shift knob
Old 03-10-2011, 04:54 PM
z28lnmn's Avatar
shift ****
Can anyone tell me how to remove the shift **** on a 1984 Camaro
Old 03-10-2011, 06:52 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: shift ****
is your friend.
Old 03-10-2011, 07:17 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: shift ****
Auto, or stick shift? And if auto, is it the ball shifter?
Old 03-10-2011, 08:11 PM
z28lnmn's Avatar
Re: shift ****
Yes it is auto & yes it has the ball ****.
Old 03-10-2011, 08:58 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: shift ****
Pull straight up on the buttun. It should come out easily. Looking down in the **** you will see a circlip around the shaft. Using circlip pliers that have points to fit inside the little holes on the ends of the circlip, you compress the clip allowing it to freely be removed. Careful not to lose it. The ball should now pull straight up and off. Note the slot or slots that the ****'s tabs are sliding off of and make sure to replace the same way. Voila!
Old 03-11-2011, 12:03 PM
z28lnmn's Avatar
Re: shift ****
Thanks alot that worked I appreciate the help. Thank's again
Night rider327
02-25-2016 09:50 AM
Cam-aro
Camaros Wanted
11-12-2015 03:35 PM
racereese
10-03-2015 03:46 PM
HoosierinWA
Members Camaros
09-29-2015 12:43 PM
J. Chris Davis
Interior Parts Wanted
09-28-2015 11:55 AM
Quick Reply: shift knob
