My version of cup holders
Old 05-29-2015, 09:53 PM
WTR388's Avatar
Car: 87 Trans Am
Not super inventive, but they work and they look like they belong!
Took two of those fold up marine cup holders, and a 5"x5" piece of .032 aluminum, sandwiched the door panel between the two and riveted it all together. Works like a charm, took no time to do and it was cheap. The appraiser didn't even take note of them when he went over my car.
Never mind the mess... That's been all cleaned up.
Old 05-31-2015, 04:01 PM
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Re: My version of cup holders
I have the exact one but its mounted on the passenger side of the center console right next to the radio with two sided tape. Best aftermarket solution I have seen.
Old 05-31-2015, 06:13 PM
Stauf's Avatar
Car: 91 Z28 Coupe
Those actually match pretty well with the camaro interior. I would never do that to mine, but they do look stock if you didnt know otherwise.
Old 05-31-2015, 06:16 PM
mjdavis68's Avatar
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
Hey, nice touch.
Old 05-31-2015, 09:38 PM
WTR388's Avatar
Car: 87 Trans Am
I don't even notice them now that I've driven the car around a bunch. Only negative, is if they are open you have to remember to not kick them with your feet when getting in.
I'm hopefully re-doing the door panels this winter and adding some door speakers, so I'm going to somehow keep these in the same position.
Old 05-31-2015, 09:57 PM
1983Chimaera's Avatar
Car: 1988 Camaro IROC-Z
Engine: LB9 (305 TPI)
Axle/Gears: 2.73 Positraction
I have door speakers, and unfortunately where those are mounted is pretty much the ONLY available cut out in the door to put speakers, and even then it's a tight fit if you have power windows (the motor housing is right there as well).
Fanatic1074
10-03-2022 05:57 AM
3rdgenparts
05-21-2016 11:50 PM
IROCZDAVE (88-L98)
09-17-2015 07:43 AM
gta892000
09-16-2015 12:37 AM
Quick Reply: My version of cup holders
