camaro interior in a firebird?
Old 05-06-2013, 10:21 AM
andy74's Avatar
Car: 1988 gta carbed 383
Engine: small block 4bbl
Axle/Gears: 3.27 g80
I have a almost complete dash and console for a Camaro,and the dash and console for my 88 gta are really screwed up bad, since I already am swapping to a non a/c heater box,should I or could I swao in the Camaro pieces? my digital dash doesn't work,and I have all the analog Camaro pieces, or will it look stupid? opinions and suggestions please!
Old 05-06-2013, 12:38 PM
Sam L.'s Avatar
Car: 1990 Camaro Iroc-z Z28,1987 Camaro
Engine: 406 Super rammed SBC, LT1 355
Transmission: 4l60E, 700R4
Axle/Gears: disc brake 3.27 9 bolt posi,10 bolt
Re: camaro interior in a firebird?
do it,it will mix it up id definetly get a new digital dash! i think the camaro pieces should look good!
Old 05-07-2013, 03:20 AM
TheAmazinGreat's Avatar
Car: 1989 Firebird
Engine: 2.8L V6
I put a Camaro console in my Firebird with the stock Firebird dash and it took a bit of cutting and fitting to get it in but I like the look of it a lot more than the Firebird console so as far as the console goes no worries there. If you're swapping in a Camaro dash the console should go in fairly easy but I can't say anything about how the dash will fit. I say go for it, you can always change it back.
Old 05-07-2013, 04:52 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
It's not as easy as you might think...
The side supports will NOT support the Camaro dash. You would need to remove them from the one car and install in the other. These would be where the lower dash bolts go up from the bottom into the body brackets.
Old 05-09-2013, 03:00 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
I've never been a fan of the Camaro interiors, I always thought they looked cheaper than the Firebird ones. Therefore, I'm gonna say leave it as it is. Consoles can be repaired, and if you keep checking your local junkyards, you'll score a mint dash pad for cheap sooner or later.
Old 05-10-2013, 02:35 PM
Billyjoebob007's Avatar
Car: 83 Camaro Z28 (CFI)
Engine: 305 V8 (CFI)
Might as well put some Camaro wheels on it too Name:  09666003ea.gif
Frozer!!!
01-19-2024 04:55 PM
1992 Trans Am
05-10-2023 07:19 PM
Vintageracer
01-10-2020 05:33 PM
colton_carlson
03-08-2019 12:21 PM
Linson
08-21-2015 02:12 PM
Quick Reply: camaro interior in a firebird?
