B&M Megashifter console cut out
Old 07-29-2010, 08:32 PM
kd5icr's Avatar
Car: 1985 Camaro Z28
Engine: 305 mild build up
Axle/Gears: Stock
Does anyone here have the template used to mark the console to cut it out to fit the top plate and shifter? I got a used one here and now I am installing it. I have it in and it shifts great. now I just need to cut the console. I know I can guess at it and cut out a little at a time, but if I can get a template I would rather. The car is a 85 Z28. I am also going to post an ad in the clasified area, I want to sell the old shifter head it is the ball type in leather. The leather is worn but not to bad.
Thanks.
Old 07-30-2010, 03:39 AM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Re: B&M Megashifter console cut out
I just eyeballed mine as ive cut a few for me and a friend and we had the same shifter. I took mine and mimiced mine and when he put it in his car it hit slightly. Mounted slightly different I guess. If you have the boot for it then it will cover up everything cut anyways so it will look clean for sure.
Old 08-19-2010, 09:37 PM
jt1562000's Avatar
Car: '88 IROC-Z
Engine: 383 Stroker
I have one I can send to you. Just PM me your address and ill get it on its way.
Old 08-20-2010, 06:04 AM
6SIX6's Avatar
Car: 89 IROC
i found my old one yesterday as well if you need it
Old 08-22-2010, 08:58 AM
kd5icr's Avatar
Axle/Gears: Stock
Thanks guys, I went ahead and did it by eye. fits great and another guy here sold me the mounting brackets so now it looks and works like it should.
Old 09-27-2010, 10:59 AM
G92RS's Avatar
Car: 92 RS Camaro
Engine: LHO 3.1L V6
Transmission: 700 R4auto
i actually have a suggestion for you go buy some abs plastic, use a dremel and seperate the ashtray portion from the shifter bezel and fabricate a piece of plastic to put underneath the megashifter bezel. its what i did
Veaceonee
09-29-2016 08:15 PM
RyanJB
05-07-2016 06:23 PM
skinny z
10-05-2015 06:23 PM
ndndndnd
09-28-2015 08:00 AM
MORREALE5
09-13-2015 09:01 PM
Quick Reply: B&M Megashifter console cut out
