cigarette lighter fuse
Transmission: Pro-built 700R4
Re: cigarette lighter fuse
If your dome light comes on it is not the fuse. It could be the lighter receptacle. I had an issue with mine as well and I had to replace my receptacle. It is a bit tricky because you can't get the nut too tight or it will ground itself out.
1 Post
Car: 91 firebird Formula 350
Transmission: N/A, working on a t5 swap
Axle/Gears: 3.73 posi
its the ACC fuse. oddly enough, its also the same fuse for the search bar at the top of the website. So if it's blown I guess that would explain why it wasn't working when you tried to use it. you DID try to use the search bar, right?
gta892000
09-16-2015 12:37 AM
