Wrapping dash in vinyl
Car: 1988 Firebird
Engine: 2.8
Transmission: THM 700R4
Ok so i have decided to wrap most of the plastic dash piece by pice in black vinyl. I already have the dashpad sanded and ready for recover and have done the stereo faceplate. I will post more pics as the pieces get finished.
After sanding and wiping it off the white in the center is the repaired part. Just need to wrap it but am considering using thin foam under the vinyl for a custom look.
Before after supergluing where it broke right side.
After i was done and yes it fits Perfect !
1 Post
Car: 1984 firebird se
Axle/Gears: 373
Re: Wrapping dash in vinyl
88 Birdman, is the wrap the shrink type? Where you heat it with a hair dryer/heat gun? Thx byron
Car: 91 Z28
Engine: Enhanced 5.0L
Axle/Gears: 3:42 Posi
so far,so good..show your bird people the back side too, so they understand the cuts/wrap it takes to make the corners...tell us your secrets!
breathment
08-09-2002 11:51 PM
breathment
03-26-2002 12:20 AM
un4givin89
03-15-2002 11:43 AM
