Camaro seat belt buckle
The seat belt buckle receiver in my car is cracked on the passenger side and the belt wont clip in. i need a new one because the whole side of the receiver is cracked off as well and looks pretty bad. I have an 89 camaro rs and i know theres a recall but i'd rather just find a receiver somewhere and call it a day before i spend hours attempting to get GM to help. anyway basically i just need someone to tell me where i can find a reasonably priced buckle. the only ones i saw were $150. it just needs to be able to belt a person in. i don't really care if its even the correct color match. are there other models for the 4th gens that will work as well? any input would be appreciated!
Car: 89 Iroc Convertible
Re: Camaro seat belt buckle
I have several passengers side front receivers.They are all in good shape with brand new gm red buttons,springs and metal bumpers.I have black,grey or beechwood tan.Asking 30.00 +shipping apiece
Car: 92 RS
Engine: 94 LT1 383
Transmission: T56-6 Speed
Axle/Gears: posi, 3.26:1,
Check out the Hoffman group. they have seat belts for $20, for a 2 pt and $60 for a 3rd gen per side and 21 colors to chose from. they also have lots of other cools stuff.
http://www.thehoffmangroup.com/autoloc/
Guest
Posts: n/a
i need a drivers side beechwood the red insert on mine is worn and old, can you replace them because my rears are in good shape but the red as well is worn... as for my drivers the outer casing has deteriorated....let me know thanks.. i would only be interested in a real nice to mint one... thanks Pete
ellas01@optonline.net
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
You can buy the red buttons seperately. I've seen them on the net but I got some thru GM. Easier as I work at a GM dealership.
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
I've got a few sets of black recievers with intact plastic and buckles that work well. Buttons are a little faded but not real washed out looking. Asking $30 a set plus shipping. And have a few extra drivers side only in black as well. $20 plus shipping. Pics if you send me an email address
Car: 1985 camaro Z/28
Engine: 305 V/8 4bbl carb
Transmission: T5 WC
Axle/Gears: 3-23 posi with 4 wheel discs
I have pairs in grey and black. They all have brand new gm red buttons,springs and metal bumpers.60 dollars shipped in the USA
Car: white 87 iroc-z
Engine: 5.7 tpi
Axle/Gears: 3:27
my82roc thanks for the radio plugs. Do you have any red buckles for driver/passenger.
Car: 89 IROC Convertible
Transmission: 5 Speed
I need belts for an 89 Convertible IROC. Particularly the driver front and both rear. Color preferred is Carmine Red, but black will do if I can get a complete set.
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
mmiscoe ,I have full sets of the receivers ( end with the buckle on it ) in black, but you are saying you need the actual belts parts aren't you ?
I have vert belts in grey from an 89 Iroc vert.My 89 iroc vert has carmine red which I would consider selling but not until I find tan belts.Im doing an interior swap from carmine to saddle tan
my82roc (or anyone else that might know where to get a front set) >> I'm looking for gray selt belt receivers (Front, driver and passenger) for my '92 Z28 convertible. They're a bit worse for wear, red buttons are more pink!
I'm replacing the carpet, so it seems a good time to toss out my 'looks old' receivers and put some nicer ones there. Might even spring for a rear set as well if someone has them all. Main interest is the front ones for this car >>
http://youmarketing.net/92z28.html
Thanks in advance folks!
Mike
Mike
Car: 91 RS vert
I actually need a red front set of receivers, but I'd buy a black set for that price - please let me know. Broken seat belts are a real pain as we use them every time - state law.
Car: '87 Blue Z28 Tee Top
Transmission: T5 WC
Transmission: T5 WC
Location: South Bend Indiana iphone CALL OR TXT 574-607-2389
1 Post
Car: 2003 GMC 2500HD Sierra Pickup
Engine: 6.0 Vortech
Transmission: 4x4
I have 1 grey reciever uncracked, i forget which is driver and pass long or short lol.
Ray
Ray
great... do u accept pay pal?
and also please--contact me at
charles.rosen@comcast.net
this belt is functional and looks good with no
cracks??
im ready to buy and i need it shipped to 33063
florida--35.00 with shipping??
deal.
cracks??
deal.
Transmission: T5 WC
cracks??
deal.
cracks??
deal.
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Hello All!!
If you really need a seat belt buckle receiver, I do believe that 1990's/early 2000's Cavaliers will work/fit also!!
If your not worried about the exact match, it's a good alternative/temp fix!!
P.S. I'm just not sure of the exact year of Cavalier, but I did try this in my local junk yard, and the seat belt latch plate does fit, and stays secure!!
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
I am looking for a set of grey front receivers for the seat belts, if anyone has some please PM me
#43
Rather than start a new thread on the same topic, I thought I'd resurrect this old topic.
I have a 1990 Camaro (gray) and the seat belt receiver, especially the driver's side one, could use replacing. The plastic sleeve around the belt is torn and frayed. The buckles work fine, but the red on the button has faded, like most do.
Does anyone have at least the driver's side one or a pair of both to sell? I saw that most of these shipped for about $30 each, so I'm looking to pay that. Thanks for any help in advance,
~Jim
~Jim
#44
Does no one have any of these for sale anymore? Seemed like there was a lot of activity on this a couple years ago. Does anyone have an idea where I could find such a part?
#45
On Probation
If no one responds here or in the parts wanted section and no luck on fleabay you could try your local pic a part yard
Just about any late 70s early 80s GM female reciever end would work with your existing factory male belt ends.
I also had no luck for my 84s recievers and got a set from a 76 olds cutlass along with mint plastic guides. Bolted right in and worked with the factory male ends/belts.
#48
#49
Car: 1991 Z-28 Convertible
Engine: 5.0L
Do you still have any seat belt covers for sale? I have a 1991 convertible gray interior and both front seatbelt covers are cracked!
