Door panel question..
Car: 1986 IROC Z
Does anyone make and sell just the board part of the door panels? Looks like mine got wet at some point and are all warped. The fabric/carpet part of them is in pretty good shape still and just needs a new flat backing to attach to.
Car: 89 GTA
Engine: 5.7 TPI
Re: Door panel question..
http://www.classicindustries.com/sho...nts/?&p=1&r=60
Hawksthirdgen also has the door panel complete. Doubt you'll just get that cardboard stuff anymore.
Car: 1985 z28 camaro
Engine: 305 lg4,edelbrock,3"air cleaner.k&n
Transmission: turbo 700r4 w/b&m megashifter
Axle/Gears: Stock.
Hi,
Mine were also badly warped. The material that the factory used was rubbish.
You can make your own from 3 mm MDF, ( medium density fibre board ).
Trace the shape of the originals onto the board, and mark the location of all mounting holes,then cut out with a jigsaw. I glued the mounting clips to the board, before I covered the panels in fabric.takes a bit of work,but if you take your time, you will get a good result. It is a good idea to put a coat of varnish on the back of the board,and make sure that you put the factory plastic lining back on the door if you have it. Then if you get any moisture in the door, it wont affect the door panel.
Cheers,
Alicat.
Cheers,
Alicat.
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Hi,
Cheers,
Alicat.
Cheers,
Alicat.
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: WC T5
Axle/Gears: Torsen 3.73
I made my own out of whiteboard, its just thin wood with the white backing on it that they use in classrooms. That white backing is more resistant to water so its perfect
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Check with a local/custom upholstery shop.
The originals were constructed via an industrial sewing machine which you probably don't have access to, but that was part of the reason GM chose that material.
EvilMunky707
Interior Parts Wanted
10-18-2015 03:22 PM
aaron7
10-08-2015 12:53 PM
1Aauto
Sponsored Vendors
10-02-2015 10:18 AM
