, didn't see any search window type of thing. Thanks for the help! I'll try to get it right this time. :-)
1 Post
Car: 04 Silverado
Engine: 4.8
Transmission: auto
I edited my post and left you 2 links, it's an easy fix Oh and the search function is at the top of the page in red under the Hawks banner ad.
Engine: 305TPI
yeah, that was basically what I was doingg, seems like a tool could be made to eliminate/reduce the prying part.
