Tilt Lever Cap Removal?
Old 05-24-2015, 11:43 AM
82IMSA's Avatar
Car: 1986 Camaro IROC Z28
Engine: LS7
Transmission: Built 4L80e w/GearVendors overdrive
Anybody know how to remove this without breaking it (see photo)? Also, is there room under it to run a wire and for a nut to hold an additional stalk? I'm trying to add a steering wheel control stalk to operate my radio, and this looks like the best spot to put it.
Tilt Lever Cap Removal?-steering-column-bowl-housingTilt Lever Cap Removal?-swc-stalk.jpg
Old 06-07-2015, 06:19 PM
transaero's Avatar
Car: 1987 Trans Am GTA
Engine: Warmed over 350 TPI
Transmission: 700r4 soon to be t56
Re: Tilt Lever Cap Removal?
When you have pulled that whole top section off, you need to unscrew the tilt lever. It will probably be very tight, I had to use vice grips and unfortunately pulled some of the paint off of the lever. Then the piece should just slide off.
Old 06-07-2015, 08:35 PM
82IMSA's Avatar
Engine: LS7
But how do I get the plastic housing loose? Does it just snap into the side of the steering column? Where do you pry to remove it without breaking anything?
Old 06-08-2015, 02:42 PM
transaero's Avatar
You need to partly disassemble the column. First you need to remove the steering wheel. Then you will need a lockplate compressor tool to remove a lock ring. Then there are several screws and torx bolts you'll need to remove. Then the top assembly should slide forward and you can slide the piece out (after removing the tilt level too).
Read through this thread:
https://www.thirdgen.org/forums/susp...-steering.html
Old 06-08-2015, 03:32 PM
82IMSA's Avatar
Engine: LS7
Thanks! I was hoping you didn't have to take the whole column apart to get it out. I could have sworn it just snapped in to the side of the column.
1992 Trans Am
05-10-2023 07:19 PM
Vintageracer
01-10-2020 05:33 PM
DonW
08-24-2015 08:24 PM
3rdgenparts
08-08-2015 07:09 PM
Quick Reply: Tilt Lever Cap Removal?
