Dashboard (not dash pad) holes
Car: 1985 Camaro Z28 IROC
Engine: 5.0L TPI H.O. 215HP STOCK
Axle/Gears: GU6=3.42
Ok everyone, so the P/O had a couple things screwed into the dashboard, the panel just above climate control and under the center vents, and I want fix it or replace it. The vids I found showing dash removal is probably the single hardest thing to do on these Camaro's, so I'm not feeling that. Maybe some back epoxy with a sewing needle, unless someone knows if I can replace just this small section.
Thanks for your help in advance
Re: Dashboard (not dash pad) holes
I think a repair would be obvious but it all depends on what you are satisfied with as an outcome. Some plastic filler will fill it, and maybe a light spray with some SEM Landau black, but in order to get a consistent sheen on the paint you would need to spray the entire dash.
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
And it's not so bad if you aren't actually removing it so you don't have to disconnect any wiring.
Agree that any attempt at spot repair will look pretty crappy.
I think the easiest repair that would be acceptable would be to get a piece if similar plastic or a donor piece from a broken dash and glue it on top. Maybe get creative with some other kind of panel
Only an hour??? Who would be willing to come to Lansing and help/show me? I can pay, either with beer or cash...lol
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Thinking out loud here but if you had a scrap piece like from a junk yard you could try patching holes before attempting on your good one. That way you could experiment matching the color as well as the texture. Could even try making an impression of the surface to use over the hole/s to help match the texture. Thinking the technique would be something similar to vinyl repair.
