Third Gen Firebird Console Swap Info
#53
1 Post
Car: '87 Trans Am
Engine: 5.0L-V8
Axle/Gears: 3.23 - Posi -10 Bolt
Re: Third Gen Firebird Console Swap Info
Did you cut the little triangle piece that sticks out from the front of it? I think that gives you about 2 more inches to slide it up.. Mine didn't come with it though..?
#55
Car: 88 GTA Notchback
Axle/Gears: don't know
I think he means the "horns" that stick out the front. You need to cut those off.
#61
1 Post
Car: '87 Trans Am
Engine: 5.0L-V8
Like I said, if you cut the piece off I circled in red, it will allow you to push the console up around 2 more inches.
#64
1 Post
Car: 90' Firebird
Engine: 3.1
Axle/Gears: 3.27 9-Bolt
It all works out...
The fourth gen console fit perfect around the cut out in the tunnel.
I have a finger or two in the front to spare! I didn't take the time to look at the donor car with the third gen console but I suspect it's about the same.
#68
I know this is an old post but I’m fixing to do this tomorrow morning using a third gen camaro console that’s going in my Firebird. I’ve always thought the camaro consoles looked better to be honest. But what is that “slightest trim job to the top” mean? What has to be trimmed?
JadedBirdsFlame (08-02-2020)
#69
#70
sparky87GTA (04-07-2020)
#72
Has anyone tried putting a 3rd gen camaro center console inside of a firebird? the rubber inside my 1989 firebirds center console is giving out and my friends camaros (1992) center console is plastic and has a cleaner look to it so I was curious as to if i could put a camaros in a firebird.
#74
